Question about Yard Machines Garden
Yard machine has oil coming out of the muffler
What can i do to fix this
  • 1,972 Answers
Did you turn the mower on its side? this will do that. If it is all the time then check and make sure your oil level in the engine is where it should be. If that is not the problem you may have bad piston rings.
Posted on Jul 19, 2015
3 Suggested Answers
panilling9
  • 284 Answers
SOURCE: Oil leaking from muffler after start up
Do you have to much oil in the engine?check for overfill and adjust
was the mower turned on its side for some reason? if so oil was probably put where it was not supposed to be and will eventually burn off. Note:If you are checking under a mower always have the spark plug on the engine in the UP position. worn engine ?Rebuild
Posted on Jun 25, 2010
philwalker78
  • 608 Answers
SOURCE: will an MTD yard machine with a 12.5hp briggs &stratton run without a muffler
Yes but not very well, regards Phil.
Posted on Jun 25, 2012
What happened to cause the engine on a Snapper riding mower to emit white smoke?
maybe low on oil, black smoke is when theres oil in the muffler, could be a blown headgasket, pistion rings could be fried also
Jun 01, 2014 | Snapper Garden
Gas is flooding out through the muffler in my push mower
sounds like the needle valve in the carb is not seating replace them and the oil
Jul 05, 2012 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Everytime I engage blades and start to cut white smoke blows out front of engine. Is mototr blown? cheaper to fix or replace?
The muffler discharges out the front as you would see it from the seat. The white smoke in the exhaust when loaded indicateds that you may be having trouble with oil and vacuum inside the engine. At best requires partial disassembly. This may get expensive. I recommend careful consideration regarding the decision to try to repair or to choose to replace.
I hope this helps.
Jul 27, 2011 | Yard Machines 155 Torque Briggs Stratton...
Getting blue smoke when I start the engine. Takes several pulls to get engine started. Also spitting a little oil out of muffler
I would say that your engine is on it's way out. It seems that you have oil getting past your piston rings and the exhaust valve, and out the muffler. Your engine could last another season, or one more month. You could rebuild it yourself, or have it done by someone else. But it could get expensive. Check the oil often. Put in thicker oil like10w-40. You may be surprised how long it may run.
I'm sorry I was not able to give you a better solution. GOOD LUCK.
Jul 26, 2011 | Mtd 22" Yard Machine Push Mower
Jun 24, 2010 | Garden
My mower will start but not run. Oil and gas is leaking from exhuast and filter. What could be wrong?
if the filter is a sponge filter then it's suppose to have oil in it(helps trap dirt) and if your getting gas out of the muffler then the engine is flooding when you try to start it..good luck
Apr 05, 2010 | Mtd 22" Yard Machine Push Mower
Oil in engine
You probably have a blown ring in the cylinder.
Aug 20, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
50 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
