Question about Amana AGDS902 Gas Kitchen Range
Hi, my Amana AGDS902 gas downdraft oven will only get warm. the tempeture setting never climbs above the 100 degree start reading. The clean mode also only just gets warm. Everything else about the range works great.
5 Suggested Answers
crayzeetrayn
  • 837 Answers
SOURCE: temp stuck on 100 degrees
try unplugging the range for at least 30 minutes
Posted on Feb 08, 2009
SOURCE: amana ACS3350AS stove temp in oven stays at 100
We had the same problem and it turned out to be a burned out lower heating element. Only the top one was heating and I could never get it over about 150deg or so.
Posted on Mar 24, 2009
  • 80 Answers
SOURCE: Hello. Regarding my Amana range (MODEL: AGDS902),
You will have to replace the bottom element.
John
Posted on Oct 03, 2009
SOURCE: i have an Amana acf3325a gas range. the oven will
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. Should be 3 - 3.6A. If less than 3A - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace. Part number is 74008064.
Keep in mind, ignitors are fragile.
Posted on Jul 15, 2010
I am attempting to pre-heat oven to 400 degrees but oven heat will not raise above 100 degrees
Hi, Upon reading your post I immediately thought of a bad ignitor for the oven, but I am not sure whether you have a gas oven or a conventional electric range. So...If it is gas, I'd suggest replacing the ignitor for the hot surface ignition. If it's electric the bake element may be at fault although most range's use the broil in the preheat, so it should still climb up to 400, it would just take a really long time. Maybe you can clarify if it's electric or gas and I can try to move you forward from there. Macmarkus :)
Dec 09, 2009 | GE Ovens
How do I clean my amana gas self cleaning oven
I have an Amana self-cleaning oven, Model AGR5715QDQ. I can't find my manual - how do I start the process of cleaning? Elizabeth
Nov 22, 2009 | Amana AGDS902 Gas Kitchen Range
The stove is locked, how do I unlock it so I cn open the oven door?
You might have the oven scheduled for cleaning. If so, clear that. You also might have a child safety lock that was put on by accident. If you can not find a clear button, try to reset the oven cleaner for a minute or two and have it shut off. If none of the above works, go to your breaker box and shut the power off. It should reset the electronics. I hope this works, I see a lot of complaints about Vikings not opening after cleaning.
Nov 15, 2009 | Amana AGDS902 Gas Kitchen Range
John
Oct 03, 2009 | Amana AGDS902 Gas Kitchen Range
The oven light will not go off when the door is closed on my Amana AGDS902. any recommendations?
Check to make sure there is no switch to manually turn on the oven light. Most have a switch now to turn them on without opening the door so you can check the food without letting out the heat. Hope this helps.
Sep 12, 2009 | Amana AGDS902 Gas Kitchen Range
Amana ACS3350AS stove temp in oven stays at 100 degrees . takes 1/2 hour to light or get to set tempeture. replace senor temperature and control panel. what should i do now
Mar 16, 2009 | Amana ACS3350AS Gas Kitchen Range
Temp stuck on 100 degrees
Feb 08, 2009 | Amana ACF3355AS Gas Kitchen Range
Amana gas range will not heat up in bake mode
it turned out to be the igniter...a friend tested it and found it to be bad.....
Nov 16, 2008 | Amana AGDS902 Gas Kitchen Range
Amana AGDS902 Gas Kitchen Range Logo
43 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
