Question about NEC Fd3238h Slim 1.44mb Floppy Drive 134-508054-374-0
NEC FD3238H Slim 1.44MB Floppy Drive macintosh
Hello! I have a Floppy Drive FD-235HG-C332 manufacturer TEAC. I want to know what data capacity (Operations modes) has my device: 720Kb, or 1Mb, or 1,44Mb, or 1,6Mb, or 2Mb. There are jampers, placed...
Your TEAC FDD (floppy disk drive) is a Tri-mode device (720 KB, 1.2 MB, and 1.44MB)
The "235" part of the model number indicates the drive's form factor (size) is 3.5 inches.
The "HG" part of the model number indicates that the FDD is a Tri-mode device, with the 3 modes
given above.
The manufacturer notes that it has no jumpers, but every FDD I've ever seen has jumpers for
bus master/slave selection. Either master or slave will work.
Here's the manufacturer's web site URL for your TEAC floppy disk drive:
http://www.teac.com/DSPD/support/floppy_drives/fd235hg_id_your_drive.htm
Here's the info on the NEC FD 1137C drive:
Enclosure Type Internal
Interface Floppy (IDC)
Platform: PC
Technical Features Capacity 1.44 MB,2.8MB,360MB,720KB,1MB,640KB
Minimum System Requirements:
Operating System Microsoft DOS • Microsoft Windows 3.1 • Microsoft Windows 95 • Microsoft Windows NT
Form Factor: 3.5" floppy disk drive
Here's the best info I found on your NEC FD 1137C Floppy disk drive:
http://www.aliexpress.com/fm-store/602209/210081532-394871196/NEC1137C-DATE1992-floppy-Adaptive-720K-1-44M-120M-Capacity-120M-40PIN-Interface-3PIN-Jumper-FD1137C-NEC1137C.html
May 13, 2011 | Teac Floppy Drive 235HG (FD-235HG) Floppy...
I need the driver of NEC FD 1231H floppy
You can download the driver from Windows Update.
Plug the floppy drive in to your computer/laptop. Found new hardware wizard should pop up. Just follow this guide & it should work.
http://support.necam.com/oem/fdd/w2kusb/
Mar 11, 2011 | NEC Slimline (FD1231H) Internal Floppy...
I need the drivers for windows 98 I can send them to hveraauditor@gmail.com
  • Hello hverauditor, if you click on to this website, you may be able to get the "Drivers" you need. 'Cut and Paste to "web browser." Thanks for using Fixya, paul7of9. Click here: Manhattan External Slim USB Floppy Disk Drive Floppy Drive
Dec 15, 2010 | Manhattan External Slim USB Floppy Disk...
Floppy drive light stays on all the time
please remove the floppy disk if inserted floppy drive...........or unplug the floppy drive .........or check the motherboard setting....some times light on due to reading floppy disk........please try it and rate it
Apr 11, 2009 | NEC (FD1231T) Floppy Drive
Need updated drives for my MAC OS 10.4 for floppy disk drive
Had a power failure now my model #SD-USB -M2 drive for macintosh will not work what do I need
Nov 24, 2008 | Imation (01946) External Floppy Drive
Nec floppy
Is this a problem if it works?
Oct 30, 2007 | NEC 3.5 Versa P/M/S Floppy Drive...
NEC Fd3238h Slim 1.44mb Floppy Drive 134-508054-374-0 Logo
46 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
