Question about Bosch 24 in. SHU6802UC / SHU6806UC Built-in Dishwasher
Why does the cycle take over 3 hours to comlete?
Every time I start the unit the "cycle countdown" display shows 2H. The cycle begins normally but the unit takes 3 and one-half to complete. If I change the display to zero using the "delay start" button, the display will revert back to 2H but the unit will not start.
2 Suggested Answers
  • 27 Answers
SOURCE: prolonged washer cycle time
Hi! I'm not familiar with this model, but it sounds to me like there is not a problem! If you set the delay time to 0H, switch off the unit at the main switch, then switch back on. If there is still a 2H displayed, it means that the PROGRAM that you have selected will take 2hours! This is fairly common for the Bosch units on the 50 - 65degC cycles...some models have a "reduced washing time" button - it looks similar to the "delay" symbol, but once pressed, it reduces the washing time by almost half (cuts on rinse cycles) If your model does not have a reduced time button, select a shorter cycle (35/40/50eco), and see if the time is less. Remember that the latest dishwashers are engineered to be more energy efficient and water wise, so they had to lengthen the wash cycles in order to get good wash results! Hope this helps! C.
Posted on Jun 25, 2007
Set clock and be able to tell am from pm setting
The Clock uses a 12-hour cycle with a.m. and p.m.
1. Check that the oven is off.
2. Press CLOCK.
3. Press TEMP/TIME "+" or "-" arrow pads to set the time of day, including a.m. or p.m.
4. Press CLOCK or START
The Timer can be set in hours or minutes up to 12 hours and 59 minutes.
1. Press TIMER.
2. Press TEMP/TIME "+" or "-" arrow pads to set the length of time.
3. Press START to begin the countdown. If enabled, end-of-cycle tones will sound at end of countdown.
4. Press TIMER twice to cancel the Timer. Do not press the CANCEL/OFF keypad because the oven will turn off.
5. If the TIMER is running, but not in the display, press TIMER to display the countdown for 5 seconds
Delay Start:
The Start Time keypad is used to enter the starting time for an oven function with a delayed start.
Hope this answers all you questions about your stove.
Jaye
Nov 04, 2013 | Whirlpool RF263LXTQ Range
Bosch Dishwasher, SHU 5300 - Cycle stuck on 2H cycle
yes it needs a new control and its pretty easy to replace..
Dec 13, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
My gaggenau dishwasher GM 954-110 is not working. when i switch it on the display panel shows 2H.
Hello, welcome to FixYa.
The dishwasher you're speaking of (provided it is indeed a Gaggenau GM954) is built by Bosch as you may or may not know.
To address your concern regarding the 2H in the display actually needs to be done in two parts. I'll start with the basic info associated with the 2H displayed.
This can be simply indicating the previous cycle exceeded a 2 hour wash cycle, not necessarily an error and can be attributed with too cold water entering the dishwasher (below the recommended 120F), a longer than normal drain time (due to partial blockages, kink etc. hence longer time needed to complete the cycle) or inproper water circulation during the cycle.
Aside from these issues, it (2H) can also mean the unit has a heating error and if left long enough will show another error of "1" in the display, extremely long wash times, etc.
**The first thing I'd suggest before attempting any repair is running an additional cycle while making sure the water inlet is hot (120F optimum) and the unit does indeed drain fine.
**A fair indication of proper draining is to start a cycle and once washing begins (2-3 minutes) activate the "cancel" and the unit should adequately drain in the 2 minute time allowance.
**To identify proper water circulation, place an empty cup in the upright position in the top rack, start a cycle and inspect the cup after 2-3 minutes and it should be full of water.
After trying and posting the results of these thing's we can move forward with potential heating errors, the cause, and how to remedy them. Let me know what you find and I'll continue to assist you in any manner possible going forward. Good luck.
Regards,
Macmarkus :)
Jun 30, 2011 | Dishwashers
Controller, door interlock and motor replaced. Unit comes on, but does not operate.
Hello Dave,
Welcome to FixYa.
Try this test I posted below and let me know what error you find...if any.
To begin the test program, press both the SCRUB WASH and DELICATE/ECONO wash program buttons at the same time
as you turn the unit on by pressing the ON/OFF button. Initially, the control unit version number will appear in the display
(e.g./ 20 = version 20, 21 = version 21, etc.).
When the wash program buttons are released, the LED's above them will begin flashing. To end the test program or test cycle, press the ON/OFF button.
To check the wash program LED, press its corresponding button.
To check the Cycle Countdown display, Refill Rinse Agent LED and REGULAR WASH button LED, press the REGULAR WASH button (press the DELAY START button to test the
Cycle Countdown display alone).
The Cycle Countdown display should show "88" when the DELAY START button is pressed and "8h" when the REGULAR WASH button is pressed.
To start the test cycle, press both the SCRUB WASH and DELICATE/ECONO buttons a second time.
When the test cycle has completed, the Cycle Countdown display will indicate a fault using the codes below. If a combination of faults exists, the code numbers will be added together, (e.g./ 6 = faults 2 + 4).
0 = No faults
1 = Aqua Sensor ("Sensotronic") fault
2 = Heating fault
4 = Filling fault
8 = NTC (temperature sensor) fault
email me at macmarkus@live.ca and I can send you via a "pdf" of the diagnostic/repair manual for your specific Bosch...provided it is indeed a SHU5316 unit.
