Question about Maytag MMC5000 Microwave Oven
Sharp microwave wont heat - Maytag MMC5000 Microwave Oven
Sharp microwave has power but does not work and door wont open
Door catch is possibly broken. Consult a qualified Sharp microwave agent.
Jul 29, 2014 | Sharp Microwave Ovens
My sharp R-1492 microwave was running and popped and now it wont heat.
It sounds like the magnetron has failed, but there two other parts of concern, the high voltage capacitor and diode can be a factor, they work together to heat the food. Parts and labor can be high, depending on the nature of repair.
Mar 06, 2011 | Sharp R-1492 Microwave Oven
Loud noise wont heat [sharp R-820 BC
This is an indicator that the magnetron has failed, especially when it is followed by a loud sound, but there are two other parts that can be a factor, the high voltage capacitor and diode. The Convection/Microwave Oven needs to be assessed for parts and labor and cost.
Mar 05, 2011 | Sharp R-820B Convection/Microwave Oven
Sharp half pint microwave wont heat
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 08, 2010 | Sharp R-120D Microwave Oven
Not heating food but will heat plate. wont pop popcorn. takes three times as long to heat food even if on a paper plate
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
Mar 04, 2010 | Sharp R-55TS Microwave Oven
Microwave not heating up
Check the door switch, when it is faulty the oven will turn on but turntable, fan and magnetron wont operate.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Jan 13, 2009 | Sharp R-1850A Convection/Microwave Oven
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
heatman101
fggfd
Sep 22, 2008 | Sharp R-1610 Microwave Oven
Wont heat items in the micro or convection
MODEL NUMBER NEEDED
Apparently this is not actually an R-510HK since that model does not have convection mode. Can you reply back with the correct model number? We may have the service manual for you.
A PRELIMINARY OPINION
It sounds like you have loose door switch mounts or possibly loose door hinges.
If the door won't open via the door open button, then the outer cover will have to be removed.
BEFORE YOU RATE THIS
This is a preliminary post, asking for further information (model). Please withhold your rating until we actually offer the solution.
Dec 06, 2007 | Sharp R-510HW Microwave Oven
Maytag MMC5000 Microwave Oven Logo
13 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
