Question about BabyHawk Ivory Shadow Baby Hawk
My Shadow Hawk max force will not fire what to i do?
If will not fire with new ammo and clip. i bought the gun at a second hand store and the ammo and clip in a new set off ebay and it wouldn't fire.
What does 9mm P.A.K. Blank Gun Ammo stand for
German Abbreviation. "Pistole Automatik Knoll" automatic blank gun [ammunition].
Calibre bore of 9mm and firing "Noise" cartridges usually employed through gas rejection shuttles or replica automatic pistols with a realistic firing simulation where the gas from the shot cartridge is used on the Newtonian principal of opposite forces to eject the spent shell while reloading a fresh cartridge (also cocking the mechanism) ready for the next pull of the trigger.
Learning is fun !
Aug 08, 2016 | Optics
Modern ammo for it- 32 Colt short
Contact a local gun lovers shop.
May 18, 2016 | Optics
Harrington richardson arms
You didn\'t state what make, or type (pistol, revolver, rifle or shotgun) of H&R you have, so I can only give generalizations.
As a general rule, centerfire rifle\'s and handgun\'s firing pin protrusion usually measure between .050" and .060".
Shotguns are a little longer at .055" to .065".
Rimfire guns usually fall into the .028" to .035" range.
Once you have established that the firing pin protrusion is within an acceptable range, you can get a rough idea of hammer spring strength by looking at the primer on some fired rounds for how deep and pronounced the indent is.
Also, you mentioned that some brand(s) of ammo fired more reliably than others.
Some ammo requires a harder "hit" from the firing pin to ignite the primer.
This has to do with factors such as the alloy composition of the primer "cup" (some are harder than others, requiring a harder "hit"), some primer compounds are more sensitive than others, etc.
So maybe experiment with different brands and see which ammo works best for you.
Aug 28, 2014 | Optics
Magazine clip has ammo stuck how do i get ti out
Gently unstick it, from the clip, with a tiny straight blade screw driver tryign not to force or take it to a gun shop and have then do it.
Jul 27, 2014 | Car Audio & Video
Smith wesson problems MP15/223 cal.
How many rounds are you capping off on one trip to to the range? If it a 100 rounds or more, your weapon will retain a small amount more burnt powder and the lacquer coating on the cartridges, but it really is hardly noticeable, but still need to keep your weapon clean no matter if you are using copper. Made in USA. The mp (military /police) is a cheap version of that rifle with no cover over the breech, and no clambering damper. Still worth 5-6 hundred new.. The firing pin cruds up, and if it was fired before you got it and wasn't cleaned that would do it. If it fires, it will jam! Try the dirty gun stenerio, not a bad choice, Colt or Armalite get a little more respect and higher price. Never give up on a 15 , parts are available and reasonable price, and ther are a million upgrades , but careful not to find that you have made it too heavy
Apr 20, 2017 | Watches
I have a 243 cal single shot that snaped when fired. Tried different ammo. still misfires
Firing pin is worn. It may make a slight dent in the primer, but not quite enough to press against the anvil inside of the primer, hence the misfiring
Talk to a gunsmith to see if he has any spares, or has the ability to repair the firing pin.
Oct 03, 2012 | Harrington & Richardson H&R Sportster in...
I bought a hawk scope for my browning 7 mag it is a 6x18 specialized reticle 12. I mounted it with browning mounts and took it out after 2 boxes of shells it still will not sight in. It will put two maybe...
May I suggest that you check the alignment of the scope mounts.There is a tool available for this and costs about $10. from Brownells ,or your local gun shop can do it for a few bucks labor.
Sometimes the mounts place stress on the scope so that it is 'not' completely level and bends the scope body.
The other thing you must do to properly sight in a scope it to fire a shot and 'always; tap the scope body with a mallet or something wooden before firing again.
This 'tap' will allow the springs inside of the scope to react with the adjustment.
You should know within four shots if the suggestions are helping..No requirement to fire 20 shells.
The other thing may be that the scope itself may be faulty..Assuming you bought it from a recognized hawk dealer..take it back for a warranty replacement
Please try this and post back the results
Jan 29, 2011 | Hawk Rock & Ice Climbing
It will not fire and I have put the correct ammo in the gun,and I have loaded it the correct way and it will still not fire
Check the end of your ammo. See if there is a dent in it. It should strike the shell hard and leave a very good indention if not,the spring or firing pin is bad....you are using new ammo right?
Dec 21, 2009 | Sport & Outdoor - Others
Infinite Ammo Not working, Resident Evil 5 XBox 360
Infintite Ammo for any weapon in the game can be unlocked after meeting these prerequisites-
- Have that weapon's stats all maxed out
- Have beaten the game on any difficulty
After you've met these requirements you can purchase infinite ammo for that weapon under the bonus features menu. The only thing I can think of is that you missed one of the Infinite ammo toggles. You actually have to turn it on in two places. Once in the special settings where the costumes and game filters are and then again right before you start the actual stage you're doing.
- Infinite ammo -
1.) Complete all chapters of the game from start to finish on any difficulty.
2.) Fully upgrade the gun you want infinite ammo for.
3.) Purchase the "unlock infinite ammo" option for said gun.
4.) Turn on infinite ammo option in the Special Settings menu
5.) Start any type of game and turn on the Infinite Ammo toggle.
6.) Pwn.
Note: This goes for every gun in the game except the rocket launcher and grenade launcher. To get infinite ammo for the rocket launcher beat the game under 5 hours. The grenade launcher has no infinite ammo option, probably because you can buy ammo for it no one knows.
You must first complete the game to unlock the bonus features unlimited ammo feature. Then proceed to upgrade (or previously have upgraded) a gun fully. Once upgraded it will allow you to redeem points in the bonus features menu. Turn on the feature in the bonus Features menu, then start your game. A new option saying "unlimited ammo" should appear under the "attack response" option. Make sure this option is set to yes to allow infinite ammo.
Go to special settings where it says costume, filter select, and infinite ammo go to infinite ammo and turn it on there.
Click HERE for additional information
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 13, 2009 | Capcom Resident Evil 5 for Xbox 360
In Gears of War 2, when I get ammo after I die, why is it reduced
this was just a simple glitch that was solved by the recent patch update.
Before you died you have less ammo so it seemed as if you were gettting more m when you spawn you get more ammo and some ammo boxes don't give your gun max ammo where some did ( that was the glitch)
Mar 15, 2009 | Microsoft Gears of War 2 for Xbox 360
BabyHawk Ivory Shadow Baby Hawk Logo
Top BabyHawk Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a BabyHawk Baby Gear Expert? Answer questions, earn points and help others
