Question about Ruud Central System Air Conditioner
Inside blower will not run at the same time as the comp
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 135 Answers
Can you be more specific
Posted on Nov 25, 2014
Air condition stopped blowing
If its your blower motor (Pass. comp.) check the fuse eather inside the engine comp. or pass. comp. by using your owners manual (fuses & relays section) Varify it does not blow when the heater is on. If it still not blowing and you have pwr. to the motor. replace the motor.
Sep 03, 2010 | 2005 GMC Yukon
Will not turn on
take the cover off the side of comp,or the back where ever the main cover is, then very cearfully get as much dust out of the inside of comp as possible thats what i would do first, i use my shop vac as a blower. a paint bbrush work's fine as a duster also, good luck.
Dec 20, 2009 | HP Pavilion a1230n (EG134AA) PC Desktop
FAN RUNS ALL THE TIME. COMP RUNS FOR 3 MINS THEN OFF FOR 3 THEN ON FOR 3.....
You could be overcharged or undercharged with refrigerant, a dirty condenser or evaporator coil or fan or blower motor not running at full speed, or you could have a dirty filter or or possibly a bad capacitor on the compressor.
Sep 25, 2009 | Goldstar DH504EL Dehumidifier
Outside fan and compressor does not shut off
the system is wrong, the blower must run continuously , and the compressor is the will stop if the temperature setting is reached. The outside fan is the same as the comp.
Jun 16, 2009 | Heating & Cooling
Blower fan not working
the ac fan blower resistor has failed. The blower will not turn on but the ac clutch works. This is a common problem on several models. You will find on some that the fan will come on and the comp goes off at some settings. Have the resistor checked and verify power to the fan blower before spending a lot of money for a cheap repair. good luck
May 20, 2009 | Heating & Cooling
Front blower motor on 2002 dodge grand caravan sport only works on high speed
it's the blower motor resistor , it's behind the glove compartment, just make sure you disconect the neg. for battery first, open the glove comp. and pull the rubber stops towars the center so you can let the glove comp. hang all the way to the floor , the resistor it's in front of you, disconect the two conectors there's one big with 6 0r 8 wires coming out and another with only two, take them out by pressing on the side of each one, remove it , put the new one on , conect the battery and your done. it's about $ 13.00 at o'riellys auto parts .
I hope this fix yor problem.
David M.
Mar 13, 2009 | 2002 Dodge Grand Caravan
Inside Fan Relay location
replace blower motor switch on dash
Dec 18, 2008 | 1998 GMC Sierra
Compressor problem?
The buzzing is your compressor trying to start. It is going off on internal overload caused by heating up of the motor windings.If you have an amp meter you could check the amp draw of the comp against the locked rotor amps listed on the tag You could try to have someone test your run capacitor, which looks like a can. Could be round or oval with wires coming off it. Or try a hard start capacitor and relay to bust it loose if compressor rotor is stuck. If that doesn't do it the comp is bad.
Jun 10, 2008 | Ruud UBHC Air Conditioner
Inside blower not starting every time
That's a weird problem. I wonder if the outside compressor is drawing down the voltage in the breaker box enuff to keep the blower from starting up. If you're set to cool but the thermostat is NOT calling for the AC, can you manually turn the blower on fathfully? If so, I would check all wiring connections in the breaker box to make sure they are tight and free from tarnish or corrosion. You may even need to contact your power company and have a higher amperage line installed outside. Do your house lights blink noticably when the compressor kicks on?
While you're resolving this, you could start the blower manually and just leave it on. The compressor cycling on/off shouldn't stop the blower once it's running and it won't draw much current... couple bucks a month maybe.
Hope that helps...
Geno
Apr 04, 2008 | Goodman CKL24AR24 Air Conditioner
Ruud Central System Air Conditioner Logo
22 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
