Question about Spellbinders Edgeabilities Collection - Die Cutting and Embossing Templates - Classic Petal
Classic petal edger cuts through card as a single die dosen't look same as on packet
Edger of Classic petal die dosen't look same as on packet and cuts completely out of card so can't use it as a card edge unless I stick down with glue which seeps through the pattern.
Troy Bilt edger dies as soon as its under a load--like edging my driveway.
The only real explanation for this is that a tiny piece of dirt has gotten into one of the tiny fuel jets. Remove the carb and blow it out thoroughly with compressed air.
Nov 23, 2011 | Mtd Garden
The edger is not cutting very well. Any tips to make it work better?
You said cutting, not running, so I suggest removing the blade and sharpening on a grinder or buying a replacement blade.
I hope you find this very helpful.
Aug 21, 2011 | Black & Decker Le750 Lawn Edger
Toro Gas edger.
the srew on the carburator that adjust the air fuel mixture needs to be turned out 1/2 turn or the choke is on.
Jul 19, 2010 | Poulan Pe550 Gas Edger
Master cut edger 2.0 manuals wont start
Not positive but it sounds like it ran out of gas. Maybee a leak in one of the hoses? Or a piece of trash worked its way into the needlevalve or internal screen
May 11, 2010 | Garden
Engine starts and dies immediately what could be wrong?
The carburator may be dirty or the fuel filter might be clogged. I would take it off and clean it with some carb cleaner and see if that fixes your problem. It might be benificial to run fuel stabilizer after you clean it.
Apr 21, 2010 | Craftsman Gas Mini - Tiller/Edger
Black and decker 1.25 hp edger won't start
If it's electric, you probably cut the wire internally by kinking it or stretching the iwre beyond it'd capability.
Aug 21, 2009 | Garden
I bought a Sears edger #536 796526. It dies on me.
Hi Tom. You are not doing anything wrong. That being said, your edger has a slightly gummed up carbeurator. I would go to an auto parts store and get a can of a product called seafoam. this is a gasoline additive. Add one ounce per gallon of gas and use this as the fuel for your edger. You will solve your problem in just a few minutes after using this product, I believe. Give it a try and let me know.
Jun 13, 2009 | Craftsman Gas Mini - Tiller/Edger
Black & Decker Electric Edger (Corded) Died
It is just a matter of "process of elimination". Disassemble and continuity test each circuit until you find none.
Oct 05, 2008 | Garden
Poulan pe550 edger problem
Did you adjust the carburetur screws?
Sep 12, 2008 | Poulan Pe550 Gas Edger
Spellbinders Edgeabilities Collection - Die Cutting and Embossing Templates - Classic Petal Logo
Top Spellbinders Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Spellbinders Craft and Hobby Expert? Answer questions, earn points and help others
