Question about Garden
Gardenplus LawGarden Sprayer won't shut off
Have a Gardenplus Sprayer about three year old. Worked fine when I cleaned it put up last fall. Now when I pressure up It won't stop spraying. Mdel 229295, 2galon.
SOURCE: sprayer wont spray or hold pressure
We use the both the 425 and 475 solo sprayers most days at work and when they start to lose pressure ( after 6 months of daily professional use) we purchase a complete seal kit and put it through them. The only part I can't work out how to remove is the inside cylinder, other than that everything else is easily removed and replaced.
Posted on Mar 27, 2009
  • 31 Answers
SOURCE: pressure no spray on 1 gal tank
try removing the tip and cleaning it. there maybe something stuck in it even if its new. if that dont work i would take it back to where i bought it. hope that helps
Posted on May 16, 2009
SOURCE: I have a fimco pump on a 25 gallon sprayer. It is
at the end of the pump little square box with one pillpes head ,take it off and there is another screw in there turn it until it works,
Posted on Jun 09, 2009
  • 6 Answers
open up the pump, take out the check valve. wash in dish soap/hot water solution, scrub with old toothbrush, rinse off, reinstall & see if that makes a difference...
Posted on Jul 24, 2009
  • 203 Answers
SOURCE: not much pressure on fimco 15 gallon sprayer -
Is it possible that the pick-up tube inside the sprayer is clogged up, or the hose it damaged? Maybe dirt in the spray handle/wand?
Posted on Oct 26, 2009
Air pump not working and red light stays on reset. Is the pump bad or electrical problem?
It is a toy spa after all, not really meant to last long.
According to Intex, your fault code is due to low or no water flow. Most common problem that we see is bad filter. You either need to clean, soak, or just replace them! Because they are so small, I wouldn't even bother with cleaning them, just have a few handy, and just install new ones.
Apr 12, 2015 | Pool & Spa
Where is the fuse in the danby model DAC10010E window air conditioner
more than likely there is no fuse mabey a loose wire or bad switch. I would pull the guts out of the case and check the wiring also a good time to clean the inside of the coil and other hard to reach parts
Nov 21, 2017 | Danby Heating & Cooling
My ford freestyle won't start, but the battery seems to be fine, suggestions?
I would suggest recharging the battery, or just get a new one. It's 7 years old and probably worn out.
Jan 18, 2012 | 2005 Ford Freestyle
Lenovo battery won't charge
Battery not charging usually means its dying! If your battery under one year old, you can get replacement from Lenovo. If its older than three year old, its time to find a new battery!
Is the battery not holding the charge at all? that means is the computer shutting off as soon as taken from power outlet or battery lasting less than expected...
Sep 27, 2011 | Computers & Internet
I have a YTH2454 three years old runs fine for about an hour then shuts off won`t restart until completey cooled down,i have used my leaf blower to clean engine , just today i put new air filter and screen...
the coil that attaches to the spark plug wire may need a replacement for usually when they get old the heat will make them weak after the engine is running causing a problem such as yours here
Jul 04, 2011 | Husqvarna 24HP 54" Yard Tractor ()
I have a 15 gallon Fimco trailer sprayer. Last
Bleach gives off corrosive vapors, so the internal parts of the pump may have corroded over time. Least expensive fix is to disassemble the pump, find and replace any corroded parts, but you'll be tinkering for a day and it may not be repairable anyway. More expensive but faster is to replace the pump - check the GPM rating and find it here for about $60 - $100. Good luck!
Jul 05, 2010 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
It takes my whirlpool dryer three or four cycles to dry clothes
Kenmore Dryers are almost all the same therefore am sending this;
http://www.youtube.com/watch?v=lHkIK8oy1K4
How to Clean a Dryer Vent Video
http://www.youtube.com/watch?v=5Dj4im31lRY&feature=related
Why is so inportant to clean the lint?
http://www.youtube.com/watch?v=9kxbF31Oh4s&NR=1
It was helpful?
May 15, 2009 | Whirlpool Dryers
I have a fimco pump on a 25 gallon sprayer. It is a 2.1 gallon per min. pump. I took it out yesterday to use and it would not pump up, no pressure. Worked fine last year. I checked and the motor is...
Apr 29, 2009 | Fimco Spot Sprayer, 25 Gallon, 3.8 GPM, 45...
Garden Logo
112 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
