Question about Sharp "FO-2080 Fax, Copier, Printer, Color Scanner"
What does download mode mean - Sharp "FO-2080 Fax, Copier, Printer, Color Scanner"
Different screen now:
It only tells you if you have a custom rom or an official rom and also that mode will let you download and install unofficial roms using a pc/laptop. Be mindful though that it will void your warranty. If you don't know what your doin, i advise you to just take off the battery to close that mode.
Apr 14, 2017 | Samsung Cell Phones
How do I set my Canon EOS Rebel T3i 18 MP CMOS Digital SLR to auto mode
If you mean the auto exposure mode, turn the mode dial on the top of the camera to the "A+" position, between the "P" and the lightning bolt.
If you mean autofocus, set the switch on the lens to the AF position if the lens has an autofocus switch. On the camera, press the AF button (cursor-right) then turn the command dial to select the desired mode.
If you mean the auto white balance, press the WB button (cursor-up) then turn the command dial to select the desired mode.
In the auto exposure mode the ISO mode is set to auto, and you can't change this.
If you need a manual, you may download a copy here.
Feb 02, 2012 | Canon Cameras
This used to work perfectly on windows XP. I now have windows 7 & after downloading the Photo Explosion 2.0, it won't open & the programme just freezes. Help.
Downloading means you retrive any files and save to your PC/Laptop from any web source!
Installing means you install any software/programs to run on your PC/Laptop.
As for your software "Photo Explosion 2.0" could not run on Win 7 due to software "Compatibility Issues".
You can try, using "Win 7 compatibility mode" installing older software read this LINK
NOTE**
"There is no guarantees older software will work using Win 7 compatibility mode!"
Hope it helps.
Nov 11, 2010 | OnDemand Photo Explosion Deluxe 2.0 for PC
What does it mean when the screen on the remote says "safe mode!"?
Hi. Safe mode means that you need to update the firmware on the remote.
1. Launch the software and log in.
2. Click 'Downloads' at the top.
3. Click 'Firmware'.
4. Update the remote.
Hope that helps :)
Apr 18, 2010 | Logitech Harmony 670 LCD Remote Control
Recovery mode?
i havent encountered that specific problem, nor have i seen an option for recovery mode. My best suggestion is to go to the source and download again. http://www.sansa.com/support/sansa_e200/faqs look to the right hand side for download options.
Jul 14, 2009 | SanDisk Sansa e250 MP3 Player
Phone just says dowload, help, how do i reset it?
I'm note sure why it says this but I do know what it means;
When it says 'download' on the screen it means your phone is in 'Download mode'. This is a special mode which is needed to update the firmware of the phone.
You get into this mode by pressing '9' and the power button. Maybe your '9' key is stuck?
B.r.
Jul 08, 2009 | Samsung SGH-a737 Cellular Phone
Chrome Incognito Mode
from google:
"For times when you want to browse in stealth mode, for example, to plan surprises like gifts or birthdays, Google Chrome offers the incognito browsing mode. Webpages that you open and files downloaded while you are incognito won't be logged in your browsing and download histories; all new cookies are deleted after you close the incognito window. You can browse normally and in incognito mode at the same time by using separate windows.
Browsing in incognito mode only keeps Google Chrome from storing information about the websites you've visited. The websites you visit may still have records of your visit. Any files saved to your computer will still remain on your computer."
Hence it an option to maintain privacy..the same feature is included in IE8(beta)
Hope it helps!
Nov 05, 2008 | Google Chrome
What does ' download mode mean as soon as the copier is turned on no other function tart ....just the display turns on and stated "download mode" Sparp copier 1655 cs
Not sure what it means but it's almost impossible to get out, once in that mode. If it's under a year Sharp will fix it for free, call and talk to tech support they will ask for a CC # and will send a prepaid return sticker to ship ground. If not most likely you will have to change the main board!!!!!!!
Jul 25, 2008 | Sharp Office Equipment & Supplies
Download mode
Hmmmm.... Hello jubest. I am a bit concerned that you even know how to get into download mode. Download mode prepares the copier to be reprorammed. This is used when the engineers at Canon who designed the machine determine that through R&D and real world encounters decide to update the software/firmware to better hone the device's ability better function in the real world. I would not call it dangerous to life and limb or to the enviroment where the device is being used for an untrained person to enter download mode. But I can assure you that it is extremely easy to render the copier unusable, although it can still be used as a great place to put a fish bowl or a no smoking sign if you decide to play around with "download mode".
Sep 12, 2007 | Canon (6981A002AA) for imagerunner 2200,...
Sharp "FO-2080 Fax, Copier, Printer, Color Scanner" Logo
19 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
