Question about Oki Printing Solutions C9650 Led Printer
Okidata c6050 printer double prints letters - Oki Printing Solutions C9650 Led Printer
Tip
Okidata Dot Matrix Printers So, the one thing that no one ever pointed out is...
So, the one thing that no one ever pointed out is that Okidata printer head jewels get lubricated VIA the ribbon. You MUST use at least 50 to 70% Brand name original cartridges, or suffer premature print head wear.
Once the printed character becomes blurry, get a REMANUFACTURED head, with the oiling wick. This lets you use all the cheap ribbons, by lubricating the jewels directly.
When you are all finished, enter the menu of the printer and play with REGISTRATION. Often you can make a crisper print by tweaking this setting.
on Dec 11, 2010 | Office Equipment & Supplies
CANT STOP OKI 591 PRINTER TO STOP PRINTING REPORT
Check that the LINE FEED button is not jamming or on.
The LINE FEED + POWER ON will print the "Printer Character Report" or "Test Page".
May 24, 2010 | Okidata 591 Printer
How do i cancel a print job on h okidata printer
Click on Start - Printers & Faxes - then double click on your printer.
It will display a list of files that are queued on that printer to be printed, then right click on the print file you want to delete and then click cancel.
Dec 16, 2009 | OKI Office Equipment & Supplies
Okidata Microline 30 Turbo dot matrix
The problem your having is a spacer motor. It's located under the carriage that holds the ribbon/printhead. The part number is 56513701. Available at Seattle Platen - Dale 1800-221-2388.
Here's a free copy of the Okidata 320T service manual that will walk you through testing and verfying before ordering the replacement part.
If this helped you, please hit me up with a FIXYA. Thanks.
http://www.feedroller.com/Store/Service%20Manual/SER320T.PDF
Aug 30, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
A donth know waht to do
Hi luis, please download the manual for the ML320 Turbo.
Main home page. http://my.okidata.com/PP-ML320Turbo.nsf
For the English Pdf manual click on this next link.
http://my.okidata.com/mandown.nsf/1fe7d58578ca7f99852569af0042834b/e08d475cb4b6bf4a852569590039ffc6/$FILE/ae320tug_07.pdf
Once opened click the plus sign next to Contents. Than open Troubleshooting, open List of problems. Follow the instructions for problem 4
Please save the Pdf file to you're hard drive, by clicking on the gray floppy icon (upper left hand corner).
Mike
May 08, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Okidata c3200 - "needs new drums" message
Check your page count, drum life on a C3200 is roughly 15000 pages. This information can be found on the information menu map.
Information Menu ecblank.gif ecblank.gif dot.gif ecblank.gif Menu Item Default Setting PRINT MENU MAP EXECUTE Prints the MenuMap (menu listing) with current settings shown. Information about your printer is also
shown at the top of each MenuMap page.
Life Expectancy ecblank.gif ecblank.gif dot.gif ecblank.gifToner Cartridge
Life expectancy approximately 1,500 pages, assuming about 5% coverage, which means that 5% of the addressable dots in an image are printed with this color of toner. See Toner Cartridge..
Image Drum
Life expectancy approximately 15,000 pages, assuming an average of 3 pages per print job. If the average print job is longer than this, the image drums could last longer, but if the average print job is shorter, then image drums will be used more quickly. See Image Drum.
Transfer Belt
Life expectancy about 50,000 letter-size pages. See Transfer Belt.
Fuser
Life expectancy about 45,000 letter-size pages. See Fuser.
Feb 11, 2008 | OKI C3200n Led Printer
Cannot print double sided
tick box duplex option installed in driver, otherwise install correct driver with duplex option on server, and delete drivers on workstations.
Jan 04, 2008 | OKI C9300 Led Printer
How to disable the Okidata from printing double space
Try reseting to factory defaults.
Power unit on while holding down "tear" and "FF Load" buttons.
Hope this helps
Dezzi
Dec 27, 2007 | Office Equipment & Supplies
Oki Printing Solutions C9650 Led Printer Logo
21 people viewed this question
Top Oki Printing Solutions Office Equipment & Supplies Experts
Roger Binsfeld
richie46
Ron Baird
Are you an Oki Printing Solutions Office Equipment and Supply Expert? Answer questions, earn points and help others
