Question about Maytag Dependable Clean Top Load Washer, MAV3955EWW
What year was the maytag stacked SE7800 washer/dryer made?
rickzilla
  • 706 Answers
SOURCE: Maytag haevy duty stack washer dryer unit model # SE1000 series 06
I hope you got this fixed by now but if not I'll put in my 2 cents.. I assume that your dryer is electric and not gas. Assuming that is true then you probably have an open heater element.. similar to this used in electric stoves... There may also be other components that could have failed and in so doing, disabled power to that element. Could be a contactor or temp switch/thermistor.. Hope this helps and that you've already solved the problem...
Posted on Jul 25, 2008
SOURCE: my Maytag Front load stack unit washer/dryer model # MLE2000AYW
I had a similar problem, My washer spun but the clothes were still soaked with water. We replaced the inertia switch. That solved it.
Posted on Dec 13, 2008
SOURCE: removal of front panel of a stack washer and dryer mod
Their are screws between the washer and dryer. Undo those and the screws inside the dryer, next too and below the lint trap.
Posted on Feb 07, 2009
  • 62 Answers
SOURCE: need manuel for maytag stacked washer/dryer unit model lsg7806aae
go to this link and download the manual:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=LSE7806A&siteCd=MT_EN_US
Posted on Sep 02, 2009
esaleh
SOURCE: Maytag Neptune stack washer/dryer model#MLE2000AZW.
This is what I did and it worked. Remove the fabric softner blue pouch from the washing machine. Pour a small quantity of draino in the fabric softner resevoir. Wait until the draino drains. Pour hot water in the resevoir area to ensure that the hot water flows freely. This should take care of the problem.
Posted on Oct 08, 2012
Put detergent
MLG2000A - Maytag Neptune Super Stack SL-3
1 - Select Wash/Rinse Water Temperature
2 - Select Options (Max Extract, Extra Rinse, Signa)
3 - Select Cycle
4 - Load the Clothes Washer (add detergent on top of the load in the tub, and additives [fabric softener, bleach] in their dispensers).
5 - Start the washer.
This is according to the owner's manual I have. Has worked for 14 years for me.
Jan 14, 2014 | Maytag Neptune MLG2000A Front Load Stacked...
Top Load Stacked Washer / Dryer Maytag lse7806ace -- washer will not run, except in spin cycle
I believe there is a fuse on the left side front under the front panel about a foot from the top of the washer.
Nov 20, 2010 | Maytag LSE7806A Top Load Stacked...
The tub is leaking in the botto center
had the same problem...the washers that hold the water in need to be replaced...only $20 for parts, but labor is $700 to take entire thing apart and is not covered after 1 year [I've had 9 yrs]; I opted to trash / replace entire stack unit; buy new amana washer & dryers @ home depot b4 7/29/09 / big sale!
Jul 14, 2009 | Maytag LSE7806A Top Load Stacked...
20 year old maytag stack, washer doesn't stop agitating
Your control board is bad. It must be replaced. It can not be repaired.
Mar 21, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag s1000 stacked washer will not start water fill and cycles.
could be wash spin relay stuck in spin must be 15 years old
Feb 19, 2009 | Maytag LSE7806A Top Load Stacked...
Removal of front panel of a stack washer and dryer mod
Jan 17, 2009 | Maytag LSE7806A Top Load Stacked...
Dryer
Hi thanks for the question. the top of the dryer comes off. revealing the screws that hold the baffles in place . re- install the baffle, and the top. thanks the appliance doc.
Oct 06, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Maytag stacked washer/dryer
CHECK THE DOOR SWITCH TO SEE IF THE WIRE ARE CONNECT CORRECTLY. ON THE SWITCH THE WIRE FROM THE BULB SHOULD GO TO N/O IF ALL WIRES ARE CORRECT .THEN YOU NEED TO REPLACE THE DOOR SWITCH
Jan 03, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag Dependable Clean Top Load Washer, MAV3955EWW Logo
65 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
