Question about Kyocera Mita KM-2050 Printer
HOW i CAN FIX THE ERRO C6400
I HAVE THE ERRO C6400 IN MY KYOCERA MITA 2050 KM HOW I RESET THIS ERRO?
    Champion:
    New Friend:
  • 245 Answers
Press10871087 after press163 reast
Posted on Dec 24, 2014
leroyal
  • 2120 Answers
SOURCE: Kyocera Mita km-1820
Unplug the power cord for 10 seconds.
Posted on Jan 15, 2009
SOURCE: kyocera km-2050 scanning function
The km 2050 was on network, but moved to home and directly into tower system via usb interface connector. Printer works, but can not get scanner to work? read instructions without a clue. can someone help with correct proceedure?
Posted on Mar 12, 2009
SOURCE: I need to reset ID Code on Kyocera Mita KM-5530
The solution is easy! Push the Default Setting/Counter button on the top right side of the keyboard. Press the the Managment icon on the diplay. Enter 6-4-8-2 on the keyboard and select the Managment icon in the OFF position. Close all windows on the display and you should be ready to go.
Posted on Jun 18, 2009
mysticus_tam
  • 38 Answers
SOURCE: Error Code C6050
First you must get into the service mode by keying in 10871087
The screen will start blinking - then key 163 and the screen should read cancel or execute -select execute
when it is complete turn unit off then back on and see if that worked, if not buy a new fuser unit. They cost around $150,00 to $200.00 depending on who you buy it from.
Posted on Dec 21, 2009
n25an
  • 622 Answers
SOURCE: Kyocera mita maintenance light is on and lines
check the rectangular **** glas and table for any white out or particles... clean thoroughly... make copies... clean again... make copies... if same issue... then replace drum... but in most cases its the optics... which I advised you to clean thats causing the issue... if the issue occurs when you print an internal report then its definitely drum... if reports are clear... there is something on the glass... or on the part above it... even a little bit of black toner or ink or whiteout anywhere out there can cause a line
Posted on Dec 23, 2009
How to remove C6400 error in kyocera km 6030
http://www.copytechnet.com/forums/kyocera-mita-copystar/11146-kyocera-km-4050-c6400-error-codes.html
Dec 02, 2016 | Kyocera Office Equipment & Supplies
HOW I CAN FIX THE ERROR CODE C6400
heater problem press10871087 after press 163 reast
May 09, 2014 | Kyocera Mita KM-2050 Printer
Error code C6400
check your fuser unit thermistor or thermostat or lamp as the following digita 1087 1087 and put 163
Kyocera eroor code c-6000
Works with ERROR C6000, C6300, C6400
Switch off
Open Toner Cover
Switch on, holding "System Menu"
Go to "Secure Setting"
"Enter"
Hold "Start" "#" "Enter"
Scoll down to "Maintenance Mode"
"Enter"
Scoll down to "U163"
Scoll do "Execute"
"Enter"
Close Toner Cover
Leave run for a few seconds
Switch off
Switch on....
May 04, 2014 | Kyocera Mita 2 Pack Km 2020 2035 2050...
Kyocera KM-2050 Problem error C6400
Fuser unit Error code, you can try to reset, but if the code still there, you need to change the fuser unit.
This is the way to reset your fuser code;
On the panel press 1087 1087
this will take you to the service mode,(look into the screen)
now on the panel again press 163 and hit the start key.
Look in the screen, you will see execute, select execute by the arrow and hit the start key, the machine will turn off then on. or it will ask you to turn the main power off than on. this might fix your problem, if not! change the fuser.
Nov 19, 2011 | Kyocera Mita KM-5035 Printer
KM-2050 Printer: i need to find the pin number to my kyocera km-205...
I need to create a new pin on kyocera 5050 machine as the old one is lost
May 05, 2010 | Kyocera Mita KM-2050 Printer
Kyocera km-2050 scanning function
Mar 04, 2009 | Kyocera Mita KM-2050 Printer
I have kyocera km 1650 and i want to resert the fuse error C6400, how cqn i do it?
press status key
scroll down to service
press enter
press 163
press enter
wait 10 seconds
recycle power
Jan 26, 2009 | Kyocera Mita KM-2050 Printer
Problem C6400
it is a zero cross signal error, could be poor conections or power supply faulty or engine board faulty. you will need to get a tech to check it out
Nov 03, 2008 | Kyocera Mita KM-2050 Printer
Kyocera Mita KM-2050 Printer Logo
299 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
