Home | Sub-Zero | Bottom Freezer Refrigerator | I have a sub zero 611...
Sub-Zero Bottom Freezer Refrigerator
Problem for Sub-Zero Bottom Freezer Refrigerator
I have a sub zero 611 and water is accumulating
By mwalshe on Jun 23, 2009
I have a sub zero 611 and water is accumulating behind the vegetable drawer in the channel that is there.Where does it come from and how do I make it go away
Best Solution
posted on Jun 23, 2009
Very Helpful)
mgprice
Rank: Guru
Rating: 95%, 407 votes
sounds like you have a blocked drain tube....when defrost system kicks in the melted water runs down a tube into a tray adjacent to the compressor and is evaporated by the heat. when the tube becomes blocked the water has nowhere else to go except overflowing and out through the refridge vent down the back and onto the floor of the refridge.
If you are hand with tools i can explain a procedure to fix this problem, If not call a service guy :)
Was this helpful?
Yes
No
4 people thought this was helpful
Popular Solutions for Sub-Zero Bottom Freezer
Questions and Unsolved Problems for Sub-Zero Bottom Freezer
Do you recommend Sub-Zero Bottom Freezer Refrigerator?
Answer
Answer
i have a block of ice on back wall and ice maker is not working on Sub Zero
Answer
I have a sub zero 650 about 3 yrs old.The icemaker has stopped working for no apparent reason. I did... (More)
Answer
I need a new rubber gasket for the frezzer drawer on a 550. Where can I obtain one and how is it... (More)
Answer
freezer continues to make ice even after tray is full
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sub-Zero Bottom Freezer...:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 1494
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
