Question about Breadman TR2200C Ultimate Bread Maker
Why machine will not knead ? - Breadman TR2200C Ultimate Bread Maker
How can I get the machine to start the bread making process from the beginning. It is currently stuck on knead.
Do you have your owners manual and have you baked bread in your machine before? Just want to be sure that you know the stages that the machine goes through. The first mixing and kneading stage in a tr444 will take up to 15 minutes before it stops on its own. It will then let the dough rest for about 1/2 hour before the 2nd knead begins. It takes almost 4 hours for your machine to go through all the stages before your baked bread is finished.
Jan 15, 2015 | Breadman TR444 Bread Maker
How long should bread knead in the machine
Depends on the texture you are looking for. Typically a machine has a pre-set program that kneads a certain time and shuts off. If you are using a recipe that is a bread that you make by hand, you could use the machine to knead the bread and rise the first time, then punch it down, knead by hand and form a loaf and bake in oven.
Oct 17, 2014 | Kitchen Appliances - Others
Everything seems to be normal but the machine wont knead the dough
If your machine making a sound as if the elecric motor is humming or is it completely quiet?
Mar 13, 2013 | Panasonic SD-YD250 Bread Maker
Can't get knead bar on West Bend automatic bread maker
Was the bar ever installed on your bread maker? Is this a replacement knead bar (paddle)?
Jan 01, 2013 | West Bend Bread Maker Machine Knead Bar...
The kneading mechanism just stopped kneading :( so sad! It's pretty old I guess. Do I have to bury it or is there a quick fix?
Be sure your machine is unplugged and take the panel off the bottom of the machine. Take a look in there and you will probably find that your drive belt has snapped or come off. If so contact breadmachineshelp.com for a replacement belt.
Jan 05, 2012 | Kitchen Appliances - Others
HI, I use the dough cycle and it takes 1 hour 20 minutes, but it actually only kneads the first 10 minutes and then here and there a minute for all together about 15 minutes of kneading. Is my machine not...
It sounds like everything is OK...machines knead a while,,,,rest a long time....knead a little rest along time etc......that resting allows the dough to rise....
Feb 27, 2011 | Breadman TR555LC Bread Maker
I put fruit in the fruit & nut dispenser & it did not come into the bread. What am I doing wrong?
Hi, sorry your dispenser appears not to be working. Unless and until you can repair it you can always add fruit and nuts the old fashioned way. Take a look at your manual and find the program you are using. Find how long the 2nd knead cycle lasts. For example lets say your 2nd knead last 20 minutes. Plan on opening the lid of your machine 10 minutes into the 2nd knead. All bread machines recommend add-ins well into the 2nd knead. Just have your ingredients premeasured on a paper plate next to the machine and fold the plate and pour them in halfway into the 2nd knead of the program you chose. At least that will help you get the bread you wanted.
Dec 30, 2010 | Breadman TR2200C Ultimate Bread Maker
How do you keep the kneading blade from being baked into the bread?
Hi, You can take the kneading blade out of the machine after the last kneading cycle and before the final rise. Take the pan out of the machine to do this just to be on the safe side, Hank
Dec 06, 2010 | Sunbeam 5891 Bread Maker
Broken kneading blade 6725
kneading blades get stuck in the dough and have a hard time removing the bread from machine when done
Mar 02, 2009 | Regal Ware K6725 Kitchen Pro Bread Maker
Breadman TR2200C Ultimate Bread Maker Logo
65 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Dave Kristol
Level 1 Expert
Irene Tulloch
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
