Question about Blackburn Flea Rear Flasher Bicycle Taillight
How do I turn off my rear flea light after my ride in the rain my rear flea light came on, and now it won't turn off?
2 Suggested Answers
  • 4 Answers
SOURCE: My rear flea light won't
it might be water damaged return it to bike shop and ask for full replacement under the lifetime warranty
Posted on Sep 28, 2011
Rear Light will not stay on
Sounds like a bad contact in the switch. This seems to be a common problem.
Jan 06, 2013 | Blackburn Flea Light Set
My flea will not stop blinking after charging
Turn it on for a few minutes then turn it off and it should stop blinking.
Dec 26, 2010 | Blackburn Flea Rear Flasher Bicycle...
My blackburn flea front light isn't charging through usb port, tested on 2 laptops
'Had this problem... turned out that the contacts weren't mating properly between the flea and the dock. I remedied by shaving back some of the plastic surrounding the contacts with a pocket knife.
Sep 17, 2010 | Blackburn Flea Front HL Bicycle Headlight...
After charging the Blackburn Rear Light, it won't turn off. Any suggestions on how to get it to turn off.
Your Flea iscontinuing to flash because it acquired extra energy during the charge. Once the extra energy has been burned it will shut off. To help preventthis try to charge the Flea for no longer than an hour to an hour and a half,and don't charge the Flea after every use.
Aug 02, 2010 | Blackburn Flea Rear Flasher Bicycle...
The front light turns off after a few minutes
It may be in demo mode. Hold the power button for 20 seconds.
May 02, 2010 | Blackburn Flea Front HL Bicycle Headlight...
How do I insert the battery into the Blackburn flea?
It's a rechargable light, with a built in battery and no supposed user replacable battery. You need the USB dock to charge it either through your computer or using the optional Blackburn solar panel.
Jan 16, 2010 | Blackburn Flea Front HL Bicycle Headlight...
I cannot get Blackburn flea to take a charge. It only the 2nd time I am recharging the rear flea. Its a brand new battery.
It might be stuck in 'display mode' (described on the package). Try holding down the button for twenty seconds until you see the signal. Then try turning it on normally again.
Aug 29, 2009 | Blackburn Flea Rear Flasher Bicycle...
My Flea Taillight won't charge, I'm using a brand new "AA" battery, (hooked up - red to + and black wire to - ) I've reset the "light from demo mode (holding down the button for 20"...
Try cleaning the contacts with a cotton swab and som isopropyl alcohol.
Let those dry.
Use a paper clip, or other small pointy object to clear the area around the contact points on the light so the recharger can fully "snap" into place.
Attach a battery you know has a good charge.
Turn on the light.
Did the light turn on?
If so, great, turn it off, and if it is blinking, let it recharge.
If it didn't turn on, isn't blinking and won't hold a charge after this process, return it to Blackburn and enjoy the benefits of your lifetime warranty.
May 08, 2009 | Blackburn Flea Rear Flasher Bicycle...
Blackburn Flea Rear Flasher Bicycle Taillight Logo
51 people viewed this question
Top Blackburn Cycling Experts
John Egan
John Egan
Donald Ayers-Marsh
Paris Johnson
Paris Johnson
Level 1 Expert
Are you a Blackburn Cycling Expert? Answer questions, earn points and help others
