Question about Multiquip GA6HA Recoil Start 6000 Watt Honda GX340 Portable Generator
Where can I find the part number for the wiring harness behind the instrument panel on a Whisperwatt DCA10SPX4? Rodents have chewed through the existing wiring. I have found references for the SPX3, but not the 4
Egr temp sensor nr1 high voltage, 2013 gmc 6.6 diesel, have had recent problems with rodents chewing on wiring. Suggestions ?
You need to pull the harness up high enough to look at it. They probably chewed right thru the supply voltage wire to the EGR sensor. Since it is saying high voltage the ECM is OK, it is doing what its supposed to. The ECM isn't seeing a voltage drop because with a open circuit there is no place for the voltage to go. Id look in the valley area between the heads, they love to nest in this area for warmth.
Oct 27, 2013 | Cars & Trucks
My check engine light just came on and I took it in. I was told rats chewed thru my ignition coil. To replace it they are charging me $671 for the part alone!! I feel like this is outrageous and I'm...
I've been in this business long enough to believe that nothing is impossible. That said, I've seen many wiring harnesses chewed up by rodents, but never hard parts like a coil. If a harness has a few wires chewed, most shops will just repair it but if there is extensive damage, likely they are replacing the entire thing. Depending upon which harness needs replacement, the cost can be expensive both for labor and the part itself. That would make more sense. Sure there isn't a mis-communication and that's actually what the shop is doing??
Apr 29, 2011 | 2007 Mercury Milan V6 AWD Sedan
I have a 2006 Chevy Tahoe...codes reported are P0449 and P0455....replaced fuel cap but did not solve problem....what are my next steps without spending tons of money at a dealership? Thanks
There may be an emissions leak but a very common issue is the canister vent valve. Make sure if you contact your local dealership that you have your vehicles vin number available.
  • P0449 - Evaporative Emission (EVAP) Vent Solenoid Control Circuit
  • P0455 - Evaporative Emission (EVAP) System Leak Detected
  • Dec 28, 2010 | 2006 Chevrolet Tahoe
    I have a 2002 Toyota Camry with a 2.4L. It wont starts it tries but wont. I have checked gas and spark. It is getting the gas but issue with spark. Im getting spark to two plugs the outer two but not the...
    start by checking to see if you have power and ground at the coil connection look for chewed wire rodents are known to chew on toyota wire harness due to what they are made of
    May 02, 2010 | 2002 Toyota Camry
    Rodents chewed the wires leading from the harness side of the connector for the front o2 sensor on my 2007 hyundai sonata. I cant seem to obtain the correct order of the wires as the dealer says this is...
    Rataway fragrance stops odors caused
    Makes one gallon when mixed
    and protects the surface of areas used for nesting.
    Rodents and other animals mark territory (your car, house, etc.) with their scent. Animals are attracted by this scent. Rataway fragrance gets rid of the scent. No lingering scent, no more attraction.
    Rataway fragrance protects car engines, wiring, boats, motorhomes, machinery, heavy equipment, etc. when sprayed to protect the surfaces
    Rataway fragrance is not a pepper spray.
    If you are looking for an effective, natural control for odors, Rataway fragrance is it.
    Again... Rataway fragrance can be used around children, pets, and service personnel.
    What is Rataway Fragrance?Rataway fragrance is a spray that is very offensive to wild animals such as rats, mice, squirrels, rabbits, raccoons, dogs, cats, horses, skunks, and monkeys. Rataway fragrance is not offensive to humans.
    Jul 15, 2009 | 2007 Hyundai Sonata Limited Sedan
    Rodents are getting into my 2004 toyota camry and chewing wires.
    Spray Rataway Fragrance from Rataway.com . Rataway stops rats, mice, squirrels, rabbits,etc from nesting & chewing
    May 17, 2009 | 2004 Toyota Camry
    Gas gauge no longer works
    The light behind myRemove the cluster bezel from the instrument panel. See Cluster Bezel in this group for the procedures.
    Remove the four screws that secure the instrument cluster to the instrument panel Instrument Cluster Remove/Install
    Pull the instrument cluster rearward to disengage the two self-docking wire harness connectors
    NOTE: The instrument cluster has two self-docking wire harness connectors that will be automatically aligned with, and connected to the instrument panel wire harness when the cluster is installed in the instrument panel.
    Remove the instrument cluster from the vehicle.
    Reverse the removal procedures to install. Tighten the mounting screws to 2.2 N·m (20 in. lbs.)
    when I turn my headlights on. All the other gauges are lit, but not the gas gauge. How do I get in there to replace the bulb and fix this? Or is it a fuse problem? I have a 1998 jeep scout Thanks
    May 14, 2008 | 2007 Jeep Scout
    Multiquip GA6HA Recoil Start 6000 Watt Honda GX340 Portable Generator Logo
    13 people viewed this question
    Top Multiquip Electrical Supplies Experts
    Steve
    Gene Haynes
    Are you a Multiquip Electrical Supply Expert? Answer questions, earn points and help others
