Question about Mitsubishi WD-62531 Projection Television
How do I fix the problem with my WD-62531 projection TV shut down by itself with Timer green light blincking
How do I fix the problem with my WD-62531 projection TV shut down by itself with timer green light blinking
SOURCE: Mitsubishi dlp tv green timer light blinking
timer light keeps blinking tv does not turn on
Posted on Nov 29, 2008
  • 179 Answers
SOURCE: Mitsubishi Mod. WD-52825 projection tv
9 times out of 10 it is not an easy fix. however ot is not an expensive fix either. checkout www.tv-techs.com
Posted on Dec 29, 2008
SOURCE: WD 62725 Timer geen light keeps blinking
Here is how you fix the problem. Turn off the power to your TV for 10 seconds, then turn on. Next, take a paperclip and push in the reset button for 10 seconds, then release and wait until the light stops blinking - may take up to 5 minutes - be patient. Then turn on your TV as normal and your problem will be fixed.
Posted on May 30, 2009
SOURCE: Green Light on Mitsubishi WD-62525 keeps blinking
Fluke solution: Press and hold Menu+Enter on front of TV...
WD-62525: My Green Blinking Fix!!!
http://www.avsforum.com/avs-vb/showthread.php?s=eb9ba9017a86fd9993de5feb77ee5f25&p=17646001#post17646001
Posted on Feb 09, 2010
  • 8 Answers
SOURCE: Blinking green light Wd-C657
sell it
Posted on Apr 16, 2010
Screen is green
if it a standard tv thats is come from the picture tube
its look to be the green cathode in the picture tube
it can be fix whit a picture tube regenerator...
hope that will help
May 03, 2010 | Mitsubishi WD-62531 Projection Television
Light engine
hold menu and input or device button at same time for 5sec. Let me know what blinking code you get. 3-2 6-1 etc.
May 25, 2009 | Mitsubishi WD-62531 Projection Television
RED LAMP LIGHT!!
Check to make sure your lamp is not blown.
Make sure you installed a Mits original, and not a generic.
Make sure the lamp is seated and secured properly, as slight movement can cause a loss of connection.
Slide your set out to the side and peer into it through the slats. Can you see the lamp fire on?
Your symptom does not indicate that it could be a problem other than the lamp and the installation thereof, however---there is an instance where 2 capacitors will blow on the power supply and cause a red lamp light to show. Furthermore, the light engine itself could be causing the problems.
But, since you just installed the lamp, I would look over your installation.
Apr 09, 2009 | Mitsubishi WD-62531 Projection Television
New lamp, now color variation, dull picture and overheating
it sounds like if your tv is a dlp the colorwhele is stuck
probibly because a after market or faulty bulb has melted it
get serviced imedietly
Jan 23, 2009 | Mitsubishi WD-62531 Projection Television
Mitsubishi tv model wd-62531 less than 2 years old
It sounds to me like your bulb has burned out. Look behind your TV for where the bulb housing is and pull the bulb out to check if it's burned out or not. You'll know when you look at it if it's toast.
Dec 10, 2008 | Mitsubishi WD-62531 Projection Television
Green Blinking Light plus Red Lamp Light
You lamp bubl has burned out. You need to replace the bulb. you can order a new bulb on line by searching the web using your model number bulbs are about $110 if you reuse the cartridge and replace the bulb only. replacing the whole cartridge and bulb is around $ 200
Nov 27, 2008 | Mitsubishi WD-62531 Projection Television
Mitsubishi WD-62531 Projection Television Logo
47 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
