Question about Dishwashers
Hobart undercounter dishwasher model FFW that is not draining after use?
  • 6 Answers
SOURCE: pressure release keeps draining hot water
The 1/2" drain line you are referring to is probably the 3/4" line from the booster heater located to the left of the pump motor. The temperature/pressure relief valve is bad.
The booster heater could be overheating (bad thermostat), or you may not have an expansion tank on your building hot water system. The heating and explanding water in the booster has no where to expand to, causing a pressure spike high enough to pop the valve.
First, change the valve. I use a heavier-duty Watts XL40 valve, I purchase them from International Commercial Supply or Johnstone. Even if there is a cause for them to leak, once they start leaking they need to be replaced.
Once the new valve is in, power up and test the unit. Power up and fill the unit, then let the booster recover until it cycles off. Run a cycle, and check your rinse temperature. I like to see 190-192 degrees. If it went higher than 195 I'd turn the thermostat down. If it didn't shut off at all, and the relief blew, time to replace the thermostats in the booster heater.
Posted on Sep 12, 2009
  • 93 Answers
SOURCE: Convert a whirlpool portable dishwasher to undercounter
I would simply slide the unit under the counter and connect the inlet and drian hose permenantly.If the unit is not tall enough and sits too low then build a shelf or false floor in the cupboard for it to stand on.
Posted on Dec 30, 2009
  • 110 Answers
SOURCE: Hobart dishwasher model LX30H displays -5 on
by the way you're describing the problem, i would have to say there is something wrong with your control board. part#473173 can be bought @ any hobart office in your area. dont forget to vote
Posted on Feb 13, 2010
Testimonial: "Turns out it was mice eaten wiring."
  • 119 Answers
SOURCE: Hobart WM-ID dishwasher doesn't heat water enough to clean dishes
The WM-1D does not have any internal heating devices. You have to supply the machine with the proper water temp. It has two fill valves, one for wash and one for rinse. It should have 150F supplied to the wash fill valve and 180F to the rinse fill valve.
Posted on Jul 16, 2010
SOURCE: KITCHENAID dishwasher will not dry the dishes
kitchen aid mod kud101dl does not clean dishes well. lot of scum on door.
Posted on Apr 03, 2011
Water continues coming
Hobart ' Undercounter Dishwashers, Commercial ...
www.hobartcorp.com/.../commercial.../undercounters...
Hobart CorporationGlasswasher ... The LXe undercounter is ENERGY STAR® qualified, uses only .74 gallons of water per cycle and features new Smart Display technology to eliminate error codes. Loading... Highlights: Hobart undercounter dish machines are the most popular in the industry, keeping reputations spotless all over the world.
Advansys LXe Undercounter ' Hobart
Hobart CorporationGlasswasher ... The Hobart LXe Undercounter Dishwasher is designed to pack best-in-class cleaning power into a compact space, ... The Advansys LXe low-temp model features PuriRinse, a cold-water rinse that removes chemical residue, ...
[PDF]AM15 Technical Manual - Hobart
https://my.hobartcorp.com/kroger/.../AM15%20Technical%20Manual.pd...
Steam Booster, if used based on 20 PSI steam - 20 PSI water flowing. 130°F entering.... DRAIN AND OVERFLOW: Large bell type automatic overflow and drain ...
[PDF]Glass- and dishwashers - Hobart
Dec 08, 2015 | Hobart Undercounter Glasswasher w/Chemical...
Need a service manual for a hobart Model FFW where do i find?
This link is for the Hobart Operator manuals.
https://my.hobartcorp.com/resourcecenter/default.aspx
I have searched for service manuals also, and there do not seem to be any.
May 09, 2014 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart LX 30 undercounter dishwasher, commercial Does this model require booster?
Most of the Hobart LX series of dishwashers have their own built-in booster heaters. To check for one, remove the lower front panel (2 screws). The booster heater, if present, will be a stainless steel tank on the left side. If it doesn't have a built in booster heater then it was meant to be used with chemical sanitizer instead.
Jun 29, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
WE LOST OUR MANUAL AT WORK AND HOBART LXH DISHWASHER KEEPS SHOWING DELIME , HOW CAN GET THIS GO AWAY, THANKS
Use a commercial deliming agent (like Lime Away or LSR). Remove the rack from the dishwasher and close the door. Press Off to power down the machine. Next press and hold Wash (Delime) while pressing ON. Delime should show in the display. The unit will fill with water and then flash Add and Delime. Open the door and add the deliming agent according to the directions. (The sump holds about 3 gallons of water.) Close the door and press Wash (Delime). The machine will start the wash mode for 5 minutes and then do two rinse and drain cycles. Delime symbol will flash while this takes place. When finished, the power to the control will be turned off. Check the interior of the machine for lime deposits. If needed, repeat the delime cycle. If the delime program is interrupted before it is completed, then start the delime process from the beginning.
The manuals and other documents are available to registered users of the Hobart site here: https://feg.hobartcorp.com/CookieAuth.dll?GetLogon?curl=Z2FresourcecenterZ2Fdefault.aspx&reason=0&formdir=2 . The direct link is: hobart.co.kr/install_pdf/040.pdf .
The spec sheet is available here: http://www.hobartcorp.com/products/warewashing/undercounters/lxi-undercounter/ .
I hope this helps.
Mar 15, 2011 | Hobart 25 in. LXIH-4 Built-in Dishwasher
My sr24h hobart undercounter dishwasher is stuck in a mode where all it does is drain water out. Will not do anything else...???
Hello There; If your unit stuck on the wash cycle and not advance to rinse cycle because the rinse water is not up to 180 degree . You've to check out the booster element and the rinse temp. I hope this will help.
Sep 19, 2010 | Hobart SR24-H Built-in Dishwasher
UNDERCOUNTER DISHWASHER (HOBART)
Can you give me the model number thats on the data plate,it should be a lx18,lx30h,lxih.Im a hobart tech and repair these units alot,let me know.
Sep 03, 2008 | Dishwashers
Dishwashers Logo
Top Dishwashers Experts
