Question about Garden
Draper expert chainsaw carburetor adjustment tool
Looking for a tool to adjust the carburetor settings
rowdy45176
  • 2176 Answers
SOURCE: adjust carburetor gas and air intake on craftsman chainsaw
There is too much information to relay so I would suggest you go to Searspartsdirect.com and type in your saw number and on the right side there is an area for a manual. You will need to use your email addy and select a password for this but it is free. You can view or download the manual and the area you need is on page 15. Let me know if this won't work and I will copy and retype info requested.
Posted on Feb 18, 2009
  • 398 Answers
SOURCE: I need help with a carburetor adjustment on my chainsaw.
this site gives alot of helpful hintshttp://www.arboristsite.com/showthread.php?t=5208
Posted on Mar 02, 2009
  • 120 Answers
SOURCE: husqvarna chainsaw carburetor adjustment
Find the 2 screws. There will be a (h) high and (L) low. These are for hig rpms and low rpms. First tighten the screws. Then unscrew them about 1-1/4 turns. Then start the saw and let it warm up. Start with the high rpms first pull the trigger all the way then adjust the screw in 1/8 turns either way until it is running good at high rpms. Then work on the L rpms. Get the saw to idle then pull the trigger, there should not be any hesitation when going from L to H rpms. Just adjust the low same as the High. They have to work together so if the high is good and the low is not just right turn the h a small amount. If you have any more questions let me know
Posted on Jun 20, 2009
SOURCE: Husqvarna Model 141 Chainsaw Carb adjustment
The tool you need is available from Randy's Engine Repair, on his E-Bay store. The price is about $10., plus $3. shipping. Phone for Randy's is (937) 927-5665. It is usually busy.
Ebay item number is: 390025452838. Buy it online. I got mine about a week after I ordered it.
Posted on Sep 11, 2009
  • 4088 Answers
SOURCE: carburetor tool
Unless you are skilled enough to make your own, you are stuck taking the saw to a servicing dealer as they are the only ones allowed to possess the necessary 'D' head screwdriver. Give thanks to the EPA for mandating the prevention of mal-adjustment pollution.
Posted on Jul 07, 2010
Setting carburetor
David, may vary by make, model and engine size. I turn the L(low) and H (high) speed screws in till just seated(bottomed out) lightly, then I turn each screw out 1 complete revolution, start saw and tweek adjustments from there on the L and H. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Tune Chainsaw Carburetor
https://store.chainsawr.com/blogs/tuning-and-repairs/1126042-adjustment-and-tuning-of-a-chainsaw-carburetor
Adjusting chainsaw carb
Jul 03, 2016 | Garden
Set H&L jets oh a poulan p3314
I believe there is also a idle adjust.
adj. both L and H 1 1/2 turns approx from closed (bottom) for initial start up. check video links below, press the helpful button
http://www.poulan.com/ddoc/POUO/POUO2004_USen/POUO2004_USen__530165293-01.pdf
How To Easily Fix Chainsaw That Bogs Down By Adjusting The Carburetor
HOW TO ADJUST POULAN CHAINSAW CARBURETOR .
Jan 22, 2016 | Poulan Tools & Hardware - Others
How do I reset carb. screws to factory settings
Adjustment and Tuning of a Chainsaw Carburetor ' Chainsawr
store.chainsawr.com/.../tuning.../1126042-adjustment-and-tuning-of-a-c...
Carburetor Adjustment for Chainsaws Carburetor adjustment is critical on chain saws and other two-cycle engines. ... These saws have what is called a "fixed jet" which is set from the factory. ... (7) Go back to step (5) and reset the idle speed. ... NOTE: If you do not have a tachometer, set the RPM level so that the saw "four ...
How to Adjust the Air and Fuel on a Stihl Chainsaw ' Home ...
homeguides.sfgate.com > ... > Adjustable Mortgage Rates
Return a type A carburetor to its factory setting by turning the "H" screwcounterclockwise until it ... Where Do I Find the Carburetor on My Stihl 017 Chainsaw?
how to adjust carbs on 2 stroke weedeaters and chainsaws ...
Dec 25, 2015 | Garden
Could some help me with factory carb settings on this saw
Carburetor Adjustment for Chainsaws Carburetor adjustment is critical on chain saws ... These saws have what is called a "fixed jet" which is set from the factory.
Stihl Chainsaw Carburetor Adjustment - Tune-up Settings
tekindoor.com > MISC
Stihl chainsaw's have three carburetor adjustment screws (LA) Idle Speed screw - This ... When the engine is tested at the factory the carburetor is set to obtain a ...
The fuel/air mixture in any gasoline-powered engine is regulated by the carburetor, and the carburetor in a Stihl chainsaw is factory-adjusted to provide the best performance.... You'll find three adjustment screws for the carburetor, usually located under the air filter cover.
Factory carb setting on Craftsman 2.0 or Poulan Micro ' Firewood
Dec 04, 2015 | Garden
Need tool for adjusting air fuel ratio for husqvarna 235 chain saw
It should be a spline tool. It is the most common one.
Genuine Poulan Weedeater Part 530035560 Carb Adjusting Tool
If you work a lot 2 cycle trimmers and chainsaws you might buying the set of four adjustment tools.
2 Cycle Carburetor Adjustment Kit Includes 530035560
Nov 07, 2014 | Husqvarna Garden
Chainsaw stalls and won't restart
make sure you have the right spark plug and gap is right on for that model.
Apr 13, 2014 | Craftsman Garden
What is carburetor setting on a2.3 chainsaw
There is no fixed carburetor setting on these engines, just two screws to adjust low-end and high-end operation. Special tool may be required, there are about a half-dozen screw head standards. Check eBay for tool. Get the engine to run and idle fast (idle adjust) so it doesn't stall, adjust low-end screw so that engine doesn't hesitate or sputter when accelerated. Adjust high-end screw to run fast and smooth on full throtle. Readjust idle to normal.
Oct 28, 2013 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
I have a drapers adjustable spanner that is jammed
DW 40 penetration fluid might help to loosen it.
Aug 22, 2012 | Draper Hand Tools
Carburetor tool
Jul 07, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
What is the walbro chain saw carburetor adjustment for a
There is no set adjustment on any chain saw. If it were that simple there would be no need for adjustments. The problem is that most equipment manufactured in the past 10 years can not be adjusted by the user. Carburetors are now equipped with either adjustment limiters which limit the adjustment to less than half a turn or with adjustment screws that require a special tool to make the adjustment. More than likely you will have to take it to an authorized dealer for those adjustments.
If you do have an adjustable carburetor, then gently close both needles and open each on 1 full turn. This should allow the engine to start and the final adjustments can be made at that point. If it still will not start then open each needle 1/8 to 1/4 turn and try again. If this still does not work then most likely your carburetor needs a good cleaning and a rebuild kit.
Sep 13, 2009 | Poulan Garden
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
