Question about Dryers
Kenmore dryer hums but will not start
When I push start buttom, humming noise is heard. The dryer will start after holding button for a couple seconds but how long before it wont start at all? Please advise! Thanks.
  • 1 more comment
  • Anonymous Mar 27, 2014
    push start button in dryer only makes a humming noise when button is pushed in won't start
  • Anonymous Mar 28, 2014
    the dryer is a kenmore model 41788042700
  • Anonymous Mar 30, 2014
    dryer hums when start button pushed, belt is ok
  • 248 Answers
If it just hums the motor is probably on it's way out. If it makes a growling noise, it's the motor.
Posted on Nov 04, 2007
Kenmore 70 series electic dryer wont start make humming noise
your motor likely has a start-up capacitor to start the motor, it will be a cylindrical unit with 2 wires going to it, bring this with you to your local appliance repair depot and ask for a replacement with the same numbers on it, re-install as the old unit was uninstalled, this will likely the problem
Apr 15, 2012 | Kenmore Dryers
Amana Dryer LEA30AW
usually the humming sound is coming from the motor,try this,open the door,turn the drum with one hand and hold the door switch in with your other hand and have someone else push the start button at the same time,this might help the motor turn on but if it does you need a new motor,if you can't turn the drum you could have something stuck in the blower wheel or something jammed in the motor like a broken belt but like i said a humming sound is usually the motor.
Feb 22, 2012 | Amana Dryers
Kenmore dryer model 86950100, when I push the start button it just hums and will not start.First time it did it I waited 1/2 hour then it ran fine for couple days and now it started again, just hums. I...
the humming is coming from the motor,if you can spin the drum by hand and it moves freely you need to replace the motor,if it's hard to move you need to take the dryer apart to see why it's hanging up,the overload resets on the motor that's why after a while you'll hear the hum again,if you hold the button to long you'll pop the overload
Mar 26, 2010 | Kenmore Dryers
Kenmore dryer stopped running
Hi, I can determine a motor bad by the noise. Does it hum while holding the start button or is it a grinding deep sound? It can sound like the motor starts slow but once it gets going, it is ok. Sometimes the house lights will dim when the motor statrs going bad.
Let me know if I can help you further.
Jul 02, 2009 | Dryers
Start problem
Hi,If you hear the hum while you are pushing the start button and when you let off the button the hum stops, you have a notor going bad.
If you can get someone to help you, open the door, hold the door switch in, while someone else holds the start button, you try and turn the drum with your other hand. Sometimes the motor will start but, this only confirms the motor is bad and needs replaced. I hope this helps.
May 15, 2009 | Dryers
Our Kenmore clothes dryer is not starting.
its sounds like you have a broken belt or a bad door swith open the door rotate the drum manually if it feels verry easy to turn that means your belt is broken if not you can check the wires then replace the door switck thanks from gilles
Mar 15, 2009 | Kenmore 84052 Dryer
When you push start button, it makes noise but won't start.
This is a A.C. hum that you are hearing. this is a warning sign. You are experiencing motor failure. the actual windings inside of the motor are losing their potential to hold an even current due to breakage. the shutdown is a safety feature built in the control panel to prevent electrical spark/fire.
Feb 14, 2009 | Kenmore 659 Electric Dryer
Humming noise when i press the start putton
When I push the start button it would hum if I hold the button to long and then it would cut off.
Jan 27, 2009 | Whirlpool LER5636P Electric Dryer
if its a humming than a click,,wont start for a few mintues,,than the hum again ,,your motor is shot,,,replace,,onthejob
Jan 05, 2009 | Kenmore 62872 Electric Dryer
Kenmore 80 series - quit working - no noise when I press the start button
Check the door switch in the upper right of the door frame. Ours snapped off so the door wasn't contacting the switch anymore.
Oct 07, 2008 | Kenmore 63942 Dryer
Dryers Logo
649 people viewed this question
Top Dryers Experts
