Question about Garden
Adjusting a toro 268-H steering column - Garden
2 Suggested Answers
lester482529
  • 226 Answers
SOURCE: the steering wheel on my toro lawn tractor is
no; you'll need a new steering shaft and a steric gear.( i just did this on mine) this will be your best result.as they wear @ the same time both need to be replaced.hope this helps
Posted on Jul 29, 2009
I need a manual for toro wheel horse 268 hydro model 72107 serial no.210000417
Go to TORO.com and look for manuals. They are available for download
Jan 23, 2017 | Toro Garden
How to make gears/teeth on lower part of steering line up on 268-H T Wheel Horse line up? Rmove deck, orwhat? There is some wear on the teeth, & was bumping last time I mowed. Now, won't turn at all.
There is a spacer/bushing on the very bottom of the steering column. With wear the bushing fails and lets the steering column/and gear on the bottom of it slip down to the point that the gears don't mesh. Replace the Bushing.
Sep 14, 2015 | Cub Cadet 46" Lawnmower Deck Drive Belt...
Adjust height of Prizm steering wheel
Some Geo Prism's (and sister car Toyota Corolla) have adjustable steering columns, and some do not. The adjustment lever is on the left side of the steering column, underneath the turn signal arm. Pull this lever out...away from the steering column, and you will feel the entire column loosen for up and down positioning. To re-secure after fine tuning the desired height...push this lever firmly back into position beside the steering column. If your Prism does not have this lever...your car is not equipped with the adjustable optional column. Hope this helps.
Mar 19, 2012 | Ford F-350 Cars & Trucks
How to adjust clutch pedal on 86 mustang lx
clutch is supposed to be self adjusting. Here are instructions for replacing the adjuster:
REMOVAL & INSTALLATION
See Figure 1
  1. Disconnect the battery cable from the negative terminal of the battery.
  2. Remove the steering wheel using a steering wheel puller, Tool T67L-3600-A or equivalent.
  3. Remove the lower dash panel section to the left of the steering column.
  4. Remove the shrouds from the steering column.
  5. Disconnect the brake lamp switch and the master cylinder pushrod from the brake pedal.
  6. Rotate the clutch quadrant forward and unhook the clutch cable from the quadrant. Allow the quadrant to slowly swing rearward.
  7. Remove the bolt holding the brake pedal support bracket lateral brace to the left side of the vehicle.
  8. Disconnect all electrical connectors from the steering column.
  9. Remove the 4 nuts that hold the steering column to the brake pedal support bracket and lower the steering column to the floor.
  10. Remove the 4 booster nuts that hold the brake pedal support bracket to the dash panel.
  11. Remove the bolt that holds the brake pedal support bracket to the underside of the instrument panel, and remove the brake pedal support bracket assembly from the vehicle.
  12. Remove the clutch pedal shaft nut and the clutch pedal, as outlined above.
  13. Slide the self-adjusting mechanism out of the brake pedal support bracket.
  14. Examine the self-adjusting mechanism shaft bushings on either side of the brake pedal support bracket, and replace if worn.
To install:
  1. Lubricate the self-adjusting mechanism shaft with motor oil and install the mechanism into the brake pedal support bracket.
  2. Position the quadrant towards the top of the vehicle. Align the flats on the shaft with the flats in the clutch pedal assembly, and install the retaining nuts. Tighten to 32-50 ft. lbs. (43-67 Nm).
  3. Position the brake pedal support bracket assembly beneath the instrument panel, aligning the four holes with the studs in the dash panel. Install the four nuts loosely.
  4. Install the bolt through the support bracket and into the instrument panel. Tighten to 13-25 ft. lbs. (18-34 Nm).
  5. Tighten the four booster nuts that hold the brake pedal support bracket to the dash panel to 13-25 ft. lbs. (18-34 Nm).
  6. Connect the brake lamp switch and the master cylinder pushrod to the brake pedal.
  7. Attach the clutch cable to the quadrant.
  8. Position the steering column onto the four studs in the support bracket and start the four nuts.
  9. Connect the steering column electrical connectors.
  10. Install the steering column shrouds.
  11. Install the brake pedal support lateral brace.
  12. Tighten the steering column attaching nuts to 20-37 ft. lbs. (27-50 Nm).
  13. Install the lower dash panel section.
  14. Install the steering wheel.
  15. Connect the battery cable to the negative terminal on the battery.
  16. Check the steering column for proper operation.
  17. Depress the clutch pedal several times to adjust the cable.
Sep 24, 2010 | Ford Mustang Cars & Trucks
How to change a ignition switch on a 1990 Z24 cavalier and a diagramof what to look for
Ignition Switch REMOVAL & INSTALLATION 1982–91 Vehicles The switch is located on the steering column and is completely inaccessible without first lowering the steering column. The switch is actuated by a rod and rack assembly. A gear on the end of the lock cylinder engages the toothed upper end of the rod.
  1. Lower the steering column; be sure to properly support it.
  2. Put the switch in the OFF-UNLOCKED position. With the cylinder removed, the rod is in OFF-UNLOCKED position when it is in the next to the uppermost detent.
