Question about Ovens
GE JCKP17WP-2 OVEN NO DISPLAY
THE DISPLAY OR KEYBOARD IS BLANK
2 Suggested Answers
Daniel S
  • 4323 Answers
SOURCE: i have a 3 yr
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Aug 09, 2011
Maytag cwe4800acb oven shuts off and display goes blank during heating
Display on maytag oven 8114p471-60 went blank - Fixya
www.fixya.com/.../t16018814-display_maytag_oven_8114p471_60_we...
Jan 20, 2013 - Stove top electric ignition still works fine, so there is power going to the .... maytag cwe4800acb oven shuts off and display goes blank during .
Oct 10, 2015 | Maytag CWE4800ACB 2.6 cu. ft. 24" Single...
Oven display is blank and oven light does not come on
90% of the time this will be the main control board if neither of the displays work. Here is that board to order.
All parts come with a 365 day, any part, any reason return policy.
Feb 18, 2013 | Ovens
GE Wall Oven Model # JKP07G0D2BG - The clock has quit working. Any suggestions would be greatly appreciated.
I assume the display for the clock/timer is now blank. If the oven is still working the only thing you are missing is the clock. If you can't do without it you will need a new clock.
Most of the time the clock/timer stops working it affects the operation of the oven, the oven won't work. If this is the case you will need a new timer unless you can do without the clock/timer. If so a repairman should be able to bypass the clock with ease so that the oven will operate without the clock/timer.
Feb 12, 2011 | GE 24" Built-in Single Electric Wall Oven...
My G.E. electric oven will beep and shut off after 15 min. or so. The read out says "F-2". What is going on?
This is what GE recommends:
“F— and a number You have a function or letter” flash error code in the display • Press the CLEAR/OFF pad. Allow the oven to cool for
one hour. Put the oven back into operation.
If the function code repeats. • Disconnect all power to the oven for at least 30 seconds and then reconnect power. If the function
error code repeats, call for service.
May 18, 2010 | GE Profile JTP56 Electric Double Oven
Double oven, top oven run by keypad turns off
I have a double oven. The top unit works fine. The bottle unit will turn on to cook or clean. Then after a few seconds it turns itself off.
Oct 12, 2009 | GE Profile JKP56 Electric Double Oven
Display went blank during the self cleaning cycle
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
uiitu
Apr 29, 2009 | GE JTP28 Electric Double Oven
My viking electronic oven display blank
Contact Viking. I am pretty sure that the display unit still has a parts warranty.
Feb 26, 2009 | Viking VESO176 Stainless Steel Electric...
Display is blank, no heat no bake
The oven control panel has failed. For more tech help with this issue and a place to order parts I suggest you go the link below, it is where I go for parts and help. You will need to model number available. Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Jun 28, 2017 | GE Monogram ZET3058SHSS Stainless Steel...
Ge profile advantium 120, scb1001 oven, display panel out
My GE Profile Advantium120 interior lighting it out .What do i do to replace these bulbs.
Jun 29, 2008 | GE ZSC2001FSS Advantium Electric Single...
GE Electric Single OVEN JKP15
im not there but if i reamber right that model has a thermal limiter in them which is a breaker that in some instalations gets too hot on self clean and blows they have a kit at ge for that if you turn your breaker on the clocks works but not the oven call 1-800-ge-cares and order the kit
Dec 16, 2007 | GE JKP15 Electric Single Oven
Ovens Logo
42 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
