Question about Breville CT75XL Ikon 4-Slice Electric Toaster
My 4 slice toaster will not pop up
What can I do to make my toaster pop up? It has a button to pop it up when I choose. That no longer works and now it will not pop up automatically. It beeps when it is done but does not pop up.
Hi my girlfriend just gave me this toaster, and would like to know what the lighted buttons are for thanks
Since you don't mention the make or model number of the toaster or its age I can only make the following guesses.
It might be an electronic model. To test if this is the case, leave the toaster unplugged and push the lever of the toaster down. If it does not stay down it is an electronic toaster. If it stays down then it is NOT electronic.
The lights might be lighted push buttons.
If you plug the toaster in then put a slice of bread or two in and push the lever handle down and one light comes on then this is probably a dual purpose pushbutton. It indicates that the heating elements are on and if you push it will cancel the toasting cycle and the bread slices should pop up.
If there is a button beside the above button it could be for extending the toaster cycle time a bit longer to compensate for a thicker slice or a denser bread like a bagel. If you push it, it will light up to let you know that the cycle has been extended for this reason.
If there is a button beside this one, it could be for extending the toasting cycle to compensate for a frozen slice of bread or whatever, like a bagel or even a frozen waffle.
If you find the make and model for your toaster, it might be on the bottom somewhere, google it to see if you can download an instruction manual for it.
Hope this helps. Good Luck.
Jun 03, 2017 | The Kitchen Appliances - Others
Why wont my toaster work
Bad move. It probably burned the heating element out.
Sep 30, 2014 | Dualit 26102 Lite 2 Slice Toaster
What are top buttons for
Each bay has 3 buttons: Left button: Frozen items (Waffles, etc.)
Center button: Bagel setting ( turns off the outside elements, toasting only the insides of the bagel)
Right button: Cancel (turns off the Frozen and/or the Bagel settings and "pops up" the toast.
Feb 24, 2013 | Kenmore KTES12 Cool Touch 4-Slice Toaster
My 4 slice dual it keeps popping the breaker
One of the heating element is broken and the heating wire which have live electricity is touching the body of the toaster and thus the poppong of the breaker. So you can use this link and check which is the broken heating element . You can buy one or more heating element from ebay there are only two kinds CENTER and END which you have choose from, they will aslo supply aslo replaceing instructions.
Dec 07, 2011 | Dualit 40352 4Slice Toaster
One side of the toasting tray is in the fixed down position with all 4 buttons flashing
the toaster side is stuck and you will have to unplug it and it should pop back . If it doesnt then you will just pull it up with a tool to get it from sticking .
Jan 01, 2011 | Breville BTA840XL 4-Slice Toaster
We have the four slice toaster. The arm on the left will no longer stay down. The side still toasts, but the arm will not lock in the down position.
try removing the lower claening plate and remove the bread crumbs and see if that makes it work again. Many people don't know there is a cleaning try on the toaster.
Mar 21, 2010 | VillaWare 5850 Uno Classic 4-Slice Toaster
Sunbeam 3831 Toaster (2-slice) -- toast/carriage won't stay down
great ! its a great fealing when you save a appliance from the junkyard .
Mar 30, 2009 | Sunbeam 3831 2-Slice Toaster
Dualit 4-slice toaster (84US) warms only slightly
please check and make sure the red button in front is pressed to the right so that all 4 slots will heat up.
if it is to the left, only the left 2 will heat up.
if you need additional help contact the service center at:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Nov 01, 2008 | Kitchen Appliances - Others
What are the buttons for
Bonjour Excuse my english; french is my first language. I have the BC-1605C model; on the top there are 3 buttons; cancel button is somewhere else (at the bottom on the front of the toaster) 1= reheat (the waves on the bottom of the piece of bread)your no 3? 2= defrost (snowflake)your no 2? 3= bagel Hope this will help you
Dec 29, 2006 | Betty Crocker BCF1604 2-Slice Toaster
Breville CT75XL Ikon 4-Slice Electric Toaster Logo
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
