Question about Frigidaire Dryers
Manual dryer model Le02152H50 reverse door
Model LE02152H50 dryer I am reversing door and would like instruction
  • Frigidaire Master
  • 5,323 Answers
SHOULD BE SIMPLE IF IT HAS THE ABILITY TO DO THAT JUST BREMOVE DOOR AND CHANGE OVER SCREWS FROM ONE SIDE TO THE OTHER
Posted on Dec 20, 2014
hards327
  • 30 Answers
SOURCE: Zanussi Condenser Tumble Dryer
go to the zanussi web site you should be able to download a manual good luck
Posted on Mar 17, 2008
SOURCE: zanussi ZDC67550 Dryer, door swing change?
Hi
just reversed the doors in 15-20 mins. It worked for me. You do need to be a competent DIYer to do this.
If in doubt, do now't. Get in an engineer
Disconnect from mains (obviously)
Remove top using 7mm nut driver/spanner
Remove 2 cross-head screws holding the door - Door will come away from dryer.
Remove 2 cross-head screws holding the white top and bottom blanking plates
pull out the switch blanking plate
Locate the PINK wires connecting the switch/latch mechanism inside the dryer at the top. This will be taped to a blue wire.
Unscrew the 2 smaller cross-head screws holding the latch/switch assembly whilst holding the pink wire to stop the mechanism dropping inside the dryer.
Pull up the latch mechanism and unravel the black tape holding it to the blue wire.
Drop the latch assembly down the lefthand side of the dryer and refit using the 2 small cross-head screws.
Retape to the blue wier and feed the PINK wires through the plastic retainers.
Fit the white blanking plates to the RIGHT handside of the door opening.
Swap the hinges and the switch latch on the door (don't lose the spring !!!, refitting the hinge blanking plates(ease these out with a small flathead screwdriver covered witha bit of insulating tape to avoid damage.)
Fit the door using the 2 cross-head screws you have left
Refit the top.
Connect to the mains and switch on to the sound of £80 you have just saved yourself !!
Electricity kills Be careful
Posted on Aug 25, 2008
onthejob5130
  • 640 Answers
SOURCE: how do I reverse the door
its with your owners manual,,,look for the installation instructions..onthejob
Posted on Feb 09, 2009
dragonsthatk
  • 547 Answers
SOURCE: reversing door
you can not change the way the door opens
Posted on Feb 11, 2009
SOURCE: How do you reverse the
Remove the hinges from the dryer and then unscrew them from the door. Remove the 4 screws on the opposite side of the door so the inner and outer door panel detach. You will also have to remove 3 phillips head screws that hold the door handle to the panel so you can flip it, because top and bottom are not symmetrical. One of the 3 is hidden under the handle, you will see it when the other 2 are off. Rotate the handle and reassemble handle and inner door panel. Put the hinges back on opposite side and also switch the door latch. PS, one glitch is that the light cutoff switch is on the right side, so the door has to seat well to turn it off.
Posted on Jan 01, 2010
How to reverse a Kenmore 110.69132412 dryer door
you can put in your model numder of your dryer in google an it will show u a video on how to reverse your dryer door ok
Jun 11, 2017 | Kenmore Dryers
How do I reverse the dryer door on a kenmore model #122-00?
Most likely instruction are inside user manual
Feb 26, 2015 | Kenmore Dryers
HOW DO I REVERS THE DOOR
Hello friend, thank you for your post!
I understand that you are looking to reverse your doors on your Frigidaire dryer. I have located the installation instructions and on page 7 and 8 it explains the process of door reversal. I hope this helps. -Matt
Frigidaire Manual Search Results
Sep 20, 2014 | Frigidaire Dryers
I would like to know to reverse the door on my dryer
Not all dryers have reversible doors, but most do. This varies from model to model, but the owners manual should have a description to accomplish it. Some models simply flip over using a matching set of screw holes on the opposite side of the door opening while others will require you to disassemble the door and switch parts around to achieve a mirror image of the assembly that will hinge from the opposite side. The latch pin/receiver (on the cabinet) will also need to be addressed as it holds the door tightly closed.
Aug 24, 2014 | Dryers
I have ane electrolux dryer with reversible doors. I would like to keep the door opening to the left, but it hits the wall. Is it possible to adjust the door to make it stop before hitting the wall?
Hi Wendy, this is AP
I understand you want to reverse the door opening on your Electrolux dryer. I would be happy to assist you with those instructions. Are you able to provide the model number for your dryer? If this is a new dryer you may visit the manufacture website, locate your appliance, scroll down to bottom and you will see a listing of documents available, the installation instruction manual will have the reversal instructions listed. . I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect if you have additional information regarding your question.
Thank you,
Mar 21, 2014 | Electrolux Dryers
The door on my dryer and washer open the wrong way
Are you planning to reverse the door swing direction on your
DUET®dryer? To do so, you will need to purchase a Door
Reversal Kit.
To order, call the dealer from whom you purchased your dryer or
refer to the "Assistance or Service" section of this manual. Ask
for Part Number 8530069 (Shield Blue), 8530070 (Shield
Platinum), 8530071 (Biscuit) or 8530072 (Pewter).
Door Reversal and Stack Combination Kit
® ® DUET dryer and stack your DUET washer and dryer? To do so,
you can purchase a Door Reversal and Stack Combination Kit.
for Part Number 8530073 (Shield Blue), 8530074 (Shield
Platinum), 8530075 (Biscuit) or 8530076 (Pewter).
From the manual, Page 4. Hope this helps
Eric
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0802161.pdf
May 24, 2009 | Whirlpool Dryers
How do I reverse the door
Feb 08, 2009 | Dryers
Need to reverse dryer door on Model #FEFB9200ESO
instructions are available here
thanks for using Fix Ya, please take the time to rate this solution.
clarkco
Feb 06, 2009 | LG WM-2277HW Front Load Washer
Dryers Logo
74 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
