Question about Whirlpool Duet GHW9150P Front Load Washer
Flashes "DL" and "F"
Wont start, just clicks and flashes codes DL and F
  • 6,784 Answers
A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Replace failed component.
Posted on Jun 23, 2009
Error dl f: door will not lock to start wash
This is obviously a door lock/switch assembly failure. The fault code FdL flashes if the door locking routine fails, after six attempts, to lock the door. You should hear the door lock clicks six times before the fault code flashes. Replacing the door lock/switch assembly is the only viable solution and it's a do-it-yourself repair. You only need a pair of needle-nose pliers to stretch the door gasket retaining hoop and a Phillips-head screwdriver to remove the screws securing the door lock/switch assembly to the front panel. Click on the link below for the detailed instructions on how to replace the door lock/switch assembly.
Replacing the Door Lock/Switch Assembly on Whirlpool Duet and Kenmore Elite Front Load Washers
Jun 17, 2011 | Kenmore HE3T Washer
My check engine turns on while im driving everytime. how do i check why the check engine light comes on
Ok, on an OBD 1 system you can read you codes by using a paperclip and jumping terminal a and b. The OBD port should be a large black plastic connector with 12 openings for wire leads. Not all of them have terminals inside in most cases. It should be at the bottom of the dash trim in the drivers side foot well. Terminal A is the upper far right terminal. Terminal B is directly beside it. After the paperclip or short piece of wire is inserted in those terminals turn the key to the on position but DON'T start the car. The check engine light will flash. 1 long flash, 2 short flashes. This let's you know the system is functioning. It should do that three times and then give any stored codes. Example 3 long flashes followed by 7 short flashes is a code 37. Have a pen and paper handy to jot the codes down. If you think you missed anything switch the key off and back on. In most cases a quick google search of example 1988 Subaru DL code 37 will net you results. Hope this helps and good luck.
Jan 22, 2011 | 1988 Subaru DL
Whirlpool GHW9400 Door will not latch. Washer turns on, Starts clicking then flashes dL F
Hi, DL means Door Lock Failure while F is either (F80, 82,
84, 85).....
DL flashes if the following conditions occur:
  • Door lid is not closed completely due to interference.
  • Wash media buildup is preventing the lock bolt from extending.
  • Machine/motor control detects open door lid switch when attempting to lock.
  • Machine/motor control cannot determine if door lid is in a locked state.
Oct 03, 2010 | Whirlpool GHW9400 Duet Washer
Machine will not start dL code flashes
The door lock is not telling the control board the door is locked. You probably have a bad door switch or the wires to the door switch are corroded or broken.It could simply be a wire has come loose. Those washer do vibrate quite a bit.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 16, 2010 | Washing Machines
Working on a pride wheelchair that i just put (2) 12v33 amp batteries in. im getting 24 volts to the controls but the control only flashes and motor wont even try to engage. its a dl 5.2i dynamic...
First, make sure that the motors are both engaged and not in freewheel, and that the charger is unplugged. If it is a constant flash without pause, this is usually an indication that the joystick is "out of neutral", a problem caused by hitting running the joystick handle under a table, for instance, of moisture in the joystick itself. If it is a series of flashes, like 4, pause repeat, then you have a fault somewhere else in the chair. Here's a link to the flash codes for your controller. http://www.dynamiccontrols.com/index.cfm/3,73,237/dna-flash-codes-0307.pdf The flashes, types and manner of flash need to be better described in your posting. Good luck.
Jan 07, 2010 | Pride Health & Beauty
Plymouth acclaim wont start,no spark,no fuel
Do me a favor and cycle the key to on, then off, then on, then off, then back to on,& leave it in the on position.(not start) Now watch & record any flashes of the check engine light. You will get a number of flashes, then a pause, then more flashes. for example: 3 flashes, pause, then 3 more, would be code 33. It will always be a 2 digit number. 2 flashes,pause then 5 flashes, is code 25. When you get 5 flashes, pause then 5 more, that's code 55 which means end of message. Get back to us with any codes that flash.
May 25, 2009 | 1991 Plymouth Acclaim
When pressing the start button a "DL" indicator flashes and then a "F" indicator remains, door does not lock and the washer will not start.
that is the code for door lock. ensure its not stuck or something in rubber boot stopping door from closing all the way and try to reset it.
maybe by unplugging it for a coupkle of minutes
May 24, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Error code on the washer machine
DL/F is a door unlock error the door lock may be broken.
Mar 18, 2009 | Whirlpool Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
301 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
