The closed caption on my dynex tv is grayed out how can i turn this off?
circuitcity
  • 137 Answers
SOURCE: closed caption and black square
your TV do not disable close caption in composite mode. It may in component mode. Please make sure that the close caption in your TV menu is not set to "text"
Please be advice that CC :Text is the ONLY one that can give you a black box.
Best regards
Circuitcity
Posted on Dec 09, 2007
SOURCE: Closed Caption won't turn off
cannot turn off closed caption on 27" insignia. the option screen which illustrates the closed caption category, is not highlighted and you cannot manually choose that option from the remote control.
Posted on Jul 29, 2008
SOURCE: Sony 46" XBR2 Cannot turn off closed caption
With TV on, turn off DVR and hit menu on DVR remote - you can disable CC from there.  Worked for us - got the idea from another fixya post.
Posted on Aug 28, 2008
SOURCE: toshiba 62hx94 cant shut off closed caption have comcast cable
The problem was with the Motorfolla Comcast cable box not my T.V. . I turned off my Comcast cable box, pressed menu on the remote to the cable box. This made a 16:9 ratio appear on the cable box's LED read out, and a bluish screen appear on my television. One of the options on my television was to turn on and off closed captioning. Therfore, I turned off closed captioning and the problem was solved.
Posted on Jan 30, 2009
SOURCE: Cant turn off closed caption
I have this same problem...TC-P42X1...can't turn off the closed captioning
Posted on Aug 29, 2009
How do i delete closed captioning?
The button marked CCD "close caption display"
BTY if the TV programing is coming via cable box that the CCD feature needs to be turned off in the cable box under settings. If there is a cable remote the CC will usually be near to the "cable" button
26052381-dbyvlhzmxmckmsztft4cqgrd-4-0.jpg I hope that this helps?
Jan 13, 2016 | Dynex DX-L19-10A LCD TV
Can't turn off closed captioning on TV
Hello
1. Get into its setup menu.
2. Press 'UP' or 'DN' button to select the "Closed Caption" option.
3. Press ' >' or "ENTER". The closed caption menu options.
Select "CC" mode to 'Off' if it is now 'ON (Press UP or DN to hilight the option you want to OFF, and then press "Enter".
Feb 11, 2012 | Dynex DX-L42-10A 42 in. LCD TV
I have a DYNEX 42"
Do you have a cable or satellite box connected to the TV? If so the box is probably what is providing the Closed Caption and not the TV.
Robert
Feb 26, 2011 | Dynex DX-LCD37 TV
My closed caption on my new dynex 26L 150A11 will not turn on. I have followed all instructions in the book. I need the cc. any one have an answer? thanks cosycat
There are several possibilities here so you will need to work with me to resolve this problem. In order for Closed Captioning (CC) to work, you need to make sure the CC settings are correct on the TV, and then make sure they CC is switched on. In addition, if you are using a cable or satellite receiver box, CC also needs to be switched on for these "boxes".
It's easiest to start with the TV. Please make sure you have done the following:
1. Check the Closed Caption settings are as follows from the TV on-screen menu as follows:
a) Press the "MENU" button on the DYNEX remote
b) Press the RIGHT arrow twice to highlight the "SETUP" menu
c) Press the DOWN arrow once to open the "SETUP" menu
d) Press the DOWN arrow twice to highlight "CLOSED CAPTION"
e) Press the RIGHT arrow or the "ENTER" button once to open the CLOSED CAPTION MENU
f) Make sure the Closed Caption option "CC MODE" is set to "ON". This can be changed using the UP/DOWN arrow keys to highlight "CC MODE" and using the LEFT/RIGHT arrows to switch between off and on.
The "Basic Selection" and "Advanced Selection" settings are for analogue and digital closed-captions respectively. In addition, the "Options" sub-menu can be used to change the size and style of the digital closed captions (Advanced Selection). All three of these options should eventually be set according to your personal preferences, but for the purposes of making sure it is working, I suggest you set them as follows:
Basic Selection = CC1
Advanced Selection = Service 1
These options are the basic settings which will display only the spoken dialogue of the TV program.
g) Press "EXIT" on the remote to close the menu and return to viewing mode.
2. Press the "CCD" button on your Dynex remote control. This can be found in the bottom right-hand corner of the remote. Each press of the "CCD" button will cycle the closed captions between ON and OFF. (CCD means Closed Caption Display)
3. Check the Closed Captions are displayed and then adjust the Basic and Advanced Selection options until the type and appearance of the closed captions are how you like them.
If you have done the above and still cannot get it to work, please let me know whether you are using a cable or satellite receiver and the brand/model number. I will then be able to assist you further.
Regards,
BElectric
Dec 30, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
I can't get the closed caption off of my Dynex television...
Check the remote have a button CC.Used the CC button turn off all CC1,2,3 all off.Or goto tv Menu find closed caption 1,2,3 or Text 1,2,3 turn it all off.Will not get anymore closed captioning or big black boxes anymore.
Sep 17, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
I cant get the captions off the tv?
Go into the menu. There will be closed caption turn on/off option.
Nov 22, 2009 | Dynex DX-L42-10A 42 in. LCD TV
Closed captions will not work thru my tv remote
I hope this was resolved but this is a dish page and I am unable to answer Comcast issues.
Feb 14, 2009 | DISH Network 811 HD DTV Receiver
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
Electro Med Services...
