Question about Transcend TS320GSJ25M2 - Storejet 25M2 320 Gb 2.5" External Hard Drive - Usb 2.0 - Sata - 5400 Rpm - 8 Mb Buffer
WHY WONT MY STOREJET 320 GB DRIVER INSTALL. SAYS ACCESS IS DENIED ?
    New Friend:
    Problem Solver:
  • 15 Answers
First check whether the device is working on another computer. if it is then there are driver issues on the computer you got this message from. if not then your casing interface is not working right. you can get the data off the hard drive by removing the casing and plugging the drive to a desktop computer.
Posted on Feb 22, 2016
  • 21 Answers
SOURCE: My Transcend StoreJet 320 GB USB 20 Hard Drive is
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked (with the computer and hard drive plugged in). I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Posted on Jun 22, 2010
  • 1705 Answers
SOURCE: my external hard disk 320 gb storejet is not
You'll have to work your way through the various options but using the device manager menus and options, you need to give your drive a name or letter incator.
Avoid A:, B:, C:, D:, E:, F:, or G: depending on how many HDD and Disk drives you have.
Posted on Jun 28, 2010
  • 297 Answers
SOURCE: Storejet problem
Good day!
1. Go to my computer and right click then click manage, go to disk management and see if your external harddisk is showed.If showed,then you can see the options there to manipulate your harddisk, either you format it or repartition.
2. You can use also a disk manager software to fully control the function.
Posted on Jul 06, 2010
  • 8 Answers
SOURCE: Hi my Transcend 320 GB harddisk is not getting
hello
connect the USB external hard disk to usb port by the way disconnect other working harddisks
available on the system, boot the system with bootable cd/floppy go to command prompt and run
chkdsk on this drive
Also download "mbrfix" connect all working harddisks along with the nondetecting harddisk and run mbrfix for the USB defective harddisk
Try using different USB data transfer cable, if power source adapter is used check for rated power output in multimeter for this adapter, if found defective replace it with new/good adapter with same
specifications
Bad luck if harddisk controller has failed you have to go in for new harddisk
GOOD LUCK ooo
Posted on Nov 10, 2010
Messic
  • 94 Answers
SOURCE: I can not copy more that 2 GB toTranscend StoreJet
This is most likely because your hard disk is formatted using FAT32 which has a limitation of 2GB file size. Backup your data in another location and format the disk to NTFS and you should be able to copy that big file.
Posted on Mar 08, 2011
Lost driver cd for transcend storjet 320 gb
http://www.transcend-info.com/Support/DLCenter/index.asp?LangNo=0&Func1No=3&Func2No=205#L2
Jan 23, 2013 | Transcend StoreJet 320 GB External USB 20...
Retriving Data from Storejet and uploading to new computor
If the hard drive in the IBM laptop is OK then remove the hard drive from this laptop. Connect this hard drive to an USB hard drive adapter then connect the USB adapter with the hard drive into the USB port on the Vaio laptop. The Vaio laptop should see it as an external storage device (if the hard drive is OK). You can then open the various folders and files then copy these to the Vaio laptop
Jan 09, 2013 | Transcend StoreJet 320 GB USB 20 Hard...
Describe your Transcend StoreJet 2.5 (TS120GSJ25T) 120 GB USB 2.0 Hard Drive Problem
I have Problem with the Transcend StoreJet 2.5 120 GB USB 2.0 Hard Drive.
I didnot register it on line.in time i was presented this nice device..
because it was working ok .when i just connect it to LapTop.
NOW..After almost 2 years .it s became not RECOGNISED BY MY pc.
And i cant find any driver for it.I have all my important documents in Transcend.
WHat can i do.friends.. Any help?
Please help old Lady.
Thanks if responded.
dearme9@yahoo.com is my mail and this is banner i see.
Jul 26, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
My storejet 250 m does not show on my pc or does not open but opens on a mac.how do i rectify this.pl help thnx
if you have access to a mac yo may need to refort mat the drive to FAT32 or NTSC format, windows does not recognize MAC format of data
Mar 18, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
I can not copy more that 2 GB toTranscend StoreJet 320 GB? Why?
Mar 08, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
How do i backup my windows xp pro on my transcend storejet 320 gb
When you plug the Storejet into your USB port on your PC, after the PC's finishing installing the driver, you should see a new drive letter in your "My Computer" area. Once this is confirmed, go to your Start menu at the bottom left of your desktop, go to Programs, then Accessories, then System Tools, then Backup. The backup wizard will walk you through backing up your PC, and will ask you where to back up before it begins, Browse to the Storejet's drive letter, then backup. I hope this helps.
Dec 27, 2008 | Computers & Internet
Transcend TS320GSJ25M2 - Storejet 25M2 320 Gb 2.5" External Hard Drive - Usb 2.0 - Sata - 5400 Rpm - 8 Mb Buffer Logo
115 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
pankaj rautela
pankaj rautela
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