I`ll watch for your reply. Good luck.
Regards,
Macmarkus :)
Sep 30, 2010 | Bosch SHU5316UC Dishwasher
Dish washer does not turn on CL light stays on when reset count down 6 appears then goes to CL
Hello and welcome to Fixya,
I have a ton of service info on Bosch so it`s best I post you an exert from the service pdf`s I have on my PC which will explain the meaning of "CL" and then go from there. This is not a common indication of a control problem, but it could be a problem with the plastic casing which houses the control, we`ll deal with that later.
I`ve underlined the section pertaining to the "CL", this is for the SHU68** dishwashers only.
TO OPERATE:
First depress the On/Off Button until it locks in place.
Once the On/Off Button is depressed the LED above the previously used cycle will illuminate.
To change the cycle, simply press the desired Cycle Button twice. The LED above that cycle will then illuminate.
The Cycle Countdown will display an approximate run time for the cycle chosen.
This run time will depend on incoming water temperature and the turbidity of the pre-wash water.
Note: It is normal for the Countdown Display to remain at a time increment for more than one minute, or skip a time increment depending on the calculations of the Control Unit. Also, with continued use the Control Unit will learn the wash and temperature patterns for the most commonly used programs and will then reduce the overall start and running times.
At the end of the cycle the display will show a CL, indicating that the cycle is complete.
**TO CANCEL A CYCLE:
Press the Scrub Wash and Delicate / Econo Buttons both in at the same time. The unit will then drain and the figure CL will appear in the display.**
DELAY START:
The Delay Start feature allows the unit to be delayed for up to nine hours. To program, start the unit as described above, but after selecting a cycle push the Delay Start button. The display will show a 1h, or one-hour delay. Continue to depress the Delay Start Button until the desired delay time is reached (up to nine hours, 9h).
The unit will begin automatically once the delay time has elapsed. To reset the delay, press the Delay Start Button until it reaches 0h.
TOP RACK ONLY:
The Top Rack Only feature can be used in conjunction with any cycle. To active, press the Top Rack Only Button after selecting a
cycle, the Top Rack Only LED will illuminate and all water will be diverted to the upper wash arm for the complete cycle.
REFILL RINSE AGENT LED:
The Refill Rinse Agent LED is activated via a Reed Switch on the Detergent Dispenser, Section 4, Fig. 8-3. The LED will
illuminate when the Rinse Agent Dispenser is empty.
Service note: The Refill Rinse Agent LED will also illuminate when the dishwasher door is opened and then
closed even if the Dispenser is full, but will only remain lit for a few seconds.
“F” CODE:
An “F” in the display window indicates a filling fault.
Please note: If the door is opened during the cycle, the On/Off Button will be reset to off and must be depressed again to re-active the cycle. The cycle will resume from where it left off.
Now that you are equipped with this info, what I`d suggest is trying the **cancel option. ( ** see above )
Once you`ve tried the cancel option, select a Regular Wash and post back what happens and I`ll try to assist you from there.
Good luck.
macmarkus :)
May 14, 2010 | Bosch 24 in. SHU6802UC / SHU6806UC...
The dishwasher has been running for 3 hours and seems to be stuck on 1 minute left. Upon opening, there was sudsy water remaining in the bottom, but the dishes looked clean. The washer just won't go to...
SHU 53 MODELS To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button. To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show ?88″ when REGULAR WASH button is pressed and ?8h? when Delay Start button is pressed. To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4). 0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor (?Sensotronic?) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test) To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty. If water level switch (f1) has failed (opened), display will show fault code ?4″ and unit will continually fill and drain where testing won?t be completed. If flow switch (e5) has failed (opened), display will show ?0″, water won?t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code ?8″ immediately and testing will end shortly after water has started circulating.
Aug 01, 2009 | Bosch SHU5315UC Dishwasher
Touchpad--No Response
The "2H" is an error code indicating the control panel needs to be replaced.
May 08, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
2H accures in digital read out. NO Cycles start, just a humming
Do you own an LG LDF6810ST dishwasher? If not, please reply with the manufacturer name, model and serial number.
Are you saying that the display that normally shows the time is displaying an code of 2H? On an LG, that means 2 Hours, (120 minutes) and is not an error code.
On an LG with a symptom like this, I would arrage to replace the main processor card (PCB). You would be getting an error message if the motor (wash or drain) had failed.
Mar 30, 2009 | LG LDF6810ST Stainless Steel Built-in...
What does the 2H mean? It seems to be the "standard" but the manual has no definition.
Great question!
2H means 2 hours -- 120 minutes ... the display only has 2 digits so it can not display 120 minutes. When the timer gets done near an hour an one half, it will start to display a countdown somewhere near 90 (minutes)
Yes, the cycles are long on the LG LDFxxxx dishwashers, just like all water and energy conserving dishwashers.
This really is a good dishwasher, recommend you keep the rinse aid dispenser filled up and ALWAYS use a brand name powder (like Electrosol or Cascade.) Also make sure when it was installed, it was properly leveled.
Hope this helps!
Mar 12, 2009 | LG LDF6920ST Stainless Steel 24 in....
2H displayed and pump runs nothing else happens
I would check the buttons on the control they may stuck. check the delay button..
Dec 21, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch 24 in. SHU6802UC / SHU6806UC Built-in Dishwasher Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
