Question about Frigidaire ATF6000ES Front Load Washer
Wont drain we have a front loading machine and it will not drain the water it spins but never gets dry enough to put in the dryer.
    President:
  • 744 Answers
You may either have a problem with debris in the pump or the speed control board, try accessing the pump usually a panel on front bottom...on front of pump which is normally located in front of machine there should be a knob wich can be turned and give you access to the debris collector, make sure the filter/collector is clean..re-screw it into the pump and try another load.
2 things to bare in mind
1 unplug the machine before servicing
2 make sure you have alot of old towels handy since water from the drum is going to run out over your floor.
Posted on Jun 23, 2009
My Kenmore H2t front load washer won't drain and
Hallo there
So it will not do what it is told. This happened to my Candy machine the other day. It was finished and I opened the door, out came water and I got 5 towels on the floor to dry up the water. Closed the door again and put empty water on, it emptied the water, stopped the machine and put spin on and it made it.
My experience ,learned the hard way, to wait long enough after the machine stops as well as between changing programs.
I this will be of some use to you.
Kolbrun
Apr 15, 2012 | Kenmore Washing Machines
Wont spin,and the water doesnt drain
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 04, 2010 | Whirlpool LTE5243D Top Load Stacked...
The clothes have to be spun 2/3 times to get them dry enough for the dryer.
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 20, 2010 | GE WBSR3140DW Top Load Washer
Maytag Performa agitates, but wont spin corectly.
Washing Machine2_bing.gif does not Pump or Spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
heatman101
Jun 07, 2010 | Washing Machines
The water in my stackable washer and dryer wont drain
heatman101
May 19, 2010 | Maytag LSE7806A Top Load Stacked...
Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
hold the start button for 5 seconds this should clear previous program. then select drain on your dial. press start as normal and machine will drain. if this does not work the only other remedy is with help, making sure the end of the drain hose is higher than drum at all times take machine outside, lean it back at 45 degrees agaist a wall with a towel or similar covering lid to stop scratching . working from underneath loosen the large jubillee clip that connects the drum to pump drain hose to the drum. As the drum is overfull there is no recepticle large enough to fit under so just let water just flow away. Dry every thing off. make sure you don't loose ping pong ball in filter and make sure filter is clear. refitting is reverse of removal
Mar 28, 2008 | Hotpoint Aquarius WD640 Front Load...
Not draining
it will be the pump they have a small fan inside them they get weak and with the pressure of the water they stop spinning which doesnt push your the water through the motor fast enough to drain properly replace and you will see the difference
Aug 22, 2007 | Hotpoint Aquarius WD640 Front Load...
Washer dryer is no longer drying
two things to check take rear half of cabinet off and check the dryer duct (lhs from front) is not blocked. this is very common check water is being taken in during dry - the water is used to condense steam from the drying clothes. easiest way to check this is to see that some water is being drained during the drying cycle. i assume that drain is operating ok
Jun 03, 2007 | Zanussi ZWD1270 Front Load Washer / Dryer
Frigidaire ATF6000ES Front Load Washer Logo
152 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
