Question about Landmann 12376 Gas Grill
Assemble a landmann triton 12963 - Landmann 12376 Gas Grill
Landmann 12376 ignition
Firstly, check the distance between ignite and burner, the spark must contact with the hole of burner.
secondly, turn on the control at maximum level then keep and push control knob try to Push-button Piezo ignition several times.
Finally, If you do not find out any trouble with gas supply, connection and assembly, do the same with step 2 however, Instead of push the button use the paper or wood with flame on to ignite for side burner for the first times, after that keep it running for few minute to heat burner, then turn off then use Push-button Piezo ignition to ignite.
With my experience it can work 100% after you heat the burner, if not call me. ^^
Aug 14, 2012 | Landmann 12376 Gas Grill
Just built my grill chef 12736. Every thing is fine except it has come with two right hand doors. Do you know where I might get my hands on a left hand door?
That's got to be a bummer. Brand new grill get it assembled and find one wrong door. The best bet, is go back to or contact the retailer you purchased it from. Also, check the Owner's/Assembly Manual for a number to call if parts are missing. Most manufacturers provide this feature now. As a last resort, contact Landmann, the manufacturer http://www.landmann.de/LANDMANN_Holding/en/kontakt/
Hope this helped you. Good luck & Happy Grilling!!
Jun 27, 2011 | Landmann 12376 Gas Grill
Can you tell me how to put together the landmann 923738302 bbq please i have lost the instruction maual
As I know this model sell by Aldi store.
Sorry I can not find out english version for you.
Use Sweden for replace, the sharp is the same
http://www.landmann.se/files/man/se/12373.pdf
May 17, 2011 | Landmann Grilling
I need instructions to assemble landmann gas bbq 12736
For you ^^
http://www.landmann.co.uk/lanotattachments/download/file/id/4/store/1/12736_instruction_manual.pdf
Apr 17, 2011 | Landmann 12376 Gas Grill
Can you supply me with an instruction manaul for a Landmann 3 burner gas bbq with side burner (grill chef 12736 not sent with box
download in from landmann UK
Mar 27, 2011 | Landmann Grilling
I need assembly instructions
Download this file
difference name but the same design.
Mar 26, 2011 | Landmann 12376 Gas Grill
Landmann 12376 Gas Grill Logo
32 people viewed this question
Top Landmann Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Landmann Grilling Expert? Answer questions, earn points and help others
