Question about Troy-Bilt 2700 PSI 2.3 GPM Gas Pressure Washer 020486
Pressure builds up but when I squeeze the trigger, it dorps off to almost nothing right away
How do i stop it from pulsing?
Getting to much air to carb probably.
Jul 11, 2015 | Karcher Garden
Low pressure
It sounds like the nozzle is worn or the wrong size ( too big )
Oct 23, 2014 | All-Power America Steele Products SPWE175...
Pump will build up pressure then pressure is gone then rebuilds back up and let go again. How do I keep the pressure up? Can this be fixed?
Sounds like you have air in the line. Before starting - turn on the water and squeeze trigger for a few minutes to get the air out. Then start like you mormally do.
Oct 16, 2014 | Garden
Washer has low pressure. but can see pressure build up in hose. then when squeez triger motor stops.
Hello, W/D here.
Sounds like it may be air locked. Connect the hose to the washer. Connect the wand and hose to the washer. Open the supply water, and hold down the trigger on the spray wand. Be patient, this can take several minutes.
Now crank the washer.
Best regards, --W/D--
Feb 01, 2011 | Briggs & Stratton 2200 PSI Gas Pressure...
I cannot pressurize the sprayer. I have the solution in the sprayer. Handle is screwed on. No spray comes out
When you pump the handle is there resistance? If there is, pressure is building up in the sprayer.
If there is no resistance, the sprayer pump is probably deteriorated and should be replaced.
If there is pressure and when you squeeze the trigger nothing comes out, remove the nozzle and make sure there is nothing plugging it.
Good Luck,
Gary
Jan 09, 2011 | Garden
My pressure washer won't build up any pressure. it will run water when you pull the trigger, but it is the same pressure as if the unit if not running
I'll assume you have an electric rather than a gas powered unit. First check the button on the plug to be sure the GFCI hasn't popped and be sure the outlet has power. With the water faucet turned fully on and the power switch on squeeze and hold the trigger for at least 10 seconds to let the water flow push the air out and then it should start up.
Apr 15, 2010 | Garden
Gas engine will not start without pulling trigger on wand to relieve pressure-engine dies when letting off trigger
I am afraid that is how they work even electric ones wont start unless you squeeze the trigger ,once they are running you should be ablr to release the trigger , and then squeeze it again whilst running . if yours dies when you release the trgger while motor is running -----good chance you are working at too high pressure. but to start you have to release all the internal pressure
Aug 22, 2009 | Campbell Hausfeld 2000 Psi Gas Pressure...
Troy-Bilt 2700 PSI 2.3 GPM Gas Pressure Washer 020486 Logo
51 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
