Question about Sharp AR-M450N Copier
Where is the finisher lock located? - Sharp AR-M450N Copier
    New Friend:
  • 5 Answers
The finisher lock is the screws, the top one it looks like is just a bracket but pulls out towards you, and unlocks it. then do the rests in the back and the 2 in the bottom of the unit ( pull the paper tray to see them). You should be able to remove the all unit by disconecting the plug in the back of the paper tray cabinet.
Posted on Jun 29, 2014
How do I stop my nokia 301 to stop automatically locking up when I have finished with it. Also is there a way to turn up the vibration mode, I can hardly feel it?
Go to setting and select phone settings then location and security, choose change screen lock and then disabled it.
Aug 18, 2013 | Cell Phones
Began to beep in intervals. Changed batteries and it worked a couple of times then beeped twice then touchpad will not work, Five minutes later it beeped steadily for 10 seconds than stopped. Will not...
Why is my Powerbolt 1000 unit beeping?
This is the relevant excerpt from the Powerbolt programming and troubleshooting instructions:
"To determine why your lock is beeping abnormally, please follow these steps:
Take out batteries and unplug powerstrip.
Let it sit for 1 minute, then put the batteries back in and wait another minute.
If it does not beep, the keypad needs to be replaced (17733-1).
If the unit continues to beep, the powerboard needs to be replaced (A17734-3,3 Powerboard 1470 brass finish; A17734-3,26D Powerboard 1470 satin chrome finish; A17734-3,5 Powerboard 1470 antique brass finish)."
Since you've already gone through the battery change, try the battery remove-reinstall recommended above. If that doesn't work for you it suggests that you need to replace the appropriate Powerboard for your lock.
So this is the link to Weiser Customer Support Page, where you will find the appropriate number of your location:
http://www.weiserlock.com/en/CustomerService/ProductSupport/SupportContact.aspx
I suggest calling the appropriate toll-free number and having a conversation with a representative about this problem. You will want confirm that you need the part before you go through the expense, and that it's worth it. You will need to know the "finish" of your lock. Try to talk them into warrantying the part, in spite of the age (one year warranty on electronics), as a matter of good customer relations. They will help you get the correct part on order.
Good luck--and please provide feedback if this helps!
Sep 22, 2011 | Weiser Lock Powerbolt 1000 Lock
How long should I expect my lock to last? It is app. 3 years old will only lock & unlock app. 3 or 4 times then dies when the batteries are replaced... The batteries still have a full charge.when...
Aug 15, 2011 | Weiser Lock Powerbolt 1000 Lock
Code dr oven door won't open sounds like it keep turning
You probably need a door lock mechanism. If you remove the rear panel and locate the lock mechanism (about middle of back) and HELP the gear turn a little it may finish it's unlock cycle. If not just keep turning the gear till the door unlocks.
Oct 29, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
The memory card of my cell phone is automatically locked
The steps to unlock a password protected memory card of your mobile phone, is described below. Please follow the steps:
1. To unlock your mobile memory card, you need a file explorer. You may use FExplorer. To download FExplorer, http://fexplorer.en.softonic.com/symbian/download#pathbar
2. After finished downloading, install it to your mobile phone.
3. Insert the mobile memory card into your mobile phone. Remember, don't access the memory card through phone at this moment.
4. Run FExplorer and open the following location C:\system.
5. From the location C:\System, you will see a file named as mmcstore. Rename this file as mmcstore.txt.
6. Copy the file mmcstore.txt. and paste it to your computer. Now, open that file in notepad.
7. When you finished the above steps, you will find the password of that file
Rate me if this is helpful. Good Luck :)
May 30, 2010 | Nokia 6500 Slide Cellular Phone
My friend had locked the memory card accidently by using un known software how to open locked memory card
hello, you can try the FExplorer to recover the password: 1. First download the FExplorer from (http://fexplorer.en.softonic.com/download/25347).
2.After finished downloading, install it to your mobile phone.
3.Insert the mobile memory card into your mobile phone. Remember, don't access the memory card through phone at this moment.
4.Run FExplorer and open the following location C:\system.
5.From the location C:\System, you will see a file named as mmcstore. Rename this file as mmcstore.txt.
6.Copy the file mmcstore.txt. and paste it to your computer. Now, open that file in notepad.
7.When you finished the above steps, you will find the password of that file.
Apr 15, 2010 | SanDisk 2GB microSD Memory Card
Indesit wd 125. Wash cycle had finished, door lock was off but
Unplug machine, take lid off and locate the door lock. You will have to use a small screwdriver or something to release the lock. Then replace your door handle.
Jan 19, 2010 | Washing Machines
How to reset kwikset pwerbolt 1000
6. Resetting the code: - please follow these instructions to reset the code on your Powerbolt 1000 unit:
  • Remove the inner cover plate from the lock.
  • Locate the small round program button near the left side of the circuit board (Red or Black).
  • To program, the latch should be extended out in the lock position, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. Re-enter the same 4-8 digit code to confirm, the latch should retract. This completes the programming. This signals that your code has been accepted.
  • To enter a second code, follow the same procedures as in step 3, but this time press the reset button twice then enter your code.
7. Replacing the batteries: - please follow these instructions to replace the batteries on your Powerbolt 1000 unit:
  • Remove inner cover plate located above the thumb turn on the inside of the door
  • Replace all 4 batteries with quality alkaline AA batteries. (Do not use rechargeable batteries.)
  • Ensure that the batteries are correctly oriented or unit will not function properly.
8. Changing the password code: - please follow these instructions:
  • Manually put the bolt in extended (lock) position. Press PROGRAM button once, enter new 4 - 8 digit code and then press LOCK.
  • Press PROGRAM button twice, enter the same new code and then press LOCK once.
  • Press PROGRAM button three times, enter the same new code and then press LOCK once.
    These stept will program only the new code you enter for your unit.
9. Why is my Powerbolt 1000 unit beeping? - To determine why your lock is beeping, please follow these steps:
  • Take out batteries and unplug powerstrip.
  • Let is sit for 1 minute then put the batteries back in and wait another minute.
  • If it does not beep, the keypad needs to be replaced (17733-1).
  • If the unit beeps, the powerboard needs to be replaced (A17734-4,3 Powerboard 1460 brass finish; A17734-4,26D Powerboard 1460 satin chrome finish; A17734-4,5 Powerboard 1460 antique brass finish; A17734-4,11P Powerboard 1460 bronze finish).
Nov 02, 2008 | Kwikset Powerbolt/Electronic Deadbolt-...
Misfeed in finisher
finisher is the unit attached to the copier on the left.
open door and look for any green handle, these are what you need to move to locate the jams
Oct 19, 2008 | Toshiba E-Studio 3511 Color Copier
Sharp AR-M450N Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
