Question about Chevrolet Silverado 1500 HD 200-112-1 Cold Air Dam Intake Syste
Truck will not start in park only in nuetral
  • Airaid Master
  • 2,210 Answers
Look for park switch on control linkage, neutral switch is usually on gbox
Posted on Jul 30, 2014
Starter stays engaged park or nuetral
Powssible that there is always power to the inhibitor switch. It is the switch that only allows current to flow thru it when in park or neutral. Could be power is always present at the switch when it is in park or neutral. Check the ignition switch first and see if it is powering the start circuit all the time.
Dec 05, 2013 | 2006 Chevrolet Cobalt
Won't start in park in nuetral
will a 1989 Toyota camry transmission fi 1991 Toyota corolla
Jul 25, 2013 | 1998 Ford Escort
Only starts in nuetral
park nuetral switch on transmission may be bad.
Dec 17, 2012 | 1994 Plymouth Voyager
Crown vic 2000 wont crank ? battery, alternator,starter,starter relay all good ?
The problem is in the wiring harness,yes the battery and starter is good, the harness you repaired is the PRNDL. for the starter to start it need a path when the vehicle is Park or Nuetral,there the path is closed some how by Park and Nuetral the path is open.Thats why there is a no start.when in park or nuetral the path is closed.
Nov 12, 2012 | 2000 Ford Crown Victoria
My 2001 dodge durango will run, but once i park it it wont start again. If i play around with the shifter the truck will start, What is wrong with it?
Is this an Automatic transmission? If it is, and what is happening is that when you turn the key the starter will not engage, then you play with the shifter nob, and then it will start, then it is the
NUETRAL SAFETY SWITCH.
This is there to ensure that you cannot start the car in a gear, and will only start in either Park, or Nuetral. They go bad, just like anything else. Try starting the car with the gear-shifter in the NUETRAL position. I bet it will start.
Where the switch is located on this car, I am not sure, but it is not an expensive fix.
Jun 11, 2011 | 2001 Dodge Durango
Jeep won't shift out of second starts in second unless manually shift second is highest bit will go
Check the nuetral safety switch sound like to me you may have problems with this a vehicle should only start in park or nuetral if it starts in any other gear you may need to adjust the safety nuetral switch.
Dec 23, 2010 | 2004 Jeep Grand Cherokee
Try to start vehicle in park, new battery,alternator,serpentinebelt,dash signals come on,nothing. Try to start in neutral, ok. Try again inpark, nothing, then neutral, nothing? Park safty switch, or...
Try holding the key in the crcnk position while you slowly move the shift lever from park to nuetral and back to park. If at any point the vehicle tries to start while you are doing this than its the nuetral safety switch. From your description it sounds like the nuetral safety is the problem.
Dec 05, 2010 | 1991 Toyota Previa
Wont start in Park But will start in Nuetral
Neutral safety switch usually threaded into transmission, unless AW-4 model. Same switch used to trip back-up lights. Look for harness with approx 3-4 wires, unplug & unscrew switch from transmission.
Apr 11, 2009 | 1994 Jeep Grand Cherokee
Chevrolet Silverado 1500 HD 200-112-1 Cold Air Dam Intake Syste Logo
47 people viewed this question
Top Airaid Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an Airaid Vehicle Part and Accessory Expert? Answer questions, earn points and help others
