Question about Dometic Rooftop RV Air Conditioner
Is there oil that you can add to the fan - Dometic Rooftop RV Air Conditioner
    Genius:
  • Dometic Master
  • 1,363 Answers
No way to oil. replace motor.
Posted on Aug 17, 2015
What to do if fan is frozen up
You need to put some Hunter oil then push the blades around by hand to get the bearings lubed. Then check oil level and add more oil if necessary.
Sep 25, 2014 | Hunter 23852 Classic Original Ceiling Fan
Troubleshooting lakewood fan model hv 18
This one the best brands on the market that I have ever owned.
If the fan motor will not turn on or hums and/or turns slowly more than likely its a lubrication problem.
1. Unplug the fan from the wall remove the 516 screws to the cage
2. Try turning the fan blade by hand if it is tough to turn more than likely it's a lubrication problem
3. You will have two oil holes one in the front one in the back spray WD-40 into these holes, turn the fan blade if it starts to free it up apply more WD-40 and keep turning the blade add more WD-40 until the blade turns freely. Especially in the rear oil hole because this is an oiled bushing that you are adding oil to. Once the fan is turning freely replace the front cage with all the screws plug the fan and I hope this solves your problem. You may add 3 in 1 oil or some other very light lubricating oil periodically.
I hope this solves your problem Mike
Mar 03, 2012 | Lakewood HV 18-c Floor / Box Fan
My cast iron original hunter ceiling fan needs a manual boost to start rotating after the switch is turned on. The fan has plenty of oil. What is the problem?
Howdy,
There are a couple of issues which can cause this with the Original. First, is this an American made fan, or a Chinese made fan? The main difference between the two is the motor type. The Chinese version should have an "A" after the model#.
First question, when you turn the fan off, how long does it take to come to a stop? From high speed it should take at least 60 seconds, from low at least 20 seconds or so. Also, are you trying to start this fan from a wall switch on low speed?
The first issue which can cause this is oil level, I know you say it has plenty of oil, but, depending on how you checked it, it may not be enough in the reservoir. To check it, you take a pipe cleaner and bend it over to form a J with the hook portion being 3/8"-1/2" long and dip it into the oil cup at the top of the switch housing as said in the below links. Remember, if you have a Chinese fan from 2002-2007 (after 2007 there is a brass cap on top of the motor where you add the oil and it functions the same as the American fans), the oil hole will be on the switch housing and you must lean the motor over to add oil, if you add it with the motor level there will not be enough oil in the reservoir. If you are indeed full of oil, run the fan on high, and with a LARGE screwdriver used as a stethoscope, remove the switch housing cap (two screws) and insert it all the way to the top of the switch housing and put your ear to the other side of it, then turn the fan off and while it coasts down listen. You should hear very little noise if anything at all, it should be totally smooth oil if circulating through the oil system, if it sounds dry and gritty or like metal on metal, then oil is NOT getting to the top of the armature. If this turns out to be your problem, I can help you fix it.
The second issue which could cause this, is the capacitor is getting weak and the motor isn't generating enough torque to start. I think this is fairly unlikely as I have never seen an Original with a bad cap.
The third issue could be that, if the oil is where it is supposed to be and if you have tried putting an extra snort in the oil hole and that doesn't cure it, that something has gotten into the oil reservoir and is binding the bearing up. Bugs seem to love the oil cups of these fans for some reason and I have discovered wasps, beetles and flies in the oil cups before when dis-assembling these fans for repair. If you have exhausted the other possibilities, remove the fan and drain the oil out of it, shake the fan a few times to make the rotor bang back and forth and then re-install the fan and re-fill with new 10wt oil. (do not use 3-in one oil in either the red or blue can, both of which contain napatha)
If you have the American made fan, this is the owners manual http://www.hunterfanhq.com/tools/sales/hunter/preseason/images/owners/41532.pdf
If you have the Chinese fan, this is the owners manual for it http://www.hunterfan.com/uploadedFiles/Support/Owner_Manuals/41556.pdf
If this is an American made fan, it's worth repairing, if it is NOT an American made fan and after troubleshooting it and not finding a fix, I recommend calling Hunter and warrantying the unit out. The motors carry a lifetime warranty.
Dec 12, 2010 | Hunter 23918 Classic Original Iron Fan
Older hunter original, needs lubrication. Where do I put the lubrication in? What kind of lubrication/oil? Used to buy fan oil, but no longer available, Fan has clicking noise and lubrication oil...
Howdy,
This is the owner's manual to your fan
http://www.hunterfanhq.com/tools/sales/hunter/preseason/images/owners/41121.pdf
As for oil, you can use one of two oils. Depending on how old your fan is, I suggest changing the oil by removing the fan, turning the motor completely over and letting it drain into the "dish" on the part that spins, clean the oil out of there, then re-hang the fan and oil with 1 oz of either Hunter Fan Oil (which is available from hunter, or on ebay, just search for Hunter Original Fan) or Zoom Spout Oiler, both are the same oil.
Thanks
Sep 23, 2010 | Hunter Dryers
Fan moves very slow what is the promblem?
Sounds like you need to oil the fan shaft. They get dusty and dirty and it gathers in the oil that was in it.
add more oil and it should fix the problem. THE RAZ
May 13, 2010 | Hunter "Lexus" Traditional 52" Ceiling Fan...
I received a Duracraft model CZ-600 oil Heater. I don't know
I'm in the same boat..are we the only ones who have one?
Nov 22, 2009 | Duracraft DY-012 Tower Fan
My Hunter (original model) fan on porch will not rotate. Can hear that the motor is running?
being on the porch humidity takes a toll on electronics..fan motor usually burns up
Nov 08, 2009 | Hunter 23852 Classic Original Ceiling Fan
Equium P200-1ED.
yes the fan can be changed before that your noise making fan can be fixed only you have to do is that unscrew the fan first take small brush clean the fan leafs and blow some air from your mouth to the bearings and motor part put a few drops of oil or 2-3 drops of oil in side bearings and slowly rotate your fan with your fingre to and fro so the oil can reached to the bearings and it will get lubricated wait for five mintues and fix the fan back in position and you can use it ot need to add more oil to it again add 2-3 drops thats all once the fan is lubricated it will not make any sound in the future this is applicable to all cooling fan it is must that once in a year you should lubriacte the fans for better perfomance and it will get more life too.....
Oct 12, 2009 | Computers & Internet
Why i add singer oil to the axle of the home stand fan, 16ins blade, the fan cannot rotate at all. What is the problem.
the bearings are dry and shaft is seizing up on it. disassemble,soak bearings with oil and reassemble. easy one.
Jun 10, 2009 | Dryers
Check/add oil to a hunter ceiling fan
If you are asking for instructions on checking and possibly adding oil to a Hunter Original fan. Here are instructions:
Check oil level immediately after filling the reservoir. To check oil, bend an ordinary pipe cleaner into a 1/2" long hook and dip it into the oil reservoir.
If oil touches the end of the pipe cleaner, the fan has ample oil. If it does not touch, add SAE 10 non-detergent oil slowly until it touches the pipe cleaner.
-Hunter Original fans rarely/ never need oil unless they were relocated or tipped. ...Or if the fan was improperly installed.
-Hunter sells an oil refill / oil level check kit with good instructions. They also sell a relocation kit that includes the same kit plus all mounting hardware needed.
Good Luck!
Apr 26, 2009 | Hunter 23852 Classic Original Ceiling Fan
Dometic Rooftop RV Air Conditioner Logo
27 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
