Question about Miller Electrical Supplies
Kubota f3060 How do you release the pto to allow removal of the front mower deck
  • 69 Answers
SOURCE: I can not get my mower deck to turn when I pull
Your switch could be bad, or the voltage needed to turn on the PTO may not be up to par, or you may have a safety switch that won't let you start the PTO. I'd start with the safety switches.
Posted on May 11, 2009
SOURCE: john deere 111 mower deck. Lift is in stuck in highest position
Looked up detailed isometric diagram w/ parts denoted on John Deere website. FixYa website was a litele misleading. I did not realize that accessing a question posted "for free" would cost me something to get the answer. It's kind of like askin a neighbor as a neighbor to give you a hand and then he sends a bill.
Thanks but no thanks
Posted on Jun 26, 2009
  • 12 Answers
SOURCE: Where can I get free download manual for a Kubota Mower ZD21?
http://www.mckeelequipment.com/kubota-mowers.htm
mickey813
  • 472 Answers
SOURCE: John Deere L120. Engine dies when PTO switch is pulled.
sounds like the seat switch is bad
Posted on Mar 02, 2010
huffman49
  • 235 Answers
SOURCE: Riding mower stalls when PTO is engaged.
check the kill switch and the wire it could be that a small piece of the covering came off and is grounding to the deck or frame there by killing the engine the jerkink of the mower maybe whats causing the wire to come into contact with metal..good luck
Posted on Apr 03, 2010
Kubota zd28 mower was running fine put away but now PTO wont engage.
if your saying that pto wont do anything , that's either an electrical short or a broken belt , in rare cases the clutches go too , now if your saying the pto engauges and stalls the engine or makes horrible noises , then that's a bearing , im betting the deck shaft bearings are in need of some serious grease work
Mar 04, 2017 | Kubota Garden
Need the front deck wheel and swivel for zd28 60 inch deck
Marvin, check the links below for Kubota deck parts.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Mower Parts Discount Online Parts Cheap affordable lawnmower parts
http://www.tractorjoe.com/kubota
kubotaParts Online
Kubota Tractor Corporation Parts
Apr 22, 2016 | Garden
Kubota F3680 stalls when PTO is engaged
there is not enof power so olter the tick over
Jun 28, 2015 | Kubota Garden
Change seal for PTO kubota f3680
Remove the PTO shaft extension from the shaft put a drain pan under to catch the oil Tap a chisel or other tapered tool in behind the seal flange and work the seal out install a new seal an re-install oil up to full level
Jun 13, 2015 | Kubota Garden
Pto onmy kubota zero trun zg 23 wont work
Check to make sure you are getting power on both sides of the switch. Check the connectors going to electromagnetic engagement PTO unit. This is mounted right on the base of engine. Check ground wire coming from unit to make sure you have agod grounfd connection.
Feb 27, 2014 | Kubota Garden
How do you put the drive belt for the hydrostatic drive on?
You'll be working underneath the mower, so it is helpful to raise the mower chassis up -- at least in back. Use your automobile jack, then put jackstands underneath the chassis to do this. Take off the deck drive belt first by releasing the idler spring(s). Unbolt and remove the "anchor" that keeps the PTO clutch from rotating. Disconnect the electrical wires leading to the PTO. Release the tension on the idler for the hydrostatic drive belt. Now you can thread the new hydrostatic belt over the engine pulley and around both wheel motor pulleys. The idler pulley presses it inward to provide tension. Refasten the idler spring - a pair of channellock pliers works well to hold and pull the spring. Now reinstall the wires and the PTO anchor, then the mower deck belt. Good luck! Please rate my answer if helpful, thanks!
Jul 02, 2010 | Craftsman 21 HP 42 in. Zero Turn Tractor...
What is the easiest way to remove the deck to change mower belt.
Your listing doesn't specify the model number of your tractor. But I found a users manual for a 24HP model 917.28936 here and perhaps this is yours, or similar.
This model uses a single mower drive belt (some tractors use two separate ones) and you do have to remove the mower deck to replace the belt. The procedure is in the manual. Hope that helps.
Jul 02, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
Broken belt
This is actually pretty simple:
Remove Pto guard on mower deck
Stand mower up on back stands
Pull the friction disc away from the drive disc
slip new belt in between the friction disc and drive disc pushing all the way through
release friction disc allowing to come back in contact with drive disc
loop belt around engine pulley
let mower back down
route belt around mower pulley
loosen guides on idler pulley
route belt through idler pulley
with engine off move pto lever to tighten mower belt
adjust guides on idler pulley allowing 1/8" from belt
tighten bolt on idler pulley
release pto tension
install mower pto guard
and you should be ready to mow
Aug 14, 2009 | Garden
Engine starts, but stalls when clutch is released.
The is a safety switch located underneath the mower, in the dashboard area. This switch will not pass voltage to the ignition system unless the pedal is depressed, or the deck is not all the way up. However, your culprit is most likely the pto (power take off) switch on the dash that engages the blades. It will not allow the mower to start, if pulled, and if faulty will shut off ignition power when you release the pedal. First. You'll need a volunteer to sit on the mower and operate the controls.  Now put the deck down and with the pedal depressed start the engine. Nothing should happen, if it does replace the deck switch Sears part number #176138 mentioned above. Now raise the deck and release the pedal. Again, nothing should happen. Same solution if it does. If nothing happens on both tests the switch is ok. NOW. Behind the dash, find the pto switch, and squeeze the sides, depressing two clips that hold it in the dash. You should now be able to slide it though the dash, wiring attached. Unplug the switch. With pedal depressed, deck up, someone sitting on the seat, start the mower. Now release the pedal (making sure to block the wheels and have the transmission handle is in the neutral position. If the engine continues to run, you found the problem. Replace the PTO switch. Sears part number # 174651. Also, check the plug to the pto, ignition and deck switches for corrosion as this is a common problem, though not likely to cause yours, it could. Good luck, and please let us know the outcome, good or bad. Thanks so much.
Nov 12, 2008 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Electrical Supplies Logo
29 people viewed this question
Top Miller Electrical Supplies Experts
littlewheel
Level 1 Expert
Lawrence Oravetz
jeff5may32
Are you a Miller Electrical Supply Expert? Answer questions, earn points and help others
