Question about Goulds Pumps HydroPro Water System Diaphragm Pressure Tank 19.9 Gallon
How to prime a hydro pro bladder water pump
My system ran out of water ...now that I have water, how do I get teh water pump properly started
We have a well. Hooked to a 36 gallon bladder tank. Lots of air coming thru the water line. Your thoughts? We were told we needed a tank without a bladder. Your thoughts?
The bladder is there to prevent the water from coming into contact with the metal tank. This is important when your drinking water is coming through that tank. If the tank is just being used for irrigation the bladder is not really necessary. You also have air between the bladder and tank so create pressure on the water and prevent short cycling of pump motor.
If air is coming up then there has to be some sort of leak on the piping or fitting on the suction side of your well pump. This can cause you to also lose your prime. Check the Check valve (prevents water from suction line going back into ground) for leaks around the fitting.
Aug 25, 2017 | Plumbing
Kenmore HE2 flashing lights
did the technician point out wat needs to be repaired
Aug 24, 2008 | Kenmore 46462 Front Load Washer
Machine w/not squirt
have you check the spray nozzle or spray line for s clog? only other thing you didn't list? let me know?
Aug 23, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
I am installing a new water pump for a 1999 Honda Accord and in the cooling system there is a lot of fluid like slim and rust I have ran water through the system letting it run through the water pump
did you open the rad drain and flush that way or take the hose off the bottom of the rad. sounds like you may have more than just water pump issues could be head gasket, take off oil filler cap there is white milky slime it could be head gasket make sure you locate the leak or it will all be coming apart again anyway. make sure the timing marks are correct when you put it back together
Jan 19, 2015 | 1999 Honda Accord
Bissell pro heat wont spray water
Hi, it's Allie from Crucial Vacuum!
Your Bissell ProHeat 25A3 may have stopped spraying water for several reasons. Make sure the bladder or water tank of your unit is filled with water properly and that the 2-in-1 tank has been placed properly.
If the water tank/bladder is filled and the 2-in-1 tank is placed properly, your unit's pump may have lost prime, to check this turn your unit's power off and hold spray trigger for 30 seconds. Turn the machine back on and check the spray flow.
Another thing that may not be allowing your unit to spray properly or spray at all is having a clogged solution filter and may need to be cleaned.
Last, your unit's pump belt may be broken. To replace, turn off your unit and unplug from any electrical outlet. Use a flat head screwdriver into the slot of the belt access door to release where you should have access to your unit's pump belt.
You can purchase direct your replacement belts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/bissell-proheat-2x-belts-2pk.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Oct 05, 2014 | Bissell Pro Heat Deep Cleaner Model 25A3,...
My washer doesn't pump out all the water after clean cycle
Remove all the trays and sprayers and such, and check the place where the water drains. See if anything is there, slowing down the drain function.
Nov 26, 2013 | Frigidaire Dishwashers
Sta Rite Pool Pump
Probably need new pump if the impeller broke.
If impeller broke, then motor will run, but no water circulates
Call pool company.
Motor resources:
http://waterheatertimer.org/Color-codewire.html#motor
Apr 18, 2013 | Sta Rite Pool & Spa
Pump comes on shuts off then comes on shuts off
In other words, it is cycling quickly. Check your bladder tank for proper air pressure. You will have to shut the pump down and drain the tank to do this as the pressure in the bladder is set when the tank is empty, or nearly so, no pressure on it. Set air for a couple of lbs below the normal on point of the pressure switch. If you don't know what it is supposed to be, start at 28PSI, after pump is working, check system pressure while it is under load, meaning turn on the water and let it run and watch pressure gauge for when pump comes on. If no pressure gauge, install one as you need it to see if you system is working properly. It it isn't a bladder tank, just an older style tank, same thing, same procedure.
Sep 13, 2012 | Goulds Pumps J and JS Series Pump nozzle...
We have a Krystal Clear Saltwater System Model CS8110. We are first time pool buyers. We set up the pool last week and despite several "boosts" the chlorine level is very low. The pool store...
You should always follow the instructions on the manual .. I have a 18X33X4 oval and had to start with over 350 lbs of salt and ran the pump without the chlorinator for 24 hours to properly disolve the salt. Then, I started with 12 hrs pump cycle with 10 hrs of chlorination in between the 12 hrs. Keep checking the chlorine level and adjust time from there. Currently at temperatures of 85 to 100, I run the system at 10 hrs pump with 8 hrs chrlorinator and water is Crystal Clear... In the 2 years with the intex system, I have not added any chemicals to my pool. I once had an issue when the water level went low while I was on vacation, when I came back, the chrolinator had turned off due to low flow and my pool water was green.. As soon as I re-started the cycle, a few days later, Crystal Clear again... NO CHEMICALS OR SHOCK added.... Hope this helps....
Jul 15, 2011 | Intex Automatic Salt Water System for ...
I have changed the temp.senor,radiator and the thermostat my car keeps running hot why?
Some times the impellers in the water pump wear down and dont flow enough water to cool things properly.
You may want to make sure you have the air bleed out of the system.
The belt may not have enough tension to properly drive the water pump.
Is your cooling fan working properly?
These are some random things that I have ran into over the years I hope they help you some
Oct 14, 2010 | 2000 Oldsmobile Intrigue
Goulds Pumps HydroPro Water System Diaphragm Pressure Tank 19.9 Gallon Logo
Top Goulds Pumps Plumbing Experts
Steve
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Goulds Pumps Plumbing Expert? Answer questions, earn points and help others
