Can i watch region 1dvds on a acoustic solutions lcd tv 32" 761hd
I want to know if this lcd tv is multy standard, eg system set up, automatic,
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 65 Answers
Yes
Posted on Jun 23, 2009
How do you convert a Sony dav-sb100 Home theatre system to be multi-regional so can play region 1dvds?
bought a Sony home theatre DAV-DZ270 region 4, can you please help me to make it multi-region.
Feb 15, 2013 | Televison & Video
NV-VP60GC-S How do I get the color?
really? that's a settings issue..open up the menu(got a manual with this item?) and reset for defaults.
May 23, 2008 | Panasonic Multi-System Region-free...
How to unblock region code block of sony bdv-e770w?
It's already Region Free when purchased.
  • A+B+C Multi Zone Region Code Free Blu Ray Player DVD Region 123456 PAL/NTSC
  • PAL or MULTI-SYSTEM TV is required to watch PAL DVDs. If your TV was purchased in North America (NTSC) you will also need a Video Scaler Full HD 1080p.
    May 07, 2011 | Sony BDV-E770W 3D Blu-ray Theater System...
    How do I get my 52inch rca scenium to show 1080 using my ps3
    Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
    1.
    Check the resolution supported by your TV.
    Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
    2.
    Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
    3.
    Select [Video Output Settings].
    4.
    Select the connector type on your TV.
    Resolution (video mode) varies depending on the type of connector used.
    videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
    *2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
    D5: 1080p / 720p / 1080i / 480p / 480i
    D4: 1080i / 720p / 480p / 480i
    D3: 1080i / 480p / 480i
    D2: 480p / 480i
    D1: 480i
    *3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
    *4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
    5.
    Change video output settings.
    Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
    videooutput003.jpg 6.
    Set the resolution.
    Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
    * The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
    If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
    If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
    videooutput004.jpg 7.
    Set the TV type.
    Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
    videooutput005.jpg 8.
    Check your settings.
    Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
    videooutput002.jpg 9.
    Save your settings.
    The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
    Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
    Feb 28, 2011 | RCA Televison & Video
    Lcd26805hd manual FOR A ACOUSTIC SOLUTIONS LCD TV
    My acoustic solutions lcd26805hd tv has started flickering really badly every time I switch it on. The flickering goes on for about 30 minutes before it calms down. I have checked all the connections at the back of the tv - all ok. This happens whether I watch cable or a dvd.
    Jan 10, 2010 | Televison & Video
    I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
    1. Check the resolution supported by your TV.
    2. Select (Display Settings) under (Settings) in the home menu.
    3. Select [Video Output Settings].
    4. Select the connector type on your TV.
    D2: 480p / 480i
    D1: 480i
    5. Change video output settings.
    6. Set the resolution.
    7. Set the TV type.
    8. Check your settings.
    Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
    9. Save your settings.
    The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
    Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
    Multi region phillips dvd player
    Is this a Multi-region Player ?
    Some Players are region Set to play Only the region they, are intended For. i.e Region 1 = NTSC( USA ) Region 2 = (PAL ) UK. Region 6 = ( ASIA ) And so on.
    If you need a multi-region hack for your player, Post here.
    I do charge a Small fee for This service.
    Mike @ compurepair.
    Feb 29, 2008 | Philips DVP3140
    Multi region support
    Unit is programmed for respective regions and cannot be changed, however, you can also find discs that are "region free" and they will play fine...accordianman
    Feb 22, 2008 | Sanyo HV-DX2E DVD Player/VCR
    Sony dvd player Model DVPNS78H
    Sounds like the TV you are using does not support NTSC, the US TV standard. Try connecting the DVD player to some other TVs - something not more than a few years old would be a good bet, and a large screen plasma/LCD ideal as most of these are "multi-system" and handle PAL and NTSC automatically.
    If the problem was the region coding you would be getting a message on the screen, something like "Cannot play due to area limitations".
    Jan 14, 2008 | Televison & Video
    Bush DVD2055HDB HDMI DVD Player.
    the PN onremote to tv set this is all about the system on tv ie pal is always for colour , and auto is always determined by the tv this si automatical set by tv depending on in coming siginal ie from advd machine. NTSC is always afaded colour some times it may appear as black and white
    Jul 29, 2007 | Bush DVD2038 DVD Player
    Televison & Video Logo
    47 people viewed this question
    Top Televison & Video Experts
    Marvin
    Marvin
