Question about Utilitech 1-HP Cast Iron Shallow Well Jet Pump PPSWJ100
Does this pump have a reset screw or button? - Utilitech 1-HP Cast Iron Shallow Well Jet Pump PPSWJ100
Why is there a rear fuel pump on 89 jetta diesel
under the backseat access panel with 3 screws
Jan 21, 2013 | Cars & Trucks
Engine cranks but won't start
POSSIBLY YOU FUEL PUMP IS BAD OR YOUR FUEL PUMP RELAY OR FUSE. ON YOUR FUEL INJECTION LINE THERE IS A BLACK CAP UNSCREW IT THERE IS A PART THAT LOOKS LIKE VALVE STEM TAKE A PHILLIP SCREW DRIVER AND PUSH THAT STEM IN IF THERE IS NO PRESSURE (OR GAS DOESN'T COME OUT) IT' THE FUEL PUMP.
Jan 02, 2013 | 2002 Mercury Sable
Do i have to have a jumper wire or just reset the fuel pump button?
No idea what jumper wire your referring to
The Fuel Safety Switch is only on Ford Products,
and unless you were in an accident it will be closed
If you push down on the red button and nothing happens ,
it is closed/on,okey
Put a screw driver to your ear and put on fuel tank
Have someone cycle the key on & off
Listen for fuel pump.
Apr 24, 2011 | Ford F-150 Cars & Trucks
Foodsaver pro locked up. 3 green lites blink off and on. is the problem fixable?
The reset button is the small black rubber covered hole on the left side of the vacuum channel. If you press down on that with something like a knitting needle with the unit on, it should reset
Oct 17, 2010 | Tilia FoodSaver V2240
The machine is just flashing E24 on the front. What does this mean?
E24 = draining failure
If the appliance has stopped full of water then you have to check the drain hose for blockages, especially where it connects to the drain. Check the pump for a blockage, bail out the water manually and remove the filters. You should find a cover held by a screw covering the pump impeller. Take out the screw, take off the cover and remove anything jamming the pump. Refit the cover and try the appliance again.
Sep 06, 2010 | Dishwashers
How do i reset my boiler after having oil delivered, it ran out 2 days aggo just had 1000 litres delivered how do i getr the boiler up and running again????
While standing in front of the oil burner, on the left side you will see the fuel pump. On the bottom corner towards you, you will see a bleeder screw. If you put a cup or other vessel under this screw, loosen the screw, then hit the reset button it will start to push oil out the bleeder. Once the oil comes out a clear red liquid, close the bleeder screw and the unit should fire up. Hope this helps
May 13, 2010 | Water Heaters
Where is the reset button on a nuvi? a tiny screw-like thing?
the reset is on the bottom of the GPS, it is covered with a decal labled "reset", use a straightened paper clip to depress the recessed reset button.
Feb 10, 2010 | GPS
Reset for fuel pump
right side kick panel,1 or 2 screws comes off and hit the red button on top
Jan 07, 2010 | 1998 Ford Expedition
HOW DO I PURGE AIR FROM FUEL LINE SO MY BURNER WILL START I ALREADY BLED THE BURNER BUT AM STILL GETTING AIR OUT THE LINE
You will need a coffee can, clear hose that fits snugly over the bleeder screw and a 3/8 or 7/16 open end wrench. Find the bleeder screw on the oil pump. It will look like a grease fitting or brake line bleeder screw. Put the clear hose on and put the open end in the coffee can. Start the burner by making sure the door switch is closed and the red reset button is depressed. As the furnace starts, open the bleeder screw and watch the pink fuel as it goes into the can. Your primary control will trip after a few seconds (15-45). Close the bleeder. Reset the primary control, you may need to let the control sit for a minute or you may need to hold the button down for a minute to reset the control (each control is different). Then start the furnace and open the bleeder. You are looking for a good flow of oil with no bubbles. If you do this more than 3 times, you have an air leak in the suction line somewhere or low oil level.
Nov 08, 2009 | Honeywell Heating & Cooling
Utilitech 1-HP Cast Iron Shallow Well Jet Pump PPSWJ100 Logo
90 people viewed this question
Top Utilitech Plumbing Experts
Paul Carew
jhnolson
Are you an Utilitech Plumbing Expert? Answer questions, earn points and help others
