Question about Lexmark C Office Equipment & Supplies
C935 door a open - C Lexmark Office Equipment & Supplies
ERROR CODE 126.04 FOR LEXMARK C935
This is a Fuser driver freeze failure.
Remove the sub LVPS PCBA and check if it's properly connected.
If it isn't, replace the connection. If it is properly connected then replace the fuser driver PCBA and check if its resolved.
If not POR the machine and Replace the upper printer engine PCBA.
For all the advice you need check http://support.lexmark.com/resources/sites/LEXMARK/content/live/SERVICE_MANUALS/0/SM81/en_US/7558_SM.pdf
Jul 20, 2017 | Lexmark Office Equipment & Supplies
C935 PS3 colours work, but the black fades gradually down the page. No errors on printer, toner at 50%
sounds like you have an air leak into the ink supply system, specifically on the Black ink drive.
Mar 14, 2014 | Lexmark Office Equipment & Supplies
Removal of operator control panel on lexmark c935
You will need to remove the top cover and a couple of screws to remove the operator panel. However, we do not suggest that you do this yourself. There are a lot of wires involved in removing the operator panel. I suggest you call our Technical Support Hotline on 1-800-539-6275 to request assistance.
Aug 13, 2012 | Lexmark C935dn Laser Printer
Hi, I have a Craftsman C935 35516-3 corded lawn mower (about 15 years old). The blade is loose and I can not tighten it (the blade bolt turns without tightening . If I could remove the cowling, then I...
There are two philips screws on top. I got them with a screw extractor as they were rusted. You won't be able to fasten the blade from the motor side though.
Jun 05, 2011 | Garden
Lexmark C935, just fitted a 40x3748 Fuser unit and 40x3698 Transfer Roller, but parts of printouts are still patchy. Is there anything else to replace that would help.
If you are missing spots on the print, are they in the same spot every time? Are they repetitive. If they are repetitive then if you can measure it will usually tell you exactly what is wrong. Make sure the there is no dust/paper blocking any of the laser windows.You might have a bad ITU PN 40X3732, hope not because it is expensive.
Mar 01, 2011 | Lexmark 40X3733 Transfer Belt Cleaner...
Error code
have a lexmark C935, when I turn it on I get 925.03 service pc cartridge
Apr 07, 2009 | Lexmark C935dn Laser Printer
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
11 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
