My wife was cleaning the oven and she said she shifted the baking element and there was a loud pop. Now the baking nor the broil elements are heating. Everything else is working fine. Should I replace the element?
SOURCE: GE Oven bake element not work
It sounds like a problem with the selector switch. You have to remove the back panel to get to the back of the switch in the head unit, and find what wire goes from there to the bake element. With a meter set on 240ACV, or whichever setting is on yours that's HIGHER than that i.e. 400ACV, with the red probe on the terminal and the black one going to ground, see if you are getting 210-240 through it. If so, then it's either a faulty neutral wire connection (the other wire coming out of the element) or the selector switch. Hope this helps.
SOURCE: Bake element does not heat
After removing the racks, rack rails and the back plate I removed the 2 screws the hold the bake element. Lifting the front of the bake element up and carefully pulling the element out and gently moving the element so the connector clear the hole I was able to disconnect the wire. After testing for continuity with an ohm meter (non found) I determined the element need to be replaced. $37 and 45 minutes total.
SOURCE: Whirlpool Accubake oven super capacity series 465
In an attempt to self clean my oven, I pushed the auto clean button and then pressed start. Instead, nothing happened, but now have a message on the panel reading E1on the left side of panel and -F5- on the right side of panel. I am unable to clear it or operate the oven now.
SOURCE: Oven does not work after running self cleaning
Dear Dupe,
please rate this solution if it mends up ur needs,else choose fixya,
please do the following checks,
please rate this solution if it mends up ur needs,else choose fixya.Thank you
SOURCE: Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
