Question about Whirlpool Washing Machines
How do you run a diagnostic test on whirlpool wfw9600tw01
3 Suggested Answers
KevinWhite
  • 1902 Answers
SOURCE: F35 ERROR IN DIAGNOSTIC TEST C:00 I have been
Hello & Welcome to FixYa
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Posted on Oct 15, 2011
  • 842 Answers
SOURCE: Whirlpool Duet Model WFW9600TW01 has F35 code and not running. Manual does not reference this code.
You have a pressure sensor problem and will need to replace it. Pressure Sensor This will correct the problem you have with your unit. To access it, your will need to removed the 3 screws on the back of the unit to the top cover only, slide the cover back to the rear of the unit to remove. Locate the part and replace it, it should be mounted toward the front control but I have seen models where it was toward the back. It is on the top though and accessible.
Thanks and good luck Gere
Posted on Oct 22, 2011
How do I run diagnostic test
Washing Machine Diagnostic Test & Error Codes (Cabrio ...
? 1:29
https://www.youtube.com/watch?v=yoCTzbl4FPs
Nov 22, 2010 - Uploaded by applianceassistant
Washing Machine Diagnostic Test & Error Codes (Cabrio, Bravo, ..... What can i do? ... I tried to put it in ...
Fix and Diagnose Kenmore Oasis / Whirlpool Duet hE Washer
? 7:21
https://www.youtube.com/watch?v=8Z1JdsJYa14
Apr 24, 2011 - Uploaded by Alprazolam
Tried to do the diagnostic test and it still won't do anything. ... If the latter, and it won't run any diagnostics ...
How do you do a diagnostic test for a Whirlpool Cab
Dec 02, 2015 | Washing Machines
Whirlpool Cabrio top load washer bleach and detergent will overflow.
Change the bleach dispenser.
Also make sure the tubes are not slightly clogged from residue build up of mildew.
Dec 01, 2014 | Whirlpool Washing Machines
Oct 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F35 ERROR IN DIAGNOSTIC TEST C:00 I have been getting the same F35/Suds error as previous posters. When I enter the diagnostic test only, I can successfully get through all diagnostics. The first time. ...
Kevin
Oct 15, 2011 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
I have a Whirlpool model WFW9600TW01 front loading duet steam automatic washer. I am getting error F35 both when I try to run a load and when I run the diagnostic program. I have cleaned all the hoses,...
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 02, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have a whirlpool WFW9600TW01 front load washer. It is giving F35 and SUD error codes. I have cleaned the drain pump and lines, cleaned the dispenser, flow regulator and hoses, took out and cleaned the...
Hi dear.I may have solution for the SUD error.You can give it a go.But I do not know any thing about F35 one
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If “Sud” is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Potential Causes
• If too much detergent was used, run the unit through a Rinse/ Spin cycle then a
Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
• Check the drain hose and make sure it is not plugged or kinked
• Check Wire Harness connections to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
• Check / Clean Drain Pump Filter of foreign objects
• Check Drain Pump
• Check the Pressure Switch
• Check CCU
Replace failed component.
As it says run couple of rine cycles it should get back to normal.I hope that helps you.Thanks.
Aug 29, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Whirlpool Duet -Sud displays and washer stops
I;ve had the same problem (SUD on first fill) and found this most helpful for my WFW9600TW01 Duet washer
http://www.tellingmachine.com/post/Fixing-Sud-and-F35-errors-on-my-Whirlpool-WFW9600TW01-Washer.aspx
I duplicated his actions and it cleared up my SUD/F35 error. I think running the diagnostic test multiple times flushes the sensors/sensing lines to eliminate the problem.
Jan 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have an ''F 35'' error code on a Whirlpool Duet Washer Model # WFW9600TW01
An F 35 error in fact means any number of things, from the drain hose being pushed too deeply into the standpipe to using the wrong soap or too much soap and the computer triggering an over-suds condition. Your best bet is to contact Whirlpool.
Dec 14, 2009 | Washing Machines
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
