Question about Universal N388 GSM Wrist Watch Phone w/ 1.3"" Resistive Touch Screen, Quad-band, Bluetooth V2.0 and FM"
Reset code factory reset code for a n388
I have nokia 6680 I I forgot screen lock code when I turn my phone on it asking for lock code so now how I can open it ?
How can you forget a code you set and have been using multiple times a day? The default code is 12345. If you 'found' the phone, perhaps it is still set to the default.
NOKIA 6680 - How to Hard Reset my phone - HardReset.info
www.hardreset.info/devices/nokia/nokia-6680/hardreset/first-method/
Hard Reset NOKIA 6680. First method: Power on your handset. Hard Reset NOKIA 6680. Then please press and hold * key + 3 key + Call button + Power button, until you see Nokia logo. HardReset NOKIA 6680; After that enter your lock code. * The default lock code is 12345; Now your phone will reset and restart.
www.hardreset.info/devices/nokia/nokia-6680/hardreset/third-method/ Hard Reset NOKIA 6680. Third method: Switch on your phone. Hard Reset NOKIA 6680. Next press Menu button and goto Settings -> Phone -> Phone management -> Factory Settings -> Delete data and restore -> Yes Factory Reset NOKIA 6680; Then your device will reset and reboots. That's all. See the Previous method!
www.hardreset.info/devices/nokia/nokia-6680/hardreset/second-method/ Hard Reset NOKIA 6680. Second method: Turn on your cell phone. Hard Reset NOKIA 6680. You should now type this code: *#7370#; Then press your lock code. * The default lock code is 12345; After that your phone will reset and restarts. Success! See the Previous method! See the Next method! How to Hard Rest NOKIA ...
Nokia 6680 hard reset
www.hard-reset.com > Nokia hard reset Apr 3, 2010 - Nokia 6680 hard reset: Press these buttons * + 3 + call + Power on your phone. Before the device is reset, you need to provide the lock code. The default lock code is.
Nokia 6680 Hard reset - How To Factory Reset
https://www.hardreset99.com/nokia-hard-reset/nokia-6680-hard-reset-factory-reset/ Feb 18, 2017 - Nokia 6680 Hard reset and Factory reset. Forgot your android mobile Password or PIN or Pattern, Here you can get recovery solutions for free.
NOKIA 6680 Hard Reset - IMEI.info
www.imei.info/hard-reset-1350-nokia-6680/ Are your looking for a way to make your NOKIA 6680 work faster? Do you wish to clear all of the data on your NOKIA 6680 before selling it to someone else? Well what you need is the factory reset. What is it? Factory reset (aka hard reset) is an operation which deletes all data (including settings, applications, calendars, ...
videos
nokia 6680 hard reset Google Search
Mar 24, 2018 | Nokia Cell Phones
How do I reset my security code for my 2005 ML350.
If you're talking the code you set it to then instructions for changing it should be in the instruction manual. Which can be downloaded off the internet. If you're talking about the factory set code, if your disconnect the battery and let set for a few minutes then it will reset to factory code. After the factory code reset you should be able to easily reset your own created security code.
Feb 09, 2018 | Cars & Trucks
I have a n388 watch and I'm trying to pair it with a zte zmax.
Make sure Bluetooth is on. Look in the watches manual for more instructions
Mar 17, 2015 | ZTE Cell Phones
Fisher & Paykel Freezer N388 Manual
hi there.
go to this link and you might find the manual.
Fisher Paykel Freezer N388 Manual Google Search
Mar 14, 2013 | Refrigerators
Factory reset code for nokia x3
i fogot nokia x3 securty how to reset
May 31, 2011 | Nokia X3 Cell Phone
I forgot the lock code to my rumor touch and can still access the phone but cannot lock it because i forgot the code... what do i do?
hi dear.. please help me.. i forgot my NOKIA E63 restore factory settings lock code. please send the how to reset my lock code to manikanta.art@gmail.com
May 24, 2011 | LG Rumor Touch
Key lock on
Hello
Your Dell tV can be unlocked by reseting it to factory reset.
To reset it to factory reset do the folloing.
Enter the TV main Menu.
Select Factory Reset to return the TV Menu settings to the factory default values
NOTE: Before you proceed with the Factory Reset, enter a four-digit access code. The Factory Reset and
Parental Control always share the same access code. The default Parental Control code is 3355
NOTE: Parental Control setting can be reset by doing factory reset
If you ar unable to do this proceedings, do the unlock method used for Philips, and your TVs kit is of Philips.
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
OK.
Feb 01, 2011 | Dell W4201C 42 in. Plasma HDTV
Our TrueTech TV remote came with a preset factory code that allows us to override our code in case we forget it. Unfortunately, my billiant children have figured out the factory code and are now able to...
You can try these codes 2211 or 3308 if they do not work you will need to reset the unit. You will need to unplug it for 45 minutes that will reset the TV to factory settings. Then the pass codes I provided should work.
Jul 27, 2009 | TruTech PLV16190 Television
Universal N388 GSM Wrist Watch Phone w/ 1.3"" Resistive Touch Screen, Quad-band, Bluetooth V2.0 and FM" Logo
90 people viewed this question
Top Universal Cell Phones Experts
William Alequin
Are you an Universal Cell Phone Expert? Answer questions, earn points and help others
