Question about Irons
Logik LDABXRW13 Preset not working on new radio
The fuse trips when the iron is switched on
dead short internally or bad wiring in the cord
cord can be replaced by electrician but otherwise junk it and get a new one
Dec 09, 2016 | Irons
Logik steam generator iron no steam
Service the steam and spray mechanism:
Unplug the iron.
Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
God bless you
Jan 24, 2013 | Irons
The fuse used i a rion box is called?
normally thermal fuse is the name. for this kind of appliance see the diagram attached. God bless you, you can find in radio shack.
Jul 24, 2012 | Irons
I have the vertical commercial steamer model IS 8100. Machine lights up, no steam. The cord doesn't even get hot. I've tried to demineralize it by allowing vinegar to sit in the well of the base. Thanks...
My unit did the same thing. There is a temperature fuse attached to the heating chamber. If the unit overheats it will blow this fuse. It is not re-setable and must be replaced. Radio Shack carries these items.
Check your chamber for crude. Mine was pretty bad and I ended up filling it up with white vinegar over night. If you can get it to work, boil a solution of 1/4 white vinegar and DISTILLED water. Let it run through a whole tank of it and then run it with just DISTILLED water until you don't smell vinegar anymore. Do this every few months with heavy use.
Jan 10, 2011 | Rowenta IS8100 Iron
Dropped the iron. Something rattling inside. won't work.Anything I can do?
??? may have broken the element . if it rattles it sounds like metal and ect . may cost more to fix than a new and old if repaired will not have new warranty and will cost close to the new price .. so if i were you . spend the money for new .. **** ..
Jan 15, 2010 | Irons
No steam
Check the eBay return policy. If it is new and it does not work it should be returnable.
Jul 28, 2009 | Irons
I have had 2 Shark irons and both simply stop turning on
The cost of repair is more than the cost of a new one. Therefore, trash it and buy a new one.
Mar 11, 2009 | Euro-Pro Shark GI490 Iron
Irons Logo
78 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
