Question about Jura Capresso CoffeeTEAM GS 46405
Why does my coffee maker Capresso Team GS leak water?
    New Friend:
Hello, what I have found is the most common cause of water leaking out of the bottom of the capresso team coffee maker is a leaking silicone hose that runs to the boiler (See the photo below with the split in the hose). The replacement silicone hose needs to be safe for beverage dispensing, food & dairy processing, taste and odor-free, with a temperature range of -75? to 350? F. All you need is a sharp pick, a phillips screwdriver, and a pair of needle nose pliers. Remove the four rubber pads on the bottom using the pick. Use the screwdriver to remove the six screws holding the bottom plate on. Remove and replace "BOTH" hoses using the needlenose pliers to pinch the hose clamps. Better to play it safe while you have it apart. If one is bad the other is likely not far behind. I hope this helps. Why does my coffee maker Capresso Team GS leak wat - acccadfd-0d5d-4c31-b1b9-a56192db9bc2.jpg
Posted on Oct 15, 2014
  • Lance Goffinet
    Lance Goffinet Oct 16, 2014
    Note: don't forget to transfer the one way check valve (allowing water flow into boiler) in the input hose and the spring on the output hose to the new hoses. Also, removing the plastic shield to the left of the boiler, as seen in photo, makes things easier.
  • David Orenstein
    David Orenstein Oct 25, 2016
    Prior to leaking I had no flow at all. Cleaning unblocked the flow, presumably it was the check valve that was blocked. In turn cleaning unblocked the split in the hose. Make sure that it's the piston (not the ball) that faces the reservoir when you put the valve in the new hose.
  • 123 Answers
SOURCE: jura capresso E8
Did it work before this?
Sometimes hard water can build up and cause blockages.
Try mixing hot water and white vinegar (50/50 mix) and try running it through the machine. If this works, run it through a few more times than run cold water through a couple times to get rid of the vinegar.
Good Luck.
Posted on Apr 10, 2008
SOURCE: can't get the water to brew through the coffee
I know it's not the same make as mine, but when I had that problem, it was the strainer holes that were blocked and the coffee wouldn't filter through, I just took a wire brush to it and cleared the holes no problem and away she went. . Hope that helps
Posted on Jul 05, 2009
  • 13 Answers
SOURCE: Where can I find an Jura Capresso Impressa F9 replacement lid
The only sources I have been able to find are in Europe. They do not always wish to ship to the US however. In the US the dealers always want the repair, but seldome wish to sell parts outright. Try this website for parts.
Mike
www.juraprofi.de
SOURCE: My Jura Capresso Impressa E8 is leaking water
I have the same problem with my E9 and I have traced it to the diaphragm unit that is just distal to the pump itself. Apparently, the diaphragm is secured with a steel band (not stainless since it is rusty) that may hold seals or O-rings that break down. You can observe it leaking when pressure applied during brewing. The question is: can a new unit be ordered and if so, where?
Posted on Nov 05, 2011
SOURCE: Jura Capressa E9 Leaking
Most likely the 2 spouts have become plugged with crud. Use a toothpick while the machine is dispensing coffee. Stick the toothpick up in each little nozzle and move it around it might take several cups to get this done. I removed the top cover on mine and just poored water in where the coffee normally goes. It is just a gravity feed system. Don't poor too fast and move the toothpick around until the blockage is cleared. Helps to have 2 people for this. Also, once you get it cleared, try the finest grind setting. Mine was set on the coarsest setting and I think that was making making the blockage more likley. I dont think the cracked spout is common though. My machine has made over 8100 cups and is going on 7 years. No cracks are visible in mine.
Posted on Apr 07, 2013
CoffeeTEAM TS leaks water
Hello, what I have found is the most common cause of water leaking out of the bottom of the capresso team coffee maker is a leaking silicone hose that runs to the boiler (see the photo below showing the split in the hose). The replacement silicone hose needs to be safe for beverage dispensing, food & dairy processing, taste and odor-free, with a temperature range of -75? to 350? F. All you need is a sharp pick, a phillips screwdriver, and a pair of needle nose pliers. Remove the four rubber pads on the bottom using the pick. Use the screwdriver to remove the six screws holding the bottom plate on. Remove and replace "BOTH" hoses using the needlenose pliers to pinch the hose clamps. Better to play it safe while you have it apart. If one is bad the other is likely not far behind. I hope this helps.
Jan 28, 2014 | Jura Capresso CoffeeTEAM TS 46505
Jura capresso e9 water not coming through spout
Use a pin or a needle on the spout to clean the nozzle head. Most of the time this is due to useing to fine a grind in the machine. You may have to clean the head this way more then one time to get it to start working again properly.If you have any further questions message me back.
Thank you
Rick
Nov 29, 2011 | Jura Capresso Impressa E9 Espresso Machine...
I have a Capresso CoffeTEAM GS # 464. I decalcified the machine in the last several weeks with Durgol and replaced the water filter - have done this every 6-8 weeks for the life of the machine. I had...
Hi
Probably an internal Element has gone open circuit.
Machine is smart & senses not heating up so don't let water through.
Mine did the same thing. So I pulled it apart (with photos)
Found the heater element (Open). Found a replacement element after 6 weeks and replaced it in 2 hours.
Back to getting great coffee.. Ahhh
Aug 14, 2011 | Jura Capresso CoffeeTEAM GS 46405
Impressa E8 water leak
Did anyone find an answer to this - sadly we have the same issue.
Feb 07, 2010 | Jura Capresso Impressa E8 Espresso/Coffee...
It leaks clear water underneath on right side
Hi, wondering if you found the solution, my S9 is doing the same thing. Thanks
Feb 04, 2010 | Jura Capresso C1500 Espresso & Coffee...
Water holder
1-800-767-3554 around $21. we just purchased one becuase it was leaking but that didn't fix it
Feb 21, 2009 | Jura Capresso CoffeeTEC 471 Coffee Maker
E8 leak
If leaking water from right front when brewing, cleaning or steam then the possible problem is the feed tube from the pressure pump this is mounted with a small o-ring and either the pipe is fractured or the o-ring has perished.
Feb 05, 2008 | Jura Capresso Impressa E8 Espresso/Coffee...
Jura Capresso CoffeeTEAM GS 46405 Logo
443 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
