Question about Liquid Video L17LCD2 17" Flat Panel LCD Monitor
Blinking Blue Light.. >.>
I came home today from work, and found that's all my monitor is doing.
Whether my computer is on or off, as long as there's power hooked up
to my monitor, only that blue light will flash.
What can I do to fix this? will it be an expensive repair? Can I repair on my own?
  • 2 more comments
  • Philip G Nov 05, 2007
    That didn't solve the issue. That was one of the first things I tried. made sure all the cables were hooked up properly.
    That didn't solve the issue. That was one of the first things I tried (made sure all the cables were in tact). Any other ideas?
  • Anonymous Nov 13, 2007
    exactly the same
  • Anonymous Nov 21, 2007
    I have the same problem. Black screen with the blue light blinking. Tried changing cables and using monitor on a different computer, same problem.
    GL158@aol.com
My L17LCD2 just started to display "no signal". I have checked all connection, then tried replacing video cable did not help still same problem. I turn on the computer, then the monitor light is blue 2 seconds i see no signal & then the light turns amber. Now since changing the cable there is a beeping tone coming from the back of my computer, so i put the origanal cable back on still the beeping tone. any help would be apprieciated
Posted on Jul 04, 2011
  • 5 Answers
This is most likely a power supply problem. One or more of the electolytic capaictors in the low voltage section need to be replaced.
See the step by step diestions here:
http://www.wizardanswers.com/liquidvideorepair.html
Posted on Jan 14, 2008
  • 749 Answers
Check for loose connection of the video cable connection on the system unit (CPU). blinking may indicate that there is no signal transferred from the cpu to the monitor!
Posted on Nov 04, 2007
Samsung syncmaster 2220 blinking blue light and no image display
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 26, 2014 | Samsung SyncMaster 2220WM 22" LCD Monitor
I have a star logic monitor and it is not working. When i insert the power cord a dim blue light blinks, but then when i insert the computer to monitor cable, the dim blue blinking light goes away and it...
  1. Please try by reseating the RAM modules.
  2. Please check the VGA output port is properly fixed.
  3. Reset the BIOS to its default.
  4. Check whether the monitor colour resolution is out of range
If yes, set it to default.
Please check whether is works with different computer
IF yes, Check the VGA port.
Feb 07, 2011 | Star Logic Monitor
Hello there,\r\nMy samsung 940be flat screen is
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 09, 2010 | Samsung SyncMaster 940BE 19" LCD Monitor
My monitor will not go back on. There is a green light blinking
Hi ,
In order to isolate whether its the monitor or the compurter tower you can do a self test to check if the monitor is fine .Turn the computer off and then disconnect the cable for the monitor from the back panel of the computer tower.It will be a blue connector with screws on it .Undo the screws and then disconnect it then turn the computer on ,if the monitor is fine you should get a message that would say check input signal or you will have some kind of message on the screen that tells you that the data cable to the monitor is not connected.If u dont get any message that simply means that the monitor has gone bad and needs to be replaced...
hope this helps you .....all the best
May 12, 2010 | Acer AL1916W 19" LCD Monitor
I have owned a Samsung 932BW a couple of years. First symptom noticed was a blank screen and a blinking blue light around the on switch. From another desktop computer, I have swapped video cards,...
reynolds3d, Nothing new here. Happens a lot. 932BW will need to have some work done to the unit's SMPS probably. Read my fixya profile and make decision on what you will do based on info found there. 12fixlouie
Feb 20, 2010 | Samsung SyncMaster 932B LCD Monitor
What does a blinking blue power light when pluggined in mean on a kds 900w?
It may mean that it is in shutdown/restart mode due to bad caps in the power supply or it may be sensing overloading, you need to open it up and inspect the power supply first for caps with bulging top/seals, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can guide you further.
Feb 09, 2010 | Computers & Internet
Syncmaster paower button blinking and no display
CHECK THE REFRESH RATE ON TH OLD COMPUTER MONITOR AND MOVE IT TO A HIGHER REFRASH RATE IN THE CONTROL PANAL, MONITOR, PROPERTIES, ADVANCE SETTINGS
ROD
Feb 10, 2009 | Soyo DYLM1986 Monitor
Monitor : no display and blue led light is blinking
The power supply is the first thing that the 110v electric line goes into. The invertor is the next item past the power supply, or sometimes contained within it. I do not thing monitors are a DIY repair.      First substitute a different monitor to confirm that it is, in deed , the monitor and not the video card.
Jan 14, 2009 | Advueu Technology ADV178T 17" Flat Panel...
Liquid Video L17LCD2 17" Flat Panel LCD Monitor Logo
384 people viewed this question
Top Liquid Video Computers & Internet Experts
Rommel Balcita
Are you a Liquid Video Computer and Internet Expert? Answer questions, earn points and help others
