Question about HP DeskJet 5550 InkJet Printer
"black print cartridge is not compatible"
Almost the same, except that I was using the cartridge that has been printing just fine for weeks and suddenly I started getting the message that "the black print cartridge is not compatible with this printer." I have pulled and replaced the black cartridge, the color cartridge (using old ones that worked previously), then re-inserted the current ones; turned the printer off and on; cleaned the cartridges (alcohol); all of the above in various combinations. I do NOT want to buy a new cartridge and try it because I think I would be throwing money away.Any help would be appreciated, as I am stumped.
    Guru:
  • 224 Answers
Ok the main mistake is cleaning the cartridge with alcohol because then the cartridge picks up dust and the dust sticks to it and then the printer will not work.
Now you can try cleaning the cartridges with a cotton swab dipped in water and see if that helps with anything you also gotta clean the contacts inside the printer where the cartridges are seated.
Make sure the printer is connected directly to the walljack without the surge protector and remove the cartridges,then power on the printer if you still face the issue, while the printer is on pull out the power cable from the back of the printer and the walljack wait for 30 seconds and then plug the cable to the wall and then to the printer and see if this resolves the issue,if you still get the error its a printer hardware problem.In that case also check the cartridge expiration date at the bottom of the cartridge if it shows out of warranty that could be another reason why you get this error message
Posted on Jun 23, 2009
I have a all in one color LC61 printer, do all colors have to be filled to print blk only?
Greyscale is color not black only.
You can print in black and it will look grayscale only darker, printers are a pain to work with after a year has gone by, I can expect almost a half hour to print something with my $400 epson because one of the colors is out even though I never printed in the last year a colored page. I take the color cartirges out and they are empty, but I only print a page 2-3 times a year. I use the scanner all the time. Brother and epson have their print heads in the printer not the cartridge so make sure your inks are always have something in it or it will be miricle for the printer to last more than a year. Check colors every other week. One Epson printer only lasted 3 months because I never used it(print head dried up). Never use the set up with tubes running outside printer to small tanks of ink if you only use it occationally.
May 11, 2014 | Unknown 10pk 4B,2C,2M,2Y Compatible LC61...
I have a new HP TriColor Cartridge and my printer will not print anything except black. Also have a flashingterdrop light on left side. What is the cure?
Hi. it actually sounds like something is not contacting with the cartridge. remove the cartridge and inspect the contacts inside the printer, the ones that touch the front of the colour cartridge, for dry ink, dirt or dust, use a cotton bud dipped in boiling hot water to remove any ink on the contacts, make sure the printer is off before doing this any make sure no water is left inside when you switch it back on.
I hope this helpsRegards
Grant
Nov 11, 2011 | HP DeskJet 6540 InkJet Printer
I have tried an ink cartridge that is not official Epson cartiridge - has worked fine for weeks now has decided that it has a error and it rejects this black cartridge. The other cartridges are Epson
Hi I had the same problem with a CX5400 printer scanner. My brother gave it to me because he'd put a compatible black cartridge in that was rejected. I tried compatible and genuine epson cartridges but no good. Still works as a scanner but wont print, not worth getting fixed.
Jul 27, 2011 | Epson Office Equipment & Supplies
Prints purple instead of black on photos only
My Canon printer has TWO slots for black ink cartridges. I assumed one was extra and didn't replace it when I ran out. Text printed just fine with only one installed, but my photos were printing with purple instead of black. I looked into it, and the two cartridges are different: one holds dye-based ink, the other has pigment based. Photos must require both kinds. If your printer is the same as mine, use both!
Jul 23, 2009 | Canon PIXMA MP600 all-In-One InkJet...
My Epson CX3810 is set to BLACK ONLY, but I have a prob w/colors
dear friend
this is fault of the technology of Epson CX3810
it uses little bi of color ink everytime it prints black even though you have chosen use only black cartridges
thanks
Apr 10, 2009 | Epson Stylus CX3810 All-In-One InkJet...
Won't print black at all
Sounds like the JEt for the Black might have clogged or the print head has malfunctioned.
Feb 11, 2009 | Epson C64 InkJet Printer
Dell 924 inject
Use only original cartridges and not generic/refilled ones. I think that is the source and answer to your problem ;)
May 15, 2008 | Dell 924 All-in-One InkJet Printer
Hp f380 with Visa OS not printing black
when ready to print go first to where it says PREFERENCES click there , and then slect BLACK CARTRIDGE ONLY ,just to be sure that is not the cartridge ,fun a print , see what happens. hope this helps
Apr 01, 2008 | HP DeskJet F380 All-In-One Printer
Will not print black
first of all the most important auestion is have you used compatible ink cartridges or genuine ones, because the print head clogs up with compatible ones, i really doubt that the cartridge you installed is damaged because i haven't come across this and i am a canon technician, i know this model well
Nov 02, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
HP DeskJet 5550 InkJet Printer Logo
398 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