  3. Unfasten the two switch screws and remove the switch assembly. Fig. 1: Removal and installation of the ignition switch and related steering column components — 1990 vehicle shown 87958059.gif
    Fig. 2: Exploded view of a steering column including the ignition switch — 1990 vehicle with standard column shown 87958060.gif
    Fig. 3: Exploded view of the steering column including the ignition switch — 1990 vehicle with tilt column shown 87958061.gif
    To install:
  4. Before installing, move the new switch slider (standard columns with automatic transaxle) to the extreme left position. Move the switch slider (standard columns with manual transaxle) to the extreme left position. Move the slider (adjustable columns with automatic transaxle) to the extreme right position and then move the slider one detent to the left (off lock). Move the slider (adjustable columns with manual transaxle) to the extreme right position.
  5. Install the activating rod into the switch and assemble the switch on the column. Tighten the mounting screws. Use only the specified screws, since overlength screws could impair the collapsibility of the column.
  6. Reinstall the steering column.
Sep 01, 2010 | Chevrolet Cavalier Cars & Trucks
How do I locate the ignition switch and remove it from my gmc sierra 1991 ignition switch
The ignition switch is located on the top of the steering column underneath the dash.
1. Remove the cover panel from under the steering column and you should see the bracket that holds up the steering column, but before you un-bolt the bracket to lower the steering column, you must remove the clip holding the shifter position indicator cable to the column. (put the shifter into drive and you should be able to see the screw that holds the shift indicator cable adjusting clip to the steering column)
2. Remove the bracket holding up the steering column and carefully let the steering column down as far as it will go, the steering wheel will probably be resting on the seat.
3. You should now be able to see the ignition switch on the top of the steering column, and the two mounting bolts. The high beam switch might share the upper ignition switch bolt, and you will then need to remove the high beam switch before you can remove the ignition switch.
4. Remove the ignition switch mounting bolts (usually 5/16 but I have also seen 11/32 and 3/8 size bolt heads used)
5. Remove the ignition switch by lifting straight up from the column to dis-engage the interlink rod from the ignition tumbler assembly, you should then be able to pull the ignition over towards you just enough to dis-connect the two wire connectors to the switch and then you can remove the old switch from the vehicle. (the interlink rod is sticking straight up from the steering column and it slides up and down with the operation of the key, it fits into a notch in the ignition switch and that is what actuates the switch)
6. Reverse procedure to install new switch, starting with re-connecting the wire connectors and be sure that the interlink rod goes into the notch in the ignition switch.
7. When the switch has been re-installed and is ready to be adjusted, turn the ignition switch to the "ON" position and hold the key in that position and slide the ignition switch up and down until it is in the on position and your dash lights come on, tighten up the ignition switch mounting bolts and then test the operation of the switch, and re-adjust if necessary until the switch operates properly.
8. Adjust the high beam switch by pulling back on the high beam lever and just taking up the slack in the actuator rod to the high beam switch, test the operation of the high beam switch and re-adjust if necessary.
9. When the steering column is bolted back up, re-attach and adjust the shifter position indicator by placing the shifter in neutral and slide the adjusting cable clip until the shift indicator is pointing in the neutral position, test the function of the shift indicator and adjust as necessary.
Apr 24, 2010 | 1991 GMC Sierra
The steering wheel on my toro lawn tractor is loose - teeth won't engage. It doesn't look like the teeth are broken - can I loosen the plate on the tractor that is attached to the wheels and adjust to fit...
Jul 27, 2009 | Garden
The steering wheel on my bmw 7 series 2003 730ia model is self adjusting after a change of steering angle sensor and steering column switch.please help
Read the owners manual on resetting your door control seat preference this will include steering column and pedal adjustment if installed on your 7.
Jul 02, 2009 | 2003 BMW 7 Series
2000 Mercury Villager: Is there a shift lever adjustment? When placing foot on brake pedal and pulling shift lever rearward it doesn't feel like the transmission is completely disengaging and it is...
You may have a loose shift linkage in the steering column. Remove the upper and lower plastic covers behind the steerong wheel (5 or 6 philips head) and see if you have any loose torx head or allen head screws. Ea
rlier models had this isue.
Also, go to this site for Villager Quest help.
http://autos.groups.yahoo.com/group/villagerquest/
Here's adjustment procedure too
SECTION 307-05: Automatic Transaxle/Transmission External Controls 2000 Villager Workshop Manual
GENERAL PROCEDURES Cable Adjustment —Shift Control
  1. Place the gearshift lever in PARK (P) position.
  1. Raise and support the vehicle. Refer to Section 100-02 .
  1. Remove the splash shield.
  1. Loosen the shift cable nut.
  1. Position the shift linkage in PARK (P) position.
  1. Tighten the shift cable nut.
  1. Move the gearshift lever through the entire shifting range.
  1. Verify that the engine will crank with the gearshift lever in PARK (P) or NEUTRAL (N) position.
  1. Adjust the transmission range (TR) switch as necessary, refer to Section 307-01 .
Item Part Number Description 1 043B13 Driver side air bag module 2 — Steering wheel nut 3 3600 Steering wheel 4 — Radio volume control cover 5 — Air bag sliding contact electrical connector access panel 6 — Cruise control cover 7 14A664 Air bag sliding contact 8 13K359 Multifunction switch 9 — Tilt wheel lever 10 13318 Turn indicator cancel cam 11 — Steering column assembly 12 — Steering column mounting bracket nuts (4 Req'd) 13 3C695 Lower column shroud 14 — Steering column opening cover nuts (3 Req'd) 15 — Steering column lower yoke bolt 16 3N725 Steering column lower yoke 17 — Steering column clamp bolt 18 3C695 Upper column shroud 19 7210 Gearshift lever
May 05, 2009 | 2000 Mercury Villager
Garden Logo
73 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
