Question about Dell OptiPlex GX520n PC Desktop
I remove the battery during 15 minutes and nothing happen, i reset the jumper and nothing happen. the request for a password still there nay aother sugestions? i would greatly apreciate them.
  • edgar castellon
    edgar castellon Jun 23, 2009
    the pc still has the problem, i can't get to the system settings, so i can't work on it
  • 523 Answers
Well you are misunderstanding, taking the battery from desktop pc effects only the time of the computer and doesnot change anything, while moving the jumper from one side to other break the bios password. when you replace your jumper wait some seconeds and turn your computer on while the jumper is replaced, it will make some beeps or will ask to reset the password depends each model, then shut the computer off, put the jumper back in the right place and turn on the computer, then you will notice no more bios password. make sure you move the right jumper usually the on close to the battery and for more help google this problem it will show you the pics how to do it.
Regards
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Posted on Jun 23, 2009
Need to locate the jumpers on the motherboard of dell latitude d420 notebook to reset os password
I'm not sure the d420 has a jumper for BIOS reset on the motherboard. I think you will need to remove the small CMOS battery under the keyboard (for around 15 minutes) to reset the BIOS password and settings.
Jan 05, 2014 | Dell Latitude D420 (DELLD420) PC Notebook
Sirs I have not made any password for entering bios setup for compaq presario x1370 us, but when try to enter bios setup by pressing F10, display for administrtor password appears. What password could i...
But there is no need to worry. There are many known ways to reset / remove / bypass the password: Almost all motherboards use a small coin sized CMOS battery to store all BIOS settings along with the password. To reset the password, unplug the PC, open the cabinet and remove the CMOS battery for approx. 15-30 minutes and then put it back. It'll reset all BIOS settings as well as the password and you'll need to re-enter all settings. If it fails, then try to remove the battery for at least one hour. B. By Using the Motherboard Jumper: Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc. When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin. Make sure to turn the PC off before opening the cabinet and resetting the jumper.
Feb 25, 2011 | Compaq Presario X1370 Series Laptop...
I forgot my bios password, i want to reset my bios password
A. By Removing the CMOS Battery:
cmos_battery.jpg Almost all motherboards use a small coin sized CMOS battery to store all BIOS settings along with the password. To reset the password, unplug the PC, open the cabinet and remove the CMOS battery for approx. 15-30 minutes and then put it back. It'll reset all BIOS settings as well as the password and you'll need to re-enter all settings.
Jan 30, 2011 | Acer Aspire (AST180-US340B) PC Desktop
Need to change mouse settings on bios but i forgot my password
Jan 24, 2011 | ASUS M51Ta-X1 NoteBook
"Reset you're cmos/bios jumper to
HI,
No need to worry. There are many known ways to reset / remove / bypass the password:
  • By removing the CMOS battery
  • By using the motherboard jumper
  • By using MS DOS command
  • By using software
  • By using Backdoor BIOS password
Now I'll try to explain each method one by one:
C. By Using MS DOS Command:
This method works only if you have access to the system when its turned on because this method requires MS DOS. Open Command Prompt from Programs menu and provide following commands one bye one:
debug
o 70 2E
o 71 FF
quit
NOTE: The first character in the above commands is "O" and not the number 0.
After providing the above commands, restart your system and it should reset the CMOS Settings along with the BIOS password.
If you are curious to know how it works? then let me explain the above commands:
In this method we are using the Debug tool of MS DOS. The "O" character present at first in these commands, outputs the values to IO ports. The number 70 and 71 are port numbers which are used to access CMOS memory. By providing FF value we are telling CMOS that there is an invalid checksum and it resets the CMOS settings as well as BIOS password.
Jan 08, 2011 | Intel DG31PR Motherboard
Lenovo n500 forgot bios password
Hello, If you forgot your BIOS password,do not worry, you can reset your system back without requesting a BIOS password,Simply unscrew your laptop and get the motherboard of your laptop, locate the CMOS battery on the motherboard and remove for sometime for the battery to discharge say 4-10minutes,or better still if you can locate the jumpers for the BIOS and reset it,the BIOS password will be removed.It is the battery that keeps the BIOS chip alive by suppling it power,if power is not supplied to this chip,then the information on it will be lost. So, remove the battery for some minutes or reset your BIOS jumper on the motherboard WISH YOU THE BEST.
Nov 22, 2010 | Lenovo 3000 N500 Notebook
I need to reset the bios password on a toshiba l305-s5933
There are 2 ways you can reset your bios2_bing.gif.
1. On the motherboard there is a small watch battery. Remove this battery along with the power cable from the power supply. Hold down the power button to fully discharge the system. Wait 2-3 minutes then reinstall the battery and plug in2_bing.gif your system. Your reset is now complete
2. Some motherboards have a 3 pin jumper by the battery. Lets say that the jumper is on pins 2 and 3. Remove the jumper while the machine is OFF and place onto pins 1 and 2. Power on your machine for a minute. (Note: Your system will not POST). Shutdown your machine and put the jumper back to pins 2 and 3. Your reset is now complete
This is a great troubleshooting2_bing.gif step for those of you having POST issues or no POSTing at all. Like other troubleshooting steps, this will not always work but usually will depending on the problem.
Please let me know if you have any further questions or concerns.
Thanks.
Jan 15, 2010 | Toshiba Satellite L305-S5933 Notebook
Master reset for pc
Unplug your machine from wall outlet. Open the case and remove the flat battery from the motherboard. Wait 5-15 minutes and replace it, your machine is now at default settings.
If this helps plz take the time to write a couple of word testimonial. Thanks.
Oct 19, 2009 | Compaq Presario 5000 PC Desktop
I cant reset the bios password on a fujitsu lifebook n6410
You can find bios clear jumper on motherbord most of it is near cmos cell.
Put it to 2-3 position then power up then again put it in original position 1-2
then check.
Also you can reset all settings with pull out cmos cell for 15 minutes then it not need password.
Try again.
If you need more assistanse let me know.
Thanks.
Aug 24, 2009 | Computers & Internet
How do i remove bios password
* By removing the CMOS battery
* By using the motherboard jumper
* By using MS DOS command
* By using software
* By using Backdoor BIOS password
Mar 13, 2009 | HP Compaq Presario 2500LA Notebook
Dell OptiPlex GX520n PC Desktop Logo
108 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
