Question about Fisher Paykel Fisher & Paykel DishDrawer Series DD24DCW6 Semi-Integrated Double D
Remove drawer from fisher-paykel dishwasher - Fisher Paykel Fisher & Paykel DishDrawer Series DD24DCW6 Semi-Integrated Double D
  • 21 Answers
Open the drawer.
Top tub : depress the right hand tub clip and push it back about 30mm. Repeat for the left hand side.
Bottom tub:
remove the toe kick (refer section 9.4) and lower tub cowling (refer section 9.5), both optional.
1. If the cowling has not been removed, then the tub clips need to be pushed back about 130mm so the slide clears the cowling when the tub is lifted.
2. Lift the tub off the slides and push the runners back into the product.
3. Releasing the wire from the centre clip on the link assembly allows the tub to be moved further from the chassis (optional).
4. If the tub is being turned over for servicing, rotate it counter clockwise, remembering to remove the baskets first. Removing the handle will prevent it from being damaged.
5. Refit in reverse manner.
Posted on Nov 19, 2014
Why won't drawer of fisher paykel dish washer roll
Have you removed the drawer?
Checked the rollers?
Reinserted the drawer correctly?
Jul 13, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & Paykel dishwasher top drawer is filling up with water when bottom drawer is ran.
It is the drain water from bottom drawer that is finding its way to the top drawer. This could be due to incorrect drain hose height. Check in installation manual. Alternatively you will have to buy an air gap kit and connect the two drain hoses separately to the kitchen sink.
http://www.genuineapplianceparts.net/ecart/item.php?item_id=250&category_id=58
Mar 22, 2014 | Fisher and Paykel Dishwashers
I have a Fisher Paykel dishwasher with water in top drawer
You need a Air gap kit designed by Fisher and Paykel to address this problem. It is pricey but it is worthy. I used this and very happy with it since no back flow problem from one while other running. Here is a link to order it.http://www.fisherpaykelparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/
Dec 12, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher paykel dishwasher DD603 drawer is open but locked
i think you have to press the key/ lock button until the symbol disappears. You will find the exact button for your model in your owners manual.
Nov 25, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Hi Both drawers show error F1 flashing beeping with rinse light on and both pumps run after power is applied to machine
F1 error indicates flood switch in base has activated, meaning machine has leaked. This causes machine to drain continously, and can only be stopped by switching off power. Not easy to fix if you don't have experience- bottom drawer has to be removed to access flood switch, then machine needs to be test run and checked for leaks. Best to call the professionals!!
Oct 03, 2009 | Fisher and Paykel 23 in. DD603H SS...
The top drawer of my Fisher Paykel two drawer dishwasher will not close all the way. Something appears to be stopping it. How do I fix it?
To find out what might be blocking it, you can remove the drawer. There are two tabs one on each side of the drawer near the bottom front. Push those in and pull the drawer out. You can lift the drawer up and push the slides in to get them out of the way. Then you should be able to see into the cabinet and what if anything is stuck behind the drawer
Apr 22, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher paykel dishwasher not draining well
Check the drain hoses by removing the dishdrawers from the machine and pulling on the hoses. I installed a Fisher Paykel DD602 about a month ago and the bottom drawer was not draining. I removed the drawer and freed up the drain hose and the machine worked fine.
Comment posted on Feb 07, 2009 there should be tabs on the sides of the drawers at the sliders near the front of the machine.
Feb 01, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dish drawer by fisher and paykel DD603 FPZW
flooded unit please remove drawer abnd dry board also read some of my other post on this problem
Jul 19, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher Paykel Fisher & Paykel DishDrawer Series DD24DCW6 Semi-Integrated Double D Logo
63 people viewed this question
Top Fisher Paykel Dishwashers Experts
Owen Barnes
Are you a Fisher Paykel Dishwasher Expert? Answer questions, earn points and help others
