Question about JVC Everio GZ-MG27 Camcorder
Why does my GZ-MG27U refuse to format a PNY 32gb sd card?
It returns an error message each time.
  • 3 Answers
SOURCE: memory format problem
First of all, check the lock button on the side of your sd card to make sure it's not in the lock position. If it's unlocked and you still cannot format the card, you can always format it on your computer via usb.
Posted on Dec 17, 2008
Rexdreamer
  • 76 Answers
SOURCE: I have a JVC 20
There should not be anything to install when inserting an SD card, all you do is put the card in the card slot. If you tell it to format you have to go into the menu first and tell the camera which you are referring to the card or the harddrive. If you didnt change the setting to SD card when you did give it the format command than that is why your data was lost. If you are having an SD card error make sure that the little slide switch on the card is set as not to protect the card that will give the error sometimes. I hope this helps
Posted on Sep 16, 2010
welcomejee
  • 10594 Answers
SOURCE: Hi, I have a JVC
JVC GZ-MG21U camcorder hardware does support maximum 2GB SD Card and more than 2GB memory card will not accepted by camcorder hardware.
Your 16GB and 4GB SD Cards are just fine but are not compatible with this particular camcorder and GZ-MG21U is also just fine and needs up to 2GB or less SD memory card.
It is just compatibility issue. Click JVC Support link to download user manual copy of GZ-MG21U and check page-67 of manual for memory card info.
Hope this info will help you.
Thanks.
Posted on Mar 27, 2011
elix0411
  • 3530 Answers
SOURCE: hard drive is full on
Welcome to Fixya
Sounds like the harddrive is giving you the problem. Are you seeing any error message on the screen of the camcorder? Try to plug in the SD card to your computer (if the computer has SD card slot) and see if the computer can detect the SD card. You can format the card from there if the computer was able to detect it. Insert it back to your camcorder after formatting and see the result.
Thank you for using Fixya!
Posted on Aug 11, 2011
SOURCE: I have a JVC GZ-MG200 and I cant get it to accept an SD card (a 16gb class 10). It either comes up
I had a similar problem - I can get it to work with class 6 only
Posted on Oct 04, 2012
My Golf Buddy GPS is showing four numbers instead three. Example; a par 4 that is 380 yds. will show 1055yds. The yardage does go down as you travel to the ball but will still show 900yds. for your next...
Device trouble Pro/Tour Errors
  • Sync with PC
  • CSS error
  • Unrecognizable numerical on the screen
  • Button Test/Jig Test
  • NFID system error
Platinum Errors
  • RET code 12
  • Application error
Other Troubleshoot (Platinum)
If any of these error messages appear on the screen of your GolfBuddy unit, please contact us for an RMA number. See Returns & RMA's for process instructions.
Returns and RMA's 1. How do I return my unit?If you bought it from a retail store or golf shop, you must return that unit to the retail store and follow their return policies. If you bought the unit from GolfBuddy directly from our website, by phone, or by walking into our corporate office and you still have the receipt, you may return the unit within 30 days of purchase for a full refund. You should ALWAYS check your unit right when you receive it to make sure it satisfies you and that it is free of manufacturing defects.2. If my unit is displaying an error message, what do I do to get it fixed?If you purchased the unit from a retail store or golf shop, you can take it back to them and exchange it for another unit, depending on their exchange policies. You can also call 1-888-296-1428 to request an RMA number to ship the unit to the GolfBuddy Repair Center. You will need a receipt if within warranty to waive any repair fees for manufacturing defects. If it falls within the 90 day limited warranty, we will repair or replace the unit free of charge. If it does not fall under the warranty limits or if it is outside the 90 days time frame, then there will be a repair charge billed. The customer is liable for all shipping costs to GolfBuddy.
May 24, 2011 | GolfBuddy GPS
What is error #2200
The 2200 error message indicates a scanner stall or jam. The steps below will help you to resolve the issue and clear the error message.
Printer Reset
1 Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Attempt a test scan. If the error message does not reappear, the error is resolved.
2 Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: contact Dell.
No: Continue to step 3.
3 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
Yes: Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No: Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, contact Dell.
No: Install the color cartridge. If the printer fails, contact Dell. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved.
Mar 23, 2010 | Dell 962 Photo All-In-One InkJet Printer
I get the error 2200 message everytime I try to send a fax
Hello there:
this is a scanner stall or jam. The steps below will help you to resolve the issue and clear the error message2.gif.
Printer Reset
NOTE: The embedded links in the table lead to specific troubleshooting documents.
StepAction1
No: Attempt a test scan. If the error message does not reappear, the error is resolved.2
Power off the AIO and remove the power supply from the back of theunit. Open the scanner cover. Check the scanner glass for cracks andthe scanner casing for cracks. Close the scanner lid. Open the topcover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Contacting Lexmark.
No: Continue to step 3.3
Power off the AIO and remove the power supply from the back of theunit. Open the top cover of the AIO. Using the carrier belt, move thecartridge carrier to the middle of the unit. Insert the colorcartridge, close the top cover, reinsert the power supply, and power onthe AIO.
Yes: Repeat step 3 with another color cartridge. If the printer2.gif fails again, continue to step 4.
No: Repeat step 3and install the black/photo cartridge. If both cartridges areinstalled, attempt a test scan. If the error message does not reappear,the error is resolved.4
Power off the AIO and remove the power supply from the back of theunit. Open the top cover of the AIO. Using the carrier belt, move thecartridge carrier to the middle of the unit. Remove the color cartridgeand insert the black/photo cartridge. Then close the top cover,reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark.If the error message does not appear with both cartridges installed,attempt a test scan. If the error message does not reappear, the erroris resolved.
Nov 10, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Error 2200 lexmark 6250.
hey ,
Follow the steps :-
Step Action
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved...
Nov 15, 2008 | Lexmark X7170 All-In-One InkJet Printer
Error message E0532
E532 The stapler does not return to the home position for the front/rear shift operation within a specific time.
Problem with stapler unit or stapler board
Sep 25, 2008 | Canon NP 6545 Copier
Lens Error Message
Hi there
I had the same problem a year after I bought my camera. I returned it to Nikon and they fixed it and returned it. The problem reoccurred 3 times and each times Nikon repaired it free of charge. Then after a year it went again and, when I returned it to Nikon they sent me a new camera. Within a couple of months the new camera had the same problem. I have since resolved it with new batteries! The original coolpix rechargeable batteries do not seem to recharge properly so when I put ordinary AA batteries in it suddenly worked. Good luck.
Mar 31, 2008 | Nikon Coolpix 7600 Digital Camera
JVC Everio GZ-MG27 Camcorder Logo
44 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
