Question about LG Cell Phones
How do I fix my lg phone won't charge or turn on unless holding connector at an extreme weird angle
clairehenry
  • 15 Answers
SOURCE: Won't Charge
If you take your phone to any verizon wireless store they will replace it free of charge. You will lose your contacts, pictures, text messages and videos though. If you want to get your contacts back, you can back them up to "my account" on the verizon web site. If you buy a micro sd card, you can save your pix and flix to them so you don't lose any.
Posted on Nov 30, 2007
Bajanguru
  • 7752 Answers
SOURCE: Razr phone charge
that means your charging port needs to be replaced so take the phone to any mobile service center to have them replaced it there for you.
Posted on Feb 15, 2008
SOURCE: Won't Charge- Is there anything I can do?
well i dont have any long term ansa but here is a short term one while you find a new charger.
Take the charger and dismantle the end that plugs into fone. you should have 2 wires a black & white or black & red. Leave the blobs of solder on the end of the wires as this helps. Leave the wall socket end of charger in tact.
Take your battery out of fone. As with a normal battery you will see a (+) and (-) sign on it. Attach the black or darkest wire to the negative (-) metal square on the battery and the white or lightest wire (maybe red) to the positive (+) metal square on the battery (after trial & error i found a clothes peg to be the best form of attaching it). Leave attached for 15 minutes and this will give you around an hours usage when you put the battery back in the fone. If you leave it overnight then it will be on all day.
Basically you are making the circuit without the fone which bypasses your pin problem. Any charger will work with any fone as the charging components are in the wall end. Just make sure the voltage is compatible ie, 5v fone charger replacing 5v charger etc. Although majority of chargers are 5v.
I know this works cos i did it to mine last nite as i needed to ansa my emails. Really simple but a little drastic like i said but if the pin connector is broke anyway wot you got to lose?? I am a girl so if i can do it anyone can lol!!
Only drawback is you cant use the fone while it is charging unless you have 2 batteries and you use one while the other charges which is what i am doing. In fact i might not buy a new charger lol, i dont need one now ive found this method works.
Happy charging!! Hope this helps! Gail-michelle
Posted on Jul 15, 2008
  • 5 Answers
SOURCE: My phone just randomly stopped charging!
The problem is with your charger, because of use, the wiring has grown loose.
I've had it happen with several of my cell phones. I suggest buying a new charger, keep the receipt and box, try it. If that's doesn't work, return it.
Posted on Jun 20, 2009
  • 36 Answers
SOURCE: my phone wont charge unless i am holding it at a
its may be your chager point problem after changing charger is not done then you will change your ph charger point i think then the problem will remove
Posted on Jul 15, 2010
My LG Leon phone will not charge. How do I fix this?
Hi Lisa, The link below is a youtube video showing you how to fix your phone....CHEERS..
How To fix any Android Phone Tablet that won turn on
Apr 03, 2016 | LG Cell Phones
Lg vx6100 won't turn on or charge
There may be liquid damage present. First using a flashlight, inspect the battery contacts and data/charging socket for green mold/water damage. If nothing unusual is discovered you could disassemble and inspect the inner circuit boards for white residue that would be left behind from water calcium, clean the calcium from the circuit board with a slightly wet toothbrush and dry with compressed air or a hair dryer.
Dec 22, 2013 | LG VX8300 Cellular Phone
My samsung doubletime won't turn on unless it's plugged in
REMOVE BATTERY > Clean the terminals specially middle terminals of both battery & phone with dry cloth.install battery. If the problem persist then change battery.
Aug 07, 2012 | LG enV VX9900 Cellular Phone
One lg vu 920 turns off after 5 seconds and the second wont recieve service
  • Keyboard issues (no predictive text):
    • This isn't a "fix" per se, but it seems the best route is to use an alternative keyboard. Swype is pre-installed on the phone, so you can switch to that without installing anything new. Alternatively, you can try other players such as SwiftKey, A.I.type, and TouchPal. Otherwise, LG is aware of the issue and working on a fix.
  • Phone won't charge
    • The potential fix is to enable USB Debugging. To do so, head to Settings -> Applications -> Development -> make sure USB Debugging is checked.
    • Alternatively, if it won't charge normally (while powered on), it should charge while powered off. Your best bet is probably to power it off and let it charge while you sleep.
    • For some people, it seems that the phone actually is charging, it just doesn't show it.
  • Can't use USB storage
Unfortunately, there are no perfect fixes for any of the issues listed above. Other users are reporting a smattering of smaller (and substantially less frequent) issues, but hopefully the above can help some people with the most significant issues.
Mar 02, 2012 | LG Cell Phones
Revived wet phone only works when plugged in
Yes if it only works on the charger than that means that the battery is fried due to the water damage if you replace the battery the new will hold a charge and it should work. cause the water damage probably is keeping the old battery from holding any kind of charge. Hope this works for you
Dec 01, 2009 | LG Dare VX9700 Cell Phone
Jun 20, 2009 | LG RUMOR Cellular Phone
Must hold HP laptop at awkward angles for it to work
Common problem.
Cold solder on South Bridge, BGA chip needs reflow/fix.
Jan 06, 2009 | HP Pavilion dv4000 Notebook
Power chord
get a power cord as it would be less expensive because if the connector on your system is faulty you may have to spend a lot of monet
it happen with the power cord that they go gad
so don'y worry about that
Jun 10, 2008 | IBM ThinkPad T43 Notebook
Won't Charge
not sure of the warranty laws in the US but if they are the same as Aus. then it will be repaired.
As long as you have a reciept from the store you purchased from and the fault is deamed a warranty fault.
Having said that I would deam it as physical damage and therefore not a warranty repair
which means you would be charged to have it fixed
Nov 22, 2007 | LG CHOCOLATE VX8500 Cellular Phone
Cell Phones Logo
19 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
